NotATrainspott
- Joined
- 2 Feb 2013
- Messages
- 3,224
The current sleeper stock is going to need replaced at some point in the not so distant future, unless there were very extensive refurbishments done which would still be limited by the original carriage layout. The current SLEP coaches don't seem to meet the expectations of customers either, if the comments I heard at the station when one arrived are to be believed.
Any new stock would have to be a completely custom order, which would need to allow both an independently-powered mode for the extremites and electric mode for the mainline work. New LHCS could be used but it seems a lot of the operational complexity of running the services (especially the Highland one, with the myriad operations needed at Edinburgh to split and join) is due to that. It would also presumably be useful for any new stock to share characteristics with the normal daytime intercity stock on the same routes to reduce maintenance costs. With these factors, wouldn't it be a reasonable suggestion to base any new sleeper stock on IEP?
Obviously it wouldn't be as simple as another order of the same, as the window arrangement would need to be altered dramatically, and you would need to find some way of de-rating the traction package down from 140 to 100mph. A 380-esque cab would also need to be fitted to allow the units (presumably 5 car, 130m long) to join properly. Preferably also they wouldn't be aquired based on the stupid PFI-style scheme the daytime trains will be and would be instead bought outright.
By specifying 130m long sets, you could fit three within a single 400m long platform, which would be ideal for the now-disused international platforms at Waterloo, especially during any works at Euston. You could string up a tiny bit of 25kV on the now-four disused platforms to provide a shore supply and you wouldn't need to rush passengers off to allow another train to use the platform in the morning (or evening). Since all the units would be bi-modal, they could run self-powered until they reach OHLE, and can then go straight onto unelectrified routes without the hassle of a locomotive. Obviously this would also be of benefit for non-electrified diversions too. The units would also be faster accelerating over the hillier country ends of the network, and would be lighter so might not be as subject to the same speed restrictions as a 67+LHCS is up to Fort William. Also, with the carriages now being 3m longer you can fit more revenue-earning features.
Clearly the reduction in complexity would also reduce flexibility somewhat too - formations would be fixed so it wouldn't be able to respond as easily to seasonal variations (such as the extra summer coach on Fort William services which would otherwise be on the Aberdeen) but it seems that currently most of the capacity constraints are due to the limited platform lengths at Euston anyway. These certainly aren't helped by having to make room for two 90s.
It's just a thought, which will probably draw the ire of the people who seem so vehemently opposed to the IEP in daytime form. I suppose it makes most sense only if the Night Riviera were removed from the Great Western franchise and given to the new Caledonian Sleeper one - maybe that might even be the time for a return of the Cross-Country sleeper too if it could be diagrammed.
