National Rail website
xc170
9 Feb 2008
Sorry if I'm posting in the wrong section, wasn't too sure where it would fit.
Anyone else getting this problem with the National Rail website on an almost daily basis?
Adam
kieron
22 Mar 2012
Connah's Quay
Adam
That's a "404 response" page. It tells me that you selected a URL where the site (the bit before the first /) refers to a nationalrail.co.uk server, but the whole thing doesn't refer to a specific page the server can send you.
The style of page they used gives no indication of what address it failed to find, or whether you visited it from a link on another page, or by typing it in.
If you want to know if someone else has experienced something similar to what you experienced, I'm afraid you'll have to tell us what that was yourself.
tsr
15 Nov 2011
Between the parallel lines
I get loads of errors when using NRE, including errors with codes "04" and "06" for no apparent reason, just when I load up such things as LDBs or perfectly routine Journey Planner queries. I've tried multiple devices with various browsers, various internet connections, cleared caches and so on, with no luck in getting some stuff to work reliably. As a result I basically no longer use the site unless there is absolutely no alternative whatsoever. With the advent of sites such as RTT, BRFares, Sussex Trains and so on, there often is!
