MSTS Bin Patch
class57basher
9 May 2011
Hi
I need to remove the bin patch so I can reinstall it again anyone know how ro remove it on XP
Many thanks in advance
class57basher
9 May 2011
Why do you need to reinstall it?
uninstalled MSTS and was reinstalling it I thought it would have deleted the patch as when I have tried installing it again it told me the current patch was installed and when I come to install add-on's which require the patch it comes up as if it isn't installed
I have thought removing the patch may let me install it again
gswindale
1 Jun 2010
I see
Browse to your Train Simulator folder using Windows Explorer.
In there you should find a file called
Uninst_MSTS Patch 1.x.xxxx EN
Double clicking on this should run the uninstall routine.
If not; then delete that file & the associated txt file and also remove the MSTSBin Backup folder.
You should then be able to re-install :)
