National Power lines have come into contact with OLE - Berwick (13/10)
londonmidland
22 Dec 2009
Leicester
It appears the National Power lines have come into contact with the overhead line equipment (OLE) at Berwick-Upon-Tweed, as a result of ‘falling down’, causing severe disruption on the ECML.
Besides the weight of the cables themselves, what damage/what happens when two live power lines come into contact with each other?
pdeaves
14 Sep 2014
Gateway to the South West
If they happen to be different phases, there would be a massive short circuit. If the National Power lines are at a different (higher) voltage to the OLE then there would also be electrical damage.
800001
24 Oct 2015
11000 volts in the Nation Grid Wires that fell, the catenary and contact wires are damaged on both up and down lines, there is significant damage with the line closed for the remainder of the day.
hwl
5 Feb 2012
Usually there is some signalling equipment damage too when power line comes down.
In this case the DNO equipment is more likely to have been fried than NR's.
Bang, flash, nasty mess? Possibly damaged substations etc?
Hope the diesels on those 80xs are working! :)
Seemingly no clever diversions today, nothing going north of Newcastle.
It's buses or use the WCML.
ECML services already badly disrupted by earlier trespass around Stevenage.
malc-c
1 Dec 2017
Sadly it was a fatality at Stevenage
A person has sadly died after being 'struck by a train' this morning in Hertfordshire, with a number of services cancelled.
Emergency services have been dealing with an incident at Stevenage railway station since 11am today (Tuesday, October 13).
The London North Eastern Railway service between Kings Cross and Peterborough has been temporarily suspended after police found a casualty on the tracks.
https://www.hertfordshiremercury.co...live-great-northern-updates-stevenage-4601649
Local distribution network stuff. 11000 volts is way below National Grid‘s area of responsibility.
Whistler40145
30 Apr 2010
Lancashire
As a matter of interest, where is the ECML OHLE fed from in the Berwick upon Tweed area and which voltage National Grid supply is used?
Philip Phlopp
31 May 2015
I presume that failure was electrically induced rather than mechanical?
I'd guess both - electrically induced partial failure at the immediate point and time of contact, pretty much immediately followed by a tension induced mechanical separation of the cable.
hwl
5 Feb 2012
That's one of my lifelong questions answered; what happens when Network Rail and National Grid get too close for comfort...
Second time this month the previous one involved DNO cables falling in 3rd rail land - just the signalling (track circuit) fried then.
59CosG95
18 Aug 2013
Between Newcastle & Ashington
(area) Distribution Network Operator. These are the successors to the regional electricity companies.
Indeed so. A map of the DNOs is included below:
National Grid, meanwhile, is England & Wales' TNO (Transmission Network Operator), and have higher voltages to reduce heat losses (275kV/400kV); heat losses are caused by higher currents.
Just for completeness...
Ohm's law states V (voltage) = I (current) * R (resistance). Rearranging that gives you: I = V/R - meaning that, for a given value of R, as V gets larger I gets smaller.
Which is why the National Grid operates at hundreds of kV since the resistance in hundreds of miles of transmission cable is quite significant. It's also why we use 25kV for OHLE, it's a nice compromise between reducing losses and having reasonable safety margins for avoiding shock risks.
Isn’t there a feeder at Marshall Meadows, right around the border?
Getting slightly off topic here, but yes there is, the railway end of the feeder is at Marshall Meadows, IIRC it comes from the grid supply over to the South West near Eccles. It’s one of the weaker supplies on the ECML which is why it’s being strengthened as part of the ongoing power upgrade - as is discussed in a thread in the infrastructure forum.
Looking at Google Streetview there are fairly simple wooden posts leading away from the site in the SW direction, I think that’ll be 132kV? Or see later it’s probably 33kV. They seem to head for the Berwick area substation near Low Cocklaws, then there’s a bigger overhead line to the Eccles Grid site.
Looking at Google Streetview there are fairly simple wooden posts leading away from the site in the SW direction, I think that’ll be 132kV? They seem to head for the Berwick area substation near Low Cocklaws, then there’s a bigger overhead line to the Eccles Grid site.
The Eccles in question being about 10 miles SW of Berwick I presume, unless the Great Extension Lead in Manchester has just got a lot greater.
Posted above that it was just 11kV - I think 132kV would be on pylons not wooden poles.
Just found a useful mapping resource, “openinframap”. They reckon it’s 33kV supply to Marshall Meadows, I’ll amend my earlier post. Just to clarify, we’d “thread drifted” onto the supply to Marshall Meadows, AIUI not relevant to the local distribution cables where the fault occurred.
Edinburgh2000
28 Apr 2017
Not quite! For a fixed resistance, as V gets larger, I gets larger too.
I think what you meant is that for a fixed power, the current is less and so the losses are less. Power= V*I so, if V is greater then, for the same power, I is less. The (resistive) losses are I^2 * R, so increase with the square of the current. (With alternating current the impedance is not just the resistance, but that's another matter!)
