How do you solve a problem like Leeds?
Not easily.
Theres certainly an argument that other cities have had big infrastructure project, so why cant we (Manchester/ Sheffield/ Nottingham/ Newcastle/ Birmingham/ Edinburgh etc have light rail).
But even if there were a light rail scheme, it wouldnt remove any train services at Leeds City Station. If people on here complain about Altrincham being an unacceptable distance on a tram then I dont think its feasible to use trams all the way from Ilkley/ Harrogate/ Knottingley (and there generally arent any shorter services than those).
Might I just suggest that the London Crossrail stations are built to be deliberately big
Given the cost of doing anything in central London, I dont think theyll have built anything twice as big as it needs to be to meet projected demand over the next fifty years.
If the stations look big then itll probably be because some of them will be in the Top Fifty for heavy rail passengers (despite only having two platforms). Those passengers will need to circulate somewhere.
May I just make the point that the Central focus of my scheme is to reduce the number of local services terminating in Leeds and joining up existing electrified lines with new electrification schemes. I think people are concentrating too much on the tunnelling aspect of the scheme.
I think its a shame that you started with your maps of an underground line as thats distracted the argument a lot. We were presented with a complicated solution to a problem (a solution which involved a double track electrified line from Knottingley to Goole) which tends to mean that people on here focus more on taking apart issues with the solution than agreeing with the solution.
There are a lot of services per hour terminating at Leeds.
At the moment, there are the following services from the east
Edinburgh via York (XC)
Newcastle via York (TPE)
Middlesbrough via York (TPE)
Scarborough via York (TPE)
York (TPE)
York
Hull via Selby (TPE)
Selby
and the following services from the west
York via Harrogate
Harrogate
Ilkley
Ilkley
Skipton
Skipton
Carlisle/ Lancaster via Skipton
Bradford via Shipley
Blackpool via Halifax
Huddersfield via Halifax
Manchester Victoria via Halifax
Manchester Victoria via Dewsbury
Huddersfield via Dewsbury
Manchester Airport via Manchester Piccadilly (TPE)
Liverpool via Manchester Piccadilly (TPE)
Liverpool via Manchester Victoria (TPE)
Sheffield via Castleford
Knottingley via Castleford
Sheffield via Barnsley
Nottingham via Barnsley
Bristol via Birmingham (XC)
Sheffield via Moorthorpe
London via Doncaster (VTEC)
Doncaster via Bentley
so twenty nine/ hour on one side, but only eight/ hour on the other side.
You could balance it up a little by running the Sheffield via Castleford and Knottingley via Castleford services through a new Kippax line (i.e. making them east services instead of west ones) to make it twenty seven versus ten, but thats still an overbalance (and youd have to deal with Woodlesford somehow).
And whilst eight/hour seems okay for double track railway to cope with (those in the Southern Region would be laughing at the idea that this were at capacity), the stock movements to Neville Hill and the differentials between the fast and slow services mean that capacity isnt as carefully used as it might be elsewhere.
Ensure the everything to the east is electrified and therefore run by fast accelerating trains capable of 100mph and youll improve things (since all the Northern services have to be pathed with 75mph Pacers/ Sprinters in mind).
But then, thats why Leeds has so many terminating bays from the east. The nine services an hour from the Armley side (Harrogate/ Ilkley/ Skipton/ Bradford F Sq) have their own bays at the north side of the station so they dont conflict with other services. Run these through an expensive tunnel and what do you use the platforms at the north of the station for?
Take Armley services out of the equation and youve got twenty / hour on one side, and eight/ hour on the other side.
If the Woodlesford services (Sheffield via Castleford, Knottingley via Castleford, Sheffield via Barnsley and Nottingham via Barnsley) are pretty self contained on platform seventeen. Remove them from your equation (since they keep to the fringe of the station and dont conflict with other services) and youre down to sixteen versus eight.
So thats eight per hour running from west to east (e.g. Bristol to Edinburgh, Manchester Airport to Middlesbrough, Blackpool to York, Liverpool to Newcastle), so only eight per hour terminating in the middle platforms.
Of those, two and London services which are always going to have to lay over at Leeds (unless you go back to the electric horseshoe plan and run London Hambleton Leeds Wakefield London circulars with minimal dwell time).
London Leeds Newcastle would be significantly slower than any current services via Great Heck, so little point dreaming up regular extensions of Kings Cross services (unless you run all via Hambleton and extend them to Bradford/ Harrogate etc, but then would those be additional services on the Bradford/ Harrogate side so that doesnt really create any extra paths
Plus, running London services via Hambleton means Wakefield missing out (not just in terms of London to Wakefield but also taking a lot of seats off the Wakefield Leeds corridor).
Whats left? The Huddersfield stopper and the Manchester Victoria via Dewsbury? A couple of stoppers from South Yorkshire (on the Westgate corridor)? A couple of Calder Valley services? If everything were capable of matching a common-or-garden EMU like a 321 (i.e. electrified and/or fast accelerating 100mph stock) then Id suggest running those services through to Thorpe Park.
But otherwise, a tunnel under central Leeds seems a very expensive way of dealing with a handful of terminating services in the main shed of the station.
(Im basing all of this on how things are now I appreciate therell be various recasts over the next five years e.g. the split between TPE and Northern changing, the new Bradford to Nottingham service)
Excuse a 'foreigner's comment' but would not the answer to terminating services be - not to terminate them? Could it be that present franchising arrangements preclude innovative changes to existing service patterns? Down in the SW, we certainly suffer from demarcation between SWT and GWR, IMO.
There is a lot of truth here.
The problems are that there arent a lot of neat short services that can be tied together and there will always be an imbalance between the east and west services (with services from the west outnumbering those from the east considerably)
Any non-terminating services would either require extra paths over the two track viaducts to the east or would mean services from the west reversing to link on to other services (which may mean crossing the throat e.g. the much talked about Nottingham to Carlisle service
why not have a bi-level 4-track east of leeds by having a second level above the two tracksto the east of Leeds, as per the M1 in Sheffield. Costly, but avoids much demolition required for 4 tracks or muchmore costly tunnelling.
Would you have to close off the current tracks for long periods, as all of this infrastructure is built above?
In which case, Im out.
In my view, the "Leeds new line" should be re-opened in some form, between the city centre and the M62 Junction 27 IKEA retail park at Birstall.
A park and ride scheme for commuters at this location is long overdue.
Gildersome tunnel is reported to be in a dangerous condition and it is probably unlikely that trains could run through it once again, as it has been filled with colliery waste where the M62 & M621, go over the top of the tunnel.
Maybe trains could run from Birstall to a re-opened station at Wetherby and some of the
TPE services could go from Huddersfield to York, via Healey Mills and Castleford to free up a bit of space at leeds station ?
A station at the White rose shopping centre would be good. Maybe a bay platform and a set of points could be installed there, for a high frequency commuter / shopper service ?
I think that if you were looking at providing a heavy rail service to match twenty first century demand in Leeds/ West Yorkshire then youd have to look at the J27 retail park and White Rose Centre. Both see thousands of cars a day thats where people are travelling to these days.
Park and Ride off the Castleford line, near the M1/ M621 junction?
Thorpe Park?
Trouble is, these kind of threads tend to fixate on what historic route can we re-open rather than what modern demand can we tailor services to meet.
So Yorkshire threads end up being nostalgic ones about Ripon or SELRAP instead of looking at
actual problems.
