Most powerfully hauled passenger trains
Discussion in 'Traction & Rolling Stock' started by SM Chobham Int, 27 Nov 2019.
  1. Llama
    Llama Established Member
    1,154
    29 Apr 2014
    26 isn't it?
    1160hp at the flywheel, maybe 850hp absolute maximum hp at rail, 75 tons of loco and 30 tonnes of MK1 makes it slightly less hp for the coach than a solo 153? o_O
  2. 33017
    33017 Member
    126
    9 Sep 2017
    I think it’ll have been 24s you’ve seen photo’s of - Inverness type 2s worked the branch and that depot seemed to use their 24s and 26s indiscriminately.
  3. Justapunter
    Justapunter Member
    355
    21 Jun 2018
    Most of them were. But three were used as test beds for the 87 orders (like 47 046, became 601 and then 901). They had 5,000hp.
  4. gg1
    gg1 Member
    433
    2 Jun 2011
    It may well have been. I've always struggled to tell the difference between later build class 24s (with end doors and headcode boxes) and the similarly designed early 25s.
  5. delt1c
    delt1c Established Member
    1,120
    4 Apr 2008
    Has anybody mentioned when a single HST power car took passengers forward in the brake van on the Newquay branch due to a derailment, will take some beating
  6. Richard Scott
    Richard Scott Member
    112
    13 Dec 2018
    Don't forget the 153 won't have 350hp at rail either due to transmission losses and other loads such as compressor, alternator. The 26s are quoted as 900hp at rail (admittedly not over the entire speed range) so think 26 + 1 mark 1 would win there.
    I know this is abroad but did have 3 ER20s on a 2 coach train, all under power in Austria and an 07 on a single coach in Bulgaria.
  7. Llama
    1,154
    29 Apr 2014
    153s are 285hp too, probably 200hp at rail at best
  8. Richard Scott
    112
    13 Dec 2018
    Oh yes, was thinking of 158s; they're even worse with only 285hp.
  9. Bletchleyite
    Bletchleyite Veteran Member
    44,009
    Up and down the south WCML (mostly)
    In terms of power to weight the 68+Mk5a sets can't be far off - they take off like stink - EMU like acceleration.
  10. ashkeba
    ashkeba Member
    735
    13 May 2019
    68+5Mk5a is 2.8kW over 68t+5*43t = 283t.
    Anyone know the weight of a 755/4?
  11. MisterT
    MisterT Member
    281
    12 Oct 2014
    The Netherlands
    In The Netherlands, we have our Intercity Direct trains, which are 7 coaches (6 in the past) with top-and-tail Bombardier Traxx locomotives at 5.6 MW or 7,500 hp per loco, so a total of 11.2 MW or 15,000hp over 550t total weight. Does that count?
  12. dubscottie
    dubscottie Member
    703
    4 Apr 2010
  13. TRAX
    TRAX Member
    1,010
    2 Dec 2015
    Paris, EU
    It’s all good talking about hp, but why isn’t anyone talking about kN, which is what actually pulls you ?
  14. a_c_skinner
    a_c_skinner Established Member
    1,263
    21 Jun 2013
    That is of course force, not power.
  15. TRAX
    TRAX Member
    1,010
    2 Dec 2015
    Paris, EU
    Yes but it is the main parameter to take into account as far as hauling is concerned. You measure the pulling power of a locomotive by looking at its tractive effort (kN) more than its power (kW), although both parameters are closely linked
  16. 43096
    43096 Established Member
    5,740
    23 Nov 2015
    Not as good as the 2 x Taurus on four coaches I mentioned earlier!
    :lol:
  17. D6700
    D6700 Member
    436
    13 Mar 2010
    I was going to mention that combo, but saw you'd beat me to it! I saw such a train at Villach, featuring a 1016 and a 1116, both with pans up and just 4 coaches.
  18. 43096
    5,740
    23 Nov 2015
    Mind you, the most "throw you into the seat" performance I've ever experienced was a pair of SBB Re460s on 11 coaches leaving Chur 12mins late (waiting bus connection of course!). Think it must have been a Zürich driver on his way home - the acceleration was something else and he was clearly using every kW of power available. Braking for Landquart was equally impressive, hitting the platform ramp at around 70mph and stopping perfectly in the right place. Sadly had to leave the train there, but watching the departure from Landquart - by now just 8 late - it wasn't going to be late by Zürich!
  19. Chris Butler
    Chris Butler Member
    123
    23 May 2010
    You measure the pulling FORCE by looking at the tractive effort, not the power. As you say, the two are linked (power = force x speed), so I am a bit puzzled what point you are making.
  20. Mordac
    Mordac Established Member
    1,781
    5 Mar 2016
    Since this thread is full of pedantry already, I suppose I might as well mention that what "throw you into the seat" is jerk (i.e. change in acceleration) and not acceleration (change in speed).
  21. jopsuk
    jopsuk Veteran Member
    12,098
    13 May 2008
    Maximum tractive effort and power are wildly disconnected- a class 08 can exert 160kN from 261kW, a class 91 190kN from 4830kW.
Share This Page
