Some more updates were published on Wednesday, ones which include a fairly radical change to the LE map.
New data set RJRG0458 published 19 April 2017
Comparing RJRG0458 to RJRG0457
To add permiited routes via Leeds for journeys between the Guide Bridge and (G53) Hellifield Group Routeing points.
HELLIFIELD GROUP (G53) and Guide Bridge (GUI) - added sequence 'GY+YT+MB'
There are now some mapped routes which go via Leeds and double back between Guide Bridge and Manchester Picadilly.
As this map combination is much less flexible than Hellifield-Manchester's WY+MN, this isn't valid via Manchester Victoria, and so going from Hellifield Group to Guide Bridge using these maps involves the above double back (there is one train a week which goes from Guide Bridge to Stalybridge which would avoid it, but nothing in the direction listed above).
There are some easements (300433, 700332 and 700333) which allow you to do this if travelling to some of the stations for which Guide Bridge would be a valid routeing point. The versions of these easements on journey planners appear to be more generous than the one published in the routeing guide.
As such, this does come somewhere near to providing permitted routes between the Hellifield Group and Guide Bridge routeing points via Leeds.
Review of Duplicate maps - Maps changed as part of a process to simplify and to reduce the number of maps in use. resulting in the removal and replacement of map sequences
MAP SU - ROUTES VIA SURBITON TO LONDON TERMINALS. Added a direct link between SUR (Surbiton) and WOK (Woking) routeing points that allows journey planners permit train services that are not reported travel to or through the members of the (G82) Weybridge Group routeing point.
This change hasn't been included in the published maps. There are 13 maps in total which include the Surbiton-Woking section, so there may still be occasions where journey planners are unable to identify a valid route via Weybridge.
Map LE - LONDON TO PENZANCE VIA SALISBURY changed removed links via Peckham Rye,Twickenham, Feltham, Ash Vale and Taunton
In addition to this, it removes the routes the map had had via Tulse Hill and the one to Weymouth. It leaves a link behind between Yeovil and Thornford for some reason. This means that the map goes from containing a few routes between London and Farnborough Main to only containing one. Meanwhile, the map has gained a link between Yeovil and Castle Cary.
This affects a number of routes. For example, Leicester-Salisbury no longer has mapped routes via Southampton or via Streatham. It now has mapped routes via Ascot, and via Newbury.
Map WE - LONDON TO THE WEST OF ENGLAND changed removed links Didcot to Reading, (G33) Weymouth Group to (CLC) Castle Cary (via Yeovil)
It's lost the Didcot-Reading section and most of the Castle Cary-Weymouth one, but (as with LE) it retains Yeovil-Thornford.
The loss of Didcot has little or no effect, as every map which contains Didcot contains Didcot-Reading anyway. The loss of Weymouth means, for instance, that Exeter-Southampton no longer has mapped routes via Weymouth.
New sequences following map changes
Ash Vale (AHV) and Basingstoke (BSK) - added sequence 'SW'
Ash Vale (AHV) and Basingstoke (BSK) - removed sequence 'LE'
Ash Vale (AHV) and Salisbury (SAL) - added sequence 'SW+LE'
Ash Vale (AHV) and Salisbury (SAL) - removed sequence 'LE'
Ash Vale (AHV) and Taunton (TAU) - added sequence 'SW+LE+EU'
Ash Vale (AHV) and Taunton (TAU) - removed sequence 'LE'
Didcot Parkway (DID) and EXETER GROUP (G12) - added sequence 'XS+WE'
Didcot Parkway (DID) and EXETER GROUP (G12) - removed sequence 'WE'
Didcot Parkway (DID) and Liskeard (LSK) - added sequence 'BL+WE'
Didcot Parkway (DID) and Liskeard (LSK) - removed sequence 'WE'
Didcot Parkway (DID) and Newton Abbot (NTA) - added sequence 'BL+WE'
Didcot Parkway (DID) and Newton Abbot (NTA) - removed sequence 'WE'
Didcot Parkway (DID) and Par (PAR) - added sequence 'BL+WE'
Didcot Parkway (DID) and Par (PAR) - removed sequence 'WE'
Didcot Parkway (DID) and PENZANCE GROUP (G79) - added sequence 'BL+WE'
Didcot Parkway (DID) and PENZANCE GROUP (G79) - removed sequence 'WE'
Didcot Parkway (DID) and PLYMOUTH GROUP (G21) - added sequence 'BL+WE'
Didcot Parkway (DID) and PLYMOUTH GROUP (G21) - removed sequence 'WE'
Didcot Parkway (DID) and Taunton (TAU) - added sequence 'BL+WE'
Didcot Parkway (DID) and Taunton (TAU) - removed sequence 'WE'
Didcot Parkway (DID) and Truro (TRU) - added sequence 'BL+WE'
Didcot Parkway (DID) and Truro (TRU) - removed sequence 'WE'
Feltham (FEL) and Salisbury (SAL) - added sequence 'BU'
Feltham (FEL) and Salisbury (SAL) - added sequence 'TW+LE'
Feltham (FEL) and Salisbury (SAL) - removed sequence 'LE'
LONDON GROUP (G01) and WEYMOUTH GROUP (G33) - added sequence 'WE+WO'
LONDON GROUP (G01) and WEYMOUTH GROUP (G33) - removed sequence 'WE'
LONDON GROUP (G01) and Woking (WOK) - added sequence 'LE'
LONDON GROUP (G01) and Woking (WOK) - added sequence 'SU'
LONDON GROUP (G01) and Woking (WOK) - removed sequence 'SU+WU'
LONDON GROUP (G01) and Woking (WOK) - removed sequence 'WV+WX'
LONDON GROUP (G01) and Woking (WOK) - removed sequence 'WX'
READING GROUP (G24) and WEYMOUTH GROUP (G33) - added sequence 'WE+CE'
READING GROUP (G24) and WEYMOUTH GROUP (G33) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and BANBURY GROUP (G58) - added sequence 'WO+WE+SM'
WEYMOUTH GROUP (G33) and BANBURY GROUP (G58) - removed sequence 'WE+SM'
WEYMOUTH GROUP (G33) and EALING BROADWAY GROUP (G77) - added sequence 'WO+WE'
WEYMOUTH GROUP (G33) and EALING BROADWAY GROUP (G77) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and HAYES & HARLNGTN GP (G75) - added sequence 'WO+WE'
WEYMOUTH GROUP (G33) and HAYES & HARLNGTN GP (G75) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Maidenhead (MAI) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Maidenhead (MAI) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Oxford (OXF) - added sequence 'CE+WE+SM'
WEYMOUTH GROUP (G33) and Oxford (OXF) - removed sequence 'WE+SM'
WEYMOUTH GROUP (G33) and Slough (SLO) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Slough (SLO) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Twyford (TWY) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Twyford (TWY) - removed sequence 'WE'
No effect. In most cases, the change was a consequence of changes to the underlying maps. Although I do wonder about why XS+WE was chosen in some cases, and BL+WE in others (in each case, the first map is only used for Didcot-Reading).
Ash Vale (AHV) and EXETER GROUP (G12) - added sequence 'SW+LE'
Ash Vale (AHV) and EXETER GROUP (G12) - removed sequence 'LE'
Ash Vale (AHV) and Liskeard (LSK) - added sequence 'SW+LE'
Ash Vale (AHV) and Liskeard (LSK) - removed sequence 'LE'
Ash Vale (AHV) and Newton Abbot (NTA) - added sequence 'SW+LE'
Ash Vale (AHV) and Newton Abbot (NTA) - removed sequence 'LE'
Ash Vale (AHV) and Par (PAR) - added sequence 'SW+LE'
Ash Vale (AHV) and Par (PAR) - removed sequence 'LE'
Ash Vale (AHV) and PENZANCE GROUP (G79) - added sequence 'SW+LE'
Ash Vale (AHV) and PENZANCE GROUP (G79) - removed sequence 'LE'
Ash Vale (AHV) and PLYMOUTH GROUP (G21) - added sequence 'SW+LE'
Ash Vale (AHV) and PLYMOUTH GROUP (G21) - removed sequence 'LE'
Ash Vale (AHV) and Truro (TRU) - added sequence 'SW+LE'
Ash Vale (AHV) and Truro (TRU) - removed sequence 'LE'
These journeys no longer have mapped routes:
via Streatham and Honiton;
via Barnes, London, back to Barnes and then Honiton;
via Guildford, London, Barnes and Honiton; or
via Virginia Water, then Chertsey, and then Honiton.
Ashford International. (AFK) and EXETER GROUP (G12) - added sequence 'CW+EU'
Ashford International. (AFK) and EXETER GROUP (G12) - removed sequence 'CW+LE'
Ashford International. (AFK) and Liskeard (LSK) - added sequence 'CW+EU'
Ashford International. (AFK) and Liskeard (LSK) - removed sequence 'CW+LE'
Ashford International. (AFK) and Newton Abbot (NTA) - added sequence 'CW+EU'
Ashford International. (AFK) and Newton Abbot (NTA) - removed sequence 'CW+LE'
Ashford International. (AFK) and Par (PAR) - added sequence 'CW+EU'
Ashford International. (AFK) and Par (PAR) - removed sequence 'CW+LE'
Ashford International. (AFK) and PENZANCE GROUP (G79) - added sequence 'CW+EU'
Ashford International. (AFK) and PENZANCE GROUP (G79) - removed sequence 'CW+LE'
Ashford International. (AFK) and PLYMOUTH GROUP (G21) - added sequence 'CW+EU'
Ashford International. (AFK) and PLYMOUTH GROUP (G21) - removed sequence 'CW+LE'
Ashford International. (AFK) and Taunton (TAU) - added sequence 'TN+LE+EU'
Ashford International. (AFK) and Taunton (TAU) - removed sequence 'CW+LE'
Ashford International. (AFK) and Taunton (TAU) - removed sequence 'TN+LE'
Ashford International. (AFK) and Truro (TRU) - added sequence 'CW+EU'
Ashford International. (AFK) and Truro (TRU) - removed sequence 'CW+LE'
via Barnes and Honiton;
via Tooting and Honiton;
via North Dulwich and Honiton; or
via Croydon, Elephant & Castle and Honiton.
Barnes (BNS) and Salisbury (SAL) - added sequence 'EU'
Barnes (BNS) and Salisbury (SAL) - added sequence 'WX+LE'
Barnes (BNS) and Salisbury (SAL) - removed sequence 'LE'
Hounslow (HOU) and Salisbury (SAL) - added sequence 'EU'
Hounslow (HOU) and Salisbury (SAL) - added sequence 'TW+LE'
Hounslow (HOU) and Salisbury (SAL) - removed sequence 'LE'
LONDON GROUP (G01) and Salisbury (SAL) - added sequence 'WX+BU+LE'
LONDON GROUP (G01) and Salisbury (SAL) - added sequence 'WX+PZ'
Motspur Park (MOT) and Salisbury (SAL) - removed sequence 'LE'
These journeys now have mapped routes via Wokingham.
Barnes (BNS) and Taunton (TAU) - added sequence 'WX+EU'
Barnes (BNS) and Taunton (TAU) - removed sequence 'WX+LE'
Clapham Junction (CLJ) and Taunton (TAU) - added sequence 'LE+EU'
Clapham Junction (CLJ) and Taunton (TAU) - removed sequence 'LE'
These journeys no longer have mapped routes via London and Exeter.
Basingstoke (BSK) and Feltham (FEL) - added sequence 'EU'
Basingstoke (BSK) and Feltham (FEL) - added sequence 'LE+WX'
Basingstoke (BSK) and Feltham (FEL) - removed sequence 'LE'
This journey no longer has mapped routes:
via Streatham; or
via Chertsey and London.
Basingstoke (BSK) and LONDON GROUP (G01) - added sequence 'BU+WX'
Basingstoke (BSK) and LONDON GROUP (G01) - removed sequence 'XR+RG'
This journey no longer has mapped routes via Streatham.
Basingstoke (BSK) and Nunhead (NHD) - added sequence 'EU'
Basingstoke (BSK) and Nunhead (NHD) - added sequence 'LE+PK+EU'
Basingstoke (BSK) and Nunhead (NHD) - removed sequence 'LE'
via Herne Hill;
via Streatham and South Bermondsey; or
via Clapham Junction and Streatham.
It now has mapped routes via Clapham Junction and Clapham High Street which avoid London.
Basingstoke (BSK) and Peckham Rye (PMR) - added sequence 'EU'
Basingstoke (BSK) and Peckham Rye (PMR) - added sequence 'LE+PK'
Basingstoke (BSK) and Peckham Rye (PMR) - removed sequence 'LE'
Basingstoke (BSK) and Peckham Rye (PMR) - removed sequence 'LE+SC'
via Balham, Croydon, Peckham Rye, Herne Hill, Sutton or Sydenham.
Basingstoke (BSK) and Richmond London (RMD) - added sequence 'EU'
Basingstoke (BSK) and Richmond London (RMD) - added sequence 'LE+TW'
Basingstoke (BSK) and Richmond London (RMD) - removed sequence 'LE'
via Streatham;
or via Feltham and Wimbledon (in either order).
Basingstoke (BSK) and Taunton (TAU) - added sequence 'BB+WE'
Basingstoke (BSK) and Taunton (TAU) - added sequence 'LE+SS'
Basingstoke (BSK) and Taunton (TAU) - removed sequence 'XR+WE'
Basingstoke (BSK) and Taunton (TAU) - removed sequence 'XR+WR'
This journey no longer has mapped routes via Southampton.
It now has mapped routes via Salisbury.
The shortest route between Basingstoke and Taunton goes via Salisbury, but there are some new extra with the mapped route.
Basingstoke (BSK) and Twickenham (TWI) - added sequence 'EU'
Basingstoke (BSK) and Twickenham (TWI) - added sequence 'LE+TW'
Basingstoke (BSK) and Twickenham (TWI) - removed sequence 'LE'
via Streatham; or
via Wimbledon and Hounslow.
Brockenhurst (BCU) and Taunton (TAU) - added sequence 'CW+EU'
Brockenhurst (BCU) and Taunton (TAU) - removed sequence 'XR+LE'
via Basingstoke and Exeter; or
via Yeovil and Castle Cary.
BROMLEY SOUTH GROUP (G06) and Taunton (TAU) - added sequence 'FC+WC+WE'
BROMLEY SOUTH GROUP (G06) and Taunton (TAU) - removed sequence 'FA+LE'
BROMLEY SOUTH GROUP (G06) and Taunton (TAU) - removed sequence 'FC+LE'
CHATHAM GROUP (G07) and Taunton (TAU) - added sequence 'FC+WC+WE'
CHATHAM GROUP (G07) and Taunton (TAU) - removed sequence 'FA+LE'
CHATHAM GROUP (G07) and Taunton (TAU) - removed sequence 'FC+LE'
These journeys no longer have mapped routes via Exeter.
They now have mapped routes:
via Wimbledon and Slough;
via Streatham, Tulse Hill and Reading;
via Weybridge and Westbury except via London;
via Streatham, then Tulse Hill, then Clapham Junction, then Wimbledon, then Westbury;
via Streatham, then Elephant & Castle, then London, then Staines, then Westbury; and
via Streatham, then Peckham Rye, then London, then Staines, then Westbury.
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - added sequence 'BL+PZ'
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - added sequence 'BL+PZ+SN'
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - added sequence 'BL+WE+CE'
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - added sequence 'BL+WE+SN'
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - added sequence 'BL+WE+SN+PZ'
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - added sequence 'RP'
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - removed sequence 'RB'
Didcot Parkway (DID) and WEYMOUTH GROUP (G33) - removed sequence 'WE'
This journey no longer has mapped routes via Winchester.
EASTBOURNE GROUP (G84) and Taunton (TAU) - added sequence 'LB+LE+EU'
EASTBOURNE GROUP (G84) and Taunton (TAU) - removed sequence 'LB+LE'
via Chertsey and Exeter;
via London and Chertsey;
via London and Tooting;
via London and Dorchester; or
via Tooting and Exeter.
Eastleigh (ESL) and Taunton (TAU) - added sequence 'WU+WD+WE'
Eastleigh (ESL) and Taunton (TAU) - removed sequence 'SN+PB'
Eastleigh (ESL) and Taunton (TAU) - removed sequence 'XR+LE'
via Salisbury and Bristol;
via Dorchester and Exeter; or
via Basingstoke and Salisbury.
EXETER GROUP (G12) and WEYMOUTH GROUP (G33) - added sequence 'EU'
EXETER GROUP (G12) and WEYMOUTH GROUP (G33) - added sequence 'WE+CE'
EXETER GROUP (G12) and WEYMOUTH GROUP (G33) - removed sequence 'LE'
EXETER GROUP (G12) and WEYMOUTH GROUP (G33) - removed sequence 'SS'
EXETER GROUP (G12) and WEYMOUTH GROUP (G33) - removed sequence 'WE'
PLYMOUTH GROUP (G21) and WEYMOUTH GROUP (G33) - added sequence 'EU'
PLYMOUTH GROUP (G21) and WEYMOUTH GROUP (G33) - added sequence 'WE+CE'
PLYMOUTH GROUP (G21) and WEYMOUTH GROUP (G33) - removed sequence 'LE'
PLYMOUTH GROUP (G21) and WEYMOUTH GROUP (G33) - removed sequence 'SS'
PLYMOUTH GROUP (G21) and WEYMOUTH GROUP (G33) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Liskeard (LSK) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Liskeard (LSK) - added sequence 'EU'
WEYMOUTH GROUP (G33) and Liskeard (LSK) - removed sequence 'LE'
WEYMOUTH GROUP (G33) and Liskeard (LSK) - removed sequence 'SS'
WEYMOUTH GROUP (G33) and Liskeard (LSK) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Newton Abbot (NTA) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Newton Abbot (NTA) - added sequence 'EU'
WEYMOUTH GROUP (G33) and Newton Abbot (NTA) - removed sequence 'LE'
WEYMOUTH GROUP (G33) and Newton Abbot (NTA) - removed sequence 'SS'
WEYMOUTH GROUP (G33) and Newton Abbot (NTA) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Par (PAR) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Par (PAR) - added sequence 'EU'
WEYMOUTH GROUP (G33) and Par (PAR) - removed sequence 'LE'
WEYMOUTH GROUP (G33) and Par (PAR) - removed sequence 'SS'
WEYMOUTH GROUP (G33) and Par (PAR) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and PENZANCE GROUP (G79) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and PENZANCE GROUP (G79) - added sequence 'EU'
WEYMOUTH GROUP (G33) and PENZANCE GROUP (G79) - removed sequence 'LE'
WEYMOUTH GROUP (G33) and PENZANCE GROUP (G79) - removed sequence 'SS'
WEYMOUTH GROUP (G33) and PENZANCE GROUP (G79) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Taunton (TAU) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Taunton (TAU) - added sequence 'EU'
WEYMOUTH GROUP (G33) and Taunton (TAU) - removed sequence 'LE'
WEYMOUTH GROUP (G33) and Taunton (TAU) - removed sequence 'SS'
WEYMOUTH GROUP (G33) and Taunton (TAU) - removed sequence 'WE'
WEYMOUTH GROUP (G33) and Truro (TRU) - added sequence 'CE+WE'
WEYMOUTH GROUP (G33) and Truro (TRU) - added sequence 'EU'
WEYMOUTH GROUP (G33) and Truro (TRU) - removed sequence 'LE'
WEYMOUTH GROUP (G33) and Truro (TRU) - removed sequence 'SS'
WEYMOUTH GROUP (G33) and Truro (TRU) - removed sequence 'WE'
These journeys no longer have mapped routes via Salisbury.
Gatwick Airport (GTW) and Taunton (TAU) - added sequence 'LB+LE+EU'
Gatwick Airport (GTW) and Taunton (TAU) - removed sequence 'LB+LE'
REDHILL GROUP (G60) and Taunton (TAU) - added sequence 'LB+LE+EU'
REDHILL GROUP (G60) and Taunton (TAU) - removed sequence 'LB+LE'
Taunton (TAU) and Three Bridges (TBD) - added sequence 'EU+LE+LB'
Taunton (TAU) and Three Bridges (TBD) - removed sequence 'LE+LB'
via Chertsey and Exeter; or
Guildford (GLD) and Taunton (TAU) - added sequence 'WX+LE+EU'
Guildford (GLD) and Taunton (TAU) - removed sequence 'PD+LE'
This journey no longer has mapped routes via Effingham Junction and Yeovil.
Havant (HAV) and Taunton (TAU) - added sequence 'CW+CE+WE'
Havant (HAV) and Taunton (TAU) - added sequence 'CW+EU'
Havant (HAV) and Taunton (TAU) - removed sequence 'RB+LE'
Havant (HAV) and Taunton (TAU) - removed sequence 'RB+WE'
This journey no longer has mapped routes via Mortimer.
It now has mapped routes via Dorchester which do not go through Basingstoke.
Haywards Heath (HHE) and Taunton (TAU) - added sequence 'LB+LE+EU'
Haywards Heath (HHE) and Taunton (TAU) - removed sequence 'LB+LE'
Taunton (TAU) and Wivelsfield (WVF) - added sequence 'EU+LE+LB'
Taunton (TAU) and Wivelsfield (WVF) - removed sequence 'LE+LB'
via Dorchester;
Hounslow (HOU) and Taunton (TAU) - added sequence 'EU'
Hounslow (HOU) and Taunton (TAU) - added sequence 'TW+LE+EU'
Hounslow (HOU) and Taunton (TAU) - removed sequence 'WX+LE'
via London and Exeter; or
via Feltham and Raynes Park.
Leatherhead (LHD) and Taunton (TAU) - added sequence 'DK+EU'
Leatherhead (LHD) and Taunton (TAU) - added sequence 'HR+LE+EU'
Leatherhead (LHD) and Taunton (TAU) - removed sequence 'DK+LE'
Leatherhead (LHD) and Taunton (TAU) - removed sequence 'HR+LE'
via Ash Vale;
via Dochester;
via Feltham and Exeter;
via South Bermondsey and Exeter; or
ORPINGTON GROUP (G85) and Taunton (TAU) - added sequence 'FA+LE+EU'
ORPINGTON GROUP (G85) and Taunton (TAU) - added sequence 'FC+LE+EU'
ORPINGTON GROUP (G85) and Taunton (TAU) - removed sequence 'FA+LE'
ORPINGTON GROUP (G85) and Taunton (TAU) - removed sequence 'FC+LE'
OTFORD GROUP (G83) and Taunton (TAU) - added sequence 'FA+LE+EU'
OTFORD GROUP (G83) and Taunton (TAU) - added sequence 'FC+LE+EU'
OTFORD GROUP (G83) and Taunton (TAU) - removed sequence 'FA+LE'
OTFORD GROUP (G83) and Taunton (TAU) - removed sequence 'FC+LE'
Shortlands (SRT) and Taunton (TAU) - added sequence 'FA+LE+EU'
Shortlands (SRT) and Taunton (TAU) - added sequence 'FC+LE+EU'
Shortlands (SRT) and Taunton (TAU) - removed sequence 'FA+LE'
Shortlands (SRT) and Taunton (TAU) - removed sequence 'FC+LE'
Strood Kent (SOO) and Taunton (TAU) - added sequence 'FA+LE+EU'
Strood Kent (SOO) and Taunton (TAU) - added sequence 'FC+LE+EU'
Strood Kent (SOO) and Taunton (TAU) - removed sequence 'FA+LE'
Strood Kent (SOO) and Taunton (TAU) - removed sequence 'FC+LE'
Swanley (SAY) and Taunton (TAU) - added sequence 'FA+LE+EU'
Swanley (SAY) and Taunton (TAU) - added sequence 'FC+LE+EU'
Swanley (SAY) and Taunton (TAU) - removed sequence 'FA+LE'
Swanley (SAY) and Taunton (TAU) - removed sequence 'FC+LE'
via Barnes and Exeter;
via Tooting and Exeter;
via Tulse Hill and Exeter; or
via South Bermondsey and Exeter.
RAMSGATE GROUP (G68) and Taunton (TAU) - added sequence 'DE+LE+EU'
RAMSGATE GROUP (G68) and Taunton (TAU) - added sequence 'FA+LE+EU'
RAMSGATE GROUP (G68) and Taunton (TAU) - added sequence 'FC+LE+EU'
RAMSGATE GROUP (G68) and Taunton (TAU) - added sequence 'RA+LE+EU'
RAMSGATE GROUP (G68) and Taunton (TAU) - removed sequence 'DE+LE'
RAMSGATE GROUP (G68) and Taunton (TAU) - removed sequence 'FA+LE'
RAMSGATE GROUP (G68) and Taunton (TAU) - removed sequence 'FC+LE'
RAMSGATE GROUP (G68) and Taunton (TAU) - removed sequence 'RA+LE'
via Chatham, South Bermondsey and Exeter; or
via Maidstone East, South Bermondsey and Exeter.
Salisbury (SAL) and Taunton (TAU) - added sequence 'EU'
Salisbury (SAL) and Taunton (TAU) - added sequence 'LE+SS'
Salisbury (SAL) and Taunton (TAU) - added sequence 'WO+WE'
Salisbury (SAL) and Taunton (TAU) - removed sequence 'LE'
Salisbury (SAL) and Taunton (TAU) - removed sequence 'SN+PB'
Salisbury (SAL) and Taunton (TAU) - removed sequence 'SS'
This journey now has mapped routes via Yeovil Pen Mill.
SOUTHAMPTON GROUP (G26) and Taunton (TAU) - added sequence 'XR+WD+WE'
SOUTHAMPTON GROUP (G26) and Taunton (TAU) - removed sequence 'XR+LE'
This journey no longer has mapped routes via Dorchester and Exeter.
Taunton (TAU) and Tonbridge (TON) - added sequence 'EU+LE+RA'
Taunton (TAU) and Tonbridge (TON) - added sequence 'EU+LE+TN'
Taunton (TAU) and Tonbridge (TON) - added sequence 'EU+LE+VH'
Taunton (TAU) and Tonbridge (TON) - removed sequence 'LE+RA'
Taunton (TAU) and Tonbridge (TON) - removed sequence 'LE+TN'
Taunton (TAU) and Tonbridge (TON) - removed sequence 'LE+VH'
via Tooting and Exeter; or
via Tulse Hill and Exeter.
Taunton (TAU) and Woking (WOK) - added sequence 'EU'
Taunton (TAU) and Woking (WOK) - added sequence 'WE+SN+LE'
Taunton (TAU) and Woking (WOK) - removed sequence 'LE'
This journey now has mapped routes via Castle Cary which avoid London.
Replaced Sequences
Basingstoke (BSK) and Motspur Park (MOT) - removed sequence 'LE'
This journey no longer has mapped routes via Barnes.
Dover Priory (DVP) and Taunton (TAU) - removed sequence 'DE+LE'
Dover Priory (DVP) and Taunton (TAU) - removed sequence 'FA+LE'
Dover Priory (DVP) and Taunton (TAU) - removed sequence 'FC+LE'
Dover Priory (DVP) and Taunton (TAU) - removed sequence 'RA+LE'
Faversham (FAV) and Taunton (TAU) - removed sequence 'FA+LE'
Faversham (FAV) and Taunton (TAU) - removed sequence 'FC+LE'
Dover Priory (DVP) and Truro (TRU) - removed sequence 'DE+LE'
Dover Priory (DVP) and Truro (TRU) - removed sequence 'FA+LE'
via Nunhead, Tulse Hill and Honiton;
via Streatham, Tulse Hill and Honiton;
via Maidstone East, Grove Park, Clapham High Street and Honiton; or
via Clapham High Street and Honiton, except ones via Sevenoaks or London.
Effingham Junction (EFF) and Taunton (TAU) - removed sequence 'DK+LE'
Effingham Junction (EFF) and Taunton (TAU) - removed sequence 'EF+LE'
Effingham Junction (EFF) and Taunton (TAU) - removed sequence 'HR+LE'
Epsom (EPS) and Taunton (TAU) - removed sequence 'DK+LE'
Epsom (EPS) and Taunton (TAU) - removed sequence 'HR+LE'
via Dorchester; or
via Exeter.
EXETER GROUP (G12) and Richmond London (RMD) - removed sequence 'LE'
via Chertsey and Honiton; or
via Streatham and Honiton.
LONDON GROUP (G01) and WEYBRIDGE GROUP (G82) - removed sequence 'LE'
This journey no longer has mapped routes via Clapham Junction and Streatham.
PORTSMOUTH GROUP (G23) and Taunton (TAU) - removed sequence 'RB+LE'
via Dorchester;
or via Basingstoke and Salisbury.
3 map(s) changed
Map LE - LONDON TO PENZANCE VIA SALISBURY changed (1 added/ 23 removed links)
Map SU - ROUTES VIA SURBITON TO LONDON TERMINALS changed (1 added/ 0 removed links)
Map WE - LONDON TO THE WEST OF ENGLAND changed (0 added/ 4 removed links)
As described above.
As there are 2108 routes which use LE or WE (not all of which use the altered sections, of course) and the permitted routes between London and Basingstoke, Salisbury and Weybridge have been changed, there are a lot of changes to mapped routes which I have not described above.
Dated engineering easements removed
700699: Over the Easter weekend 14 to 17 April, services from Leeds to Edinburgh are routed via Castleford. This positive map easement will create temporary map permissions that will apply in both directions
700700: During the Easter period 14 to 17 April 2017, Trans Pennine Express services from Liverpool Lime Street, Liverpool South Parkway, Birchwood and Warrington Central to Edinburgh are diverted via the East Coast Mainline. Fares priced on fare route (00456) AP TPE & CONNECTIONS will be valid on services travelling via Berwick upon Tweed. This fare route easement will apply in both directions.
700702: Due to engineering works, trains from Manchester to West wales are diverted via Chester and Wrexham on the 11 and 12 March 2017. This map easement will create temporary map permissions to allow connecting services to be shown in journey planning systems. This easement will apply in both directions Easement changed add additional Route Code 00831 to electronic data VIA BATH - easement to expire 23 April 2017
The dates have all passed for these.
700689: During engineering works between 08 and 23 April 2017 which will affect journeys via Bath Spa. For journeys to from Weymouth, Upwey, Dorchest West,Maiden Newton, Chentnoler, Yetminster, Thornford, Yeovil Pen Mill, Castle Cary, Bruton, Frome,Westbury, Trowbridge, Bradford on Avon, Avoncliff, Freshford, Bath Spa, Melksham, Chippenham to Bristol and South Wales priced on tickets routed on (00700) NOT VIA LONDON, (00829) VIA YEOVIL and (00618) VIA SALISBURY will be permitted to travel via Swindon. This fare route easement applies in both directions.
There only seem to be buses scheduled through Bath this weekend, so I suspect removing this was a mistake. The couple of routes I tried in a journey planner still seem to be allowed, so they may not have implemented this change yet.
