Network Rail selling 170 tonnes of unwanted electrfication masts
Cletus
11 Dec 2010
Dover
Moderator note: split from https://www.railforums.co.uk/threads/windermere-line-electrification-progress.191705/
Only a couple of hundred more supports needed and someone can start hanging wires from them.
How about these? :smile:
https://twitter.com/philatrail/status/1169280188930281472
EDoeHx0XYAAHsrk
Seems that Network Rail has no need for these electrification masts and booms. It’s selling by tender 170 tonnes of them from Newport.
Trouble is you don't want any more of that gigantic GW Series 1 kit installed anywhere else.
Windermere isn't going to host 140mph multiple-pantograph trains anytime soon.
The same low-profile kit as used at Oxenholme for the northern WCML in 1974 will do fine, or that used on the Paisley Canal branch in Scotland.
59CosG95
18 Aug 2013
Between Peterborough & Bedlington
UK Master Series would be my likely bet - that covers the best of Series 1 & Series 2 (mainly S2) along with various Mk3, UK1 (from WCRM), GEFF (Great Eastern Furrer+Frey) and SICAT (Siemens Catenary; as used on the Larkhall branch) assemblies.
Most structures on the WCML were 152x152 UC steel sections, now largely out of favour for higher speeds and higher, independent tensioning arrangements (12kN/15kN for modern equipment); the UKMS range certainly doesn't specify them as standard sections anymore.
203x203 UC sections are now the smallest sections, and are used on most single track structures. I believe they'll most likely form the majority of structures on the Lakes Line if it *officially* goes ahead. With its lower speed, I wouldn't be surprised if they go for a lower tension value in the C&C too (11kN in each).
Meerkat
14 Jul 2018
Looking at the GWML 170 tonnes is probably only a handful of gantries!
Crisps
19 May 2019
Just a thought, (I’m no expert on these matters so I could be talking rubbish) but why not keep them and use them to shore up some of the more unreliable sections of the ECML...
The cursed Grayling seems to be able to melt steel to destroy it
These bits and bobs should be around to complete the electrification.
Cursed be his name.
Peter Mugridge
8 Apr 2010
Epsom
How much does anyone want to bet that as soon as they've sold all of this off and it has gone, the Cardiff to Swansea bit will get re-approved...?
Mag_seven
1 Sep 2014
here to eternity
What about Chippenham-Bath-Bristol-Filton? They are still potentially going ahead aren't they (unless NR know something we don't)
Meerkat
14 Jul 2018
This is the massive stuff though. Be better to use less hideous stuff on any future electronification
quantinghome
1 Jun 2013
Reminds me of a story I heard from around the time of rail privatisation. Railtrack sold off a load of bespoke geometry switches and crossings thinking it didn't need the stock, only to have to buy it back at several times the sale price to complete a track renewal scheme. Someone made a lot of money from it.
Peter C
13 Oct 2018
GWR land
Could these be used for something such as Didcot - Oxford?
I have no knowledge on the specifics of this.
-Peter
Clip
28 Jun 2010
Hold on, before everyone comes up with a plan to find these a home, does anyone know why they are selling them?
They may be deemed not suitable for use anymore
... and it’s still a lot less than the 1000 tonnes of scrap that was being discussed in early 2018. So it could also just be a bit more of the same, or a much more accurate figure than the original estimate.
Bit of a mountain out of a molehill I reckon...
