More 66's
Hentis
7 Aug 2006
Poole
Not sure if thishas been posted but Victa Westlink are to order 4 66's from Electromotive Division in Canada. These will be in the number range of 66801 - 66804 (why it cant be 66800 - 803 is beyond me!!). These should be available by Easter 2008.
(taken from this weeks Railway Herald).
So we now have:
66001 - 66250 EWS /Eurocargo Rail
66401 - 66430 DRS*
66501 - 66594 Freightliner
66601 - 66625 Freightliner
66701 - 66732 GBRF*
66801 - 66804 Victa Westlink*
66951 - 66952 Freightliner
Thats 5 companies in the Uk operating the Type 66 loco. Not bad really.
* Locos also on order.
things are looking bleak for non 66 lovers!!!
Cheers
Hentis
thefab444
27 Oct 2006
The New Forest
I presume the Victa Sheds (erm... Veds?) will be used on their freight services, and 47832 will be used on charters?
theblackwatch
15 Feb 2006
Didnt DRS want to use te 66/8 range, but couldn't because they clashed with the numbers of some carriages in either EMU's or DMU's?
That's right, cock-up by Railway Herald I think, as 66801-4 are already in traffic with South West Trains! Unless they are to be renumbered?
clagmonster
8 Jun 2005
Are you sure? I've just had a look through on http://www.thejunction.org.uk/ and no SWT units seem to have numbers in this range. As far as I can see, the following are clear:
66/3 (originally kept clear for additional EWS orders, I suppose now the Germans have come in this is more likely),
66/8
There is the also the question of where any further Freightliner 66/5 orders will go as they are getting close to 66601 which is obviously already taken.
However, I am surprised at the Victa order, seeing as they are a newly set up company with access to other locos, I would have thought they would build up traffic first, using older traction, and then place an order, thus minimising risk. Unless long term contracts have already been signed of course.
theblackwatch
15 Feb 2006
66801-10 (along with 66851-60) are formed in 450101-10. Rather a daft thing to do by whoever decided to allocate those IDs to some units!
Sprog
6 Sep 2005
SPM
I think everyione has assumed that they will be in the 66/8 series, as a small model of the VictaWestlink 66 has the number 66801 on it.
Hentis
7 Aug 2006
Poole
So what other number range will they take then?
Mostly all new TOC's that have taken on a new batch of 66's have been assigned new number ranges, The only number rabgers not in use are 66/3, 66/8 & 66/9 abliet 951 and 952 by Freightliner. I think EWS will want to keep the 66/3 series for themselves, so in my book it would leave either 66/8 or 66/9 and I dont think VWR would want a break of 2 locos if there to choose to have more than 50+ 66/9's
Hentis
clagmonster
8 Jun 2005
Ah yes,I see, please accept my appologies, I just looked at the start of each numbering range and assumed that they would carry on in a logical fashion. Presumably 68201 & 64301 are taken by something else then? I agree, it is a daft idea to use those ranges.
On a similar note to 66/8, 66901-917 and 66921-937 are also used in class 450s. I do feel though that it is unlikely that Victa would order more than 50 class 66s. I would also not be surprised to see any additional Freightliner 66s go into the 66/9 range, as I believe that the new build have had the low emission mods from new, like 66951/2.
1VWC
3 Jan 2007
Correct. When 66599 is reached, any more locos will become 66953 onwards...
Mintona
8 Jan 2006
South West
Why don't they have 66626 onwards first....? Are these for heavy haul and the 66/9s for intermodals etc.?
trains2
30 Jun 2005
Winchester
66/6s are lower geared (apparently) but the whole Freightliner 66 fleet is a shambles as both Intermodel and Heavy Haul 66s are combined from 66501 - 66592, and sectioned in about batchs of 5 or 10, so 66501 - 66505 are Intermodel, 66506 - 66515 are Heavy Haul and so on. The whole fleet needs to be reclassified sensibly with 66/5s being Intermodels and 66/6s Heavy Haul, or else combing the 66/5s into Intermodel and Heavy Haul batchs, so (e.g.) 66501 - 66540 for Intermodel, 66541 - 66592 for HH (don't know the exact numbers.
1VWC
3 Jan 2007
Why?! The current setup causes no day to day problems so why change what aint broke?!
In answer to the original question; 66/6s have a lower top speed and a higher hauling capability and therefore some 75mph diagrams are unsuitable for these. Likewise the trains with heavier loads are unsuitable for 66/5s. Having what would effectively be 66/5s numbered in the 666xx range would cause train planners trouble as they wouldn't be able to distinguish between the two types.
