Cricketer8for9
- Joined
- 11 Jan 2015
- Messages
- 686
Can I put a vote in for Balham, and of course Windmill Bridge north of East Croydon.
Absolutely. Particularly Hyndland East. 14 trains per hour, each way, every hour, over a flat junction!.
Castlefield Junction, Ordsall Lane Junction and Edgeley Junction.Woking appears to be winning the argument at the moment; any naysayers?
I understand the bit about what additional service can be justified. But isn't the SWML full from Woking into Waterloo?It’s a toss up between Woking and Windmill Bridge Junction. Both in development now.
Indeed, but I was led to believe Woking provided a particular headache. Four conflicts an hour and all that, then having to make that work once you get closer to London.
At a cursory glance the Wessex route study seems to justify it as a CP6 project for overall service reliability purposes, and a modest increase (2tph) in services by using the currently unused ‘firebreak paths’.I understand the bit about what additional service can be justified. But isn't the SWML full from Woking into Waterloo?
There is now a scheme in the road programme to dual the A46 Newark bypass (currently the only single carriageway section of an otherwise dual carriageway and motorway route from Warwick to Lincoln). So there's another chance for coordination.Only subsequently did I find that it was not a rail project at all, but the new A46 bypass, which closely parallels the rail line. So a new road could be justified, but not a relief to the rail crossing.
I recall going up the ECML, probably late 1980s, and at the Newark crossing there was the heavy plant building substantial earthworks going in alongside the Nottingham-Lincoln line. I thought the flyover was at last being built, that I somehow had not heard of.
It had been the same when the new Severn Bridge was under review in the early 1990s. Here was a chance to integrate road and rail, and abandon the nuisance in many senses Severn Tunnel, which is closely parallel. But the Dept for Transport does not think like that. I discussed it with the new bridge team at the design stage. Completely blank faces.
So we wonder what additional paths have been created by the recent Shaftholme Junction flyover over the ECML, at a point much less busy than Newark, whose opening coincided with the closure of the coal flow from Immingham to the power stations which it was built to handle.The thing about Newark is that it doesn’t enable any more paths, or at least not long distance on the ECML; the constraints are elsewhere: the 2/3 track section Peterborough to Huntingdon, Welwyn Viaduct (or Welwyn North station depending on your viewpoint), Doncaster, etc.
The only single track bit is between Moreton and Dorchester South, luckily not all the way to Wareham!The entire SWML Fast Line pattern is written around:
-4tph Waterloo-Haslemere/Portsmouth parallel moving at Woking every 15 minutes.
-Dorchester-Wareham single line
-West of England single line
The former is by far the most particularly binding being on the busiest part (the single lines you effectively have the option of playing with stopping patterns along the way)
Pretty sure thats was looked at years ago. It’s not pretty. Has to be a flyover the whole way as it’s all marsh (and protected marsh at that). Unlikely to happen I’d have thought.How about (just for fun as money is no object) a flying junction to take the up Lea Valley Line at Copper Mill Jn over the line from Stratford to Tottenham Hale, and continuing under the Chingford line to rejoin the up Chingford Line at Clapton Jn. A roller coaster ride but removes two conflicts in one hit. Or will Crossrail 2 come to the rescue? .......
Canal tunnels at St Pancras end?This thread has made me think; we have built / rebuilt / created rather a lot of grade separate junctions on the existing network (ie not on HS1, nor on the new Crossrail infrastructure) in the last decade or so. In no particular order:
Any others?
Darlington - so that trains to/from Bish don't have to cross the ECML
Pretty sure thats been looked at. It’s not pretty. Has to be a flyover the whole way as it’s all marsh (and protected marsh at that). Unlikely to happen I’d have thought.
Hitchin
Joan Croft
Allington (slight cheat, but it is effectively a new grade separation)
Acton
Airport Jn II
Reading x 3 (technically 3, operationally 4)
Bermondsey (technically 1, operationally 2)
Nuneaton + the down chord (worth half a point)
Shortlands
Norton Bridge
Any others?
I think you overplay the difficulty of building the Woking flyover. Having watched them build all the new stuff at Reading, Woking would appear simpler all round. Only single track needed for a start. Whatever the merits of your suggestion, and in a national priority list i think it’d be very low, I don’t think you can hang build-ability of Woking on it...My vote may appear to be a bit of a curve ball suggestion, but it would be to build a new junction to allow trains to run Basingstoke to Ascot via Farnborough. Why? It allows you to divert trains past Woking while you build the new junction there (there are other benefits too, such as better connections to/from Frimley and Camberley, including to Waterloo even though the junction would be facing the wrong way for direct services as well as potentially allowing more stations to be built and served without showing down existing services and increasing frequencies on local services).
The Proof House Junction re-modelling at Birmingham also made much better use of the existing grade separations.Rugby remodelling wasn't grade separation as such, but reconfigured the layout to make better use of the grade separation already there
Hitchin
Joan Croft
Acton
Airport Jn II
Shortlands
Norton Bridge
Any others?
You could say that what we've had recently is Airport Jn II and III.Airport Jn II
Any others?
