Network rail data feeds
Has anyone tried playing around with NR data feeds? If so, do you have any code you can share to get the schedule data (including daily updates) into a database? It looks like quite the job between association records and schedule records so no point reinventing the wheel if there's anyone with shareable code.
trainmania100
8 Nov 2015
Newhaven
I have access to the data feeds but haven't had time to work out how to use it
Maybe I'll use php never used Ruby
I've managed to decode the movement data and encode them into a KML file, but that only lets me see what train is where. I'd need the schedule to figure out where it's going to/from.
Oh, yes, I've been using PHP. The examples here are a good place to start.
Have you been integrating it with HTML?
Yeah. I've a small server that I play around with. The script is running just now so you should be able to see Scotrail's trains here. A couple of things I've noticed, some locations don't have lat/long data so trains appear to materialise somewhere in the Gulf of Guinea(!) and without schedule data they don't always disappear when they reach their destinations.
It's very much just a proof of concept at this stage.
trainmania100
8 Nov 2015
Newhaven
It's looking great , i like how it uses the maps and shows the trust ID
Kristofferson
23 Nov 2012
I used the RTT API instead of the NR feed to build a personalised departure board with Angular & Bootstrap. Much easier to understand and does the job!
Sent from my iPhone using Tapatalk
I did consider the RTT API, but I doubt they'd appreciate a full download of the entire schedule daily! :)
If I can get the schedule data figured out, my next task is to show the calling points when you click on a train. It's completely a spare-time project but I'm in hotels for the next month or so - which means lots of spare time!
Peter Mugridge
8 Apr 2010
Epsom
Why is 2T73 currently showing in the Gulf of Guinea off Africa? Ah - I know... it's 156 478 gone for another swim... ;)
Sorry - couldn't resist it; I did see the actual reason above.
I got to the bottom of it - not the Atlantic! - there's 1800 or so locations in the TIPLOC file that don't exist in the list of geographic coordinates. I've managed to find a few of them (quite a few are on the Borders Railway), but it'll take a while to find them all since they have useful, meaningful and easily identifiable names like "PEAK FOREST CRIPPLE SIDING" "PLYMOUTH SURPLUS" and "COAL CONCENTRATION DEPOT".
HA25322
18 Aug 2014
The Moon
Now if only someone could get Trust to download as well so we knew what was allocated to the services. Maybe one day. I will keep my fingers crossed that it may happen. However good job so far.
Unfortunately, it isn't listed as an available feed. One can hope though. My plan for this week is to try and get to the bottom of the schedule feed, but I may need to spin up a new cloud compute instance as just one TOC's schedule looks too big for my poor little Raspberry Pi to handle. :eek:
HA25322
18 Aug 2014
The Moon
I didn't think it would be as it would be well known by now I would have thought. Shame though as it would make the hobby so much easier. :lol:
So, I've managed to get the basics of the schedule feeds worked out and into a database, but I've a couple of questions.
VSTP schedules - am I correct that they don't overwrite the permanent schedule so I don't need to delete anything from the database if/when I figure out how to read the VSTP feed (for some reason it's in a different format)?
Also, in the associations feed there seem to be a lot of almost duplicate records, does anyone have a simple explanation of how association records work? I have an idea in my head but want to see if I've got it right.
Thanks all.
And another one for anyone who has played around with this stuff...
I've loaded the main JSON formatted snapshot into a database and I've got double entries for some schedules - is this my code or does the data contain duplicated entries? There's a few tens of thousands of lines in the file so don't fancy going through it manually.
HA25322
18 Aug 2014
The Moon
You can have several items under the 1 headcode. It may be WTT, the STP & VSTP. And VAR. VAR would be a slight difference to the original WTT. Eg timing issue due to engineering works that week. Or a slight tweak due to pathing constraints. I don't envy you at all. But good luck and best wishes.
It was partially my code, truncated the databases and started again and most of the duplicates are gone.
gsnedders
6 Sep 2015
FWIW, I'd be more than interested if you threw up the code somewhere and made it available. Maybe even help. :)
You might not say that if you saw how I code! :) I'll see about setting up a repository somewhere when I get a chance.
I sent a list of missing locations off to NR few days ago, and they said they've requested a data update. Wonder how long it will take to get the file updated?
[RANT]Not surprised that NR has so many problems with maintaining their infrastructure, given that they don't know where it is! Pulling locations directly from the most recent planning data file and you get such oddities as Bounds Green being in Norway!!![/RANT]
In terms of train planning, it is pretty irrelevant to be fair. Anything that looks odd is probably just something that has been put in to fill a mandatory data field.
I know it is, that was just a rant. For planning purposes it is the network links that matter - I've not taken that close a look at them (well over a million records!) but there wasn't anything that jumped out as obviously wrong.
What's odd is that some of the geographic errors are *so* close to being right - take a look at any service passing through Dundee for example, the points are correct for longitude, but about 1.5km too far south.
greatkingrat
20 Jan 2011
It's not that odd, probably was just miskeyed during data entry, a difference of 0.01 degree in latitude would be about 1.5km.
Oh there are plenty that are wrong believe me and that leads to crap schedules that miss timing points or put those in that aren't required.
Hmm... I wonder if it's an Eastings/Northings to Longitude/Latitude rounding error - I did try a couple different ways to do the conversion but the results were the same, but they might all be using the same underlying algorithm.
RailAleFan
2 Jul 2014
Midlands
What do you have as Easting / Northing for Dundee? I took location data from NapTAN
https://data.gov.uk/dataset/naptan
Which for Dundee has;
Easting 340242
Northing 729793
...and converted to Lat / Lon as
Lat 56.45648450
Lon -2.97120452
...and seems to be pretty close...
http://live-departures.info/rail/station/Dundee/
From the data set:
Code:
| LocationName           | Easting | Northing | Longitude        | Latitude        |
| Dundee Central Jn      |  340699 |   727969 | -2.9619003219444 | 56.440270689776 |
| Dundee Central Jn C.E. |  340500 |   728320 | -2.9652076338357 | 56.443398958257 |
| Dundee H.S.            |  340900 |   728450 | -2.9587492784205 | 56.444617140695 |
| Dundee                 |  341262 |   728157 | -2.9528117904044 | 56.442030086038 |
| Dundee Head Shunt      |       0 |        0 |  -7.556448482059 | 49.766185796754 |
| Dundee West C.E.       |  340250 |   728320 | -2.9692624737147 | 56.443367359206 |
| Dundee West T.C.       |  341200 |   728450 | -2.9538832949216 |  56.44465463208 |
So there's definitely something dodgy about the source data.
Edit: Forgot to mention that the Eastings/Northings are from the data source, the Lat/Long is my conversion.
Another VSTP question - how do you get the TOC? The atoc_code field is blank?!
Cross referenced from the train service code. May not always work.
I shall have a look at this - I'm not in front my PC at the moment but from your comment I guess there's a pattern to be derived. Thanks.
