Network Rail Test Trains
Discussion in 'Traction & Rolling Stock' started by whhistle, 13 Jan 2020.
  1. whhistle
    whhistle On Moderation
    2,636
    30 Dec 2010
    So NR have a few sets, including 37 and 31.
    Do these locos have route availability that the HST doesn't?
    Just thinking whether any HSTs would be taken by them so they can get rid of their older locos.
    Rail Forums
  3. Murray J
    Murray J Member
    188
    10 Aug 2019
    Don't think so. The 31s were gotten rid of a few years ago and most 37s NR use now are colas, HNRC or DRS ones leased in to operate test trains, particularly UTUs (ones with a 37 on one end and a DBSO on the other). Doubt they'll take any more HSTs, 1 set is enough and it'd probably take a while to outfit another.
  4. 43096
    43096 Established Member
    6,295
    23 Nov 2015
    There is no reason why they couldn't use a power car in place of a 37 on the existing test trains, with the driving car at the other end converted to work with the power car.
  5. Murray J
    Murray J Member
    188
    10 Aug 2019
    Probably not, but why would they need to do that when what they've already got works perfectly?
  6. hooverboy
    hooverboy Member
    1,068
    12 Oct 2017
    in locomotive terms there was only class 20's that were more "go anywhere" than HST's.
    The 37's are about on par.
    the 31's are RA6 so less able.
    The restriction came with the carriages. MK2 sets had a bit more flexibility.
  7. 43096
    6,295
    23 Nov 2015
    More modern, higher speed (100mph testing vs 80/90mph with a 37), lower fuel consumption, common fleet etc etc
  8. hwl
    hwl Established Member
    5,033
    5 Feb 2012
    and less polluting...
  9. DarloRich
    DarloRich Veteran Member
    23,335
    Work - Fenny Stratford(MK) Home - Darlington
    great thread.
    or the class 97's
    does it? I wonder.
  10. Murray J
    Murray J Member
    188
    10 Aug 2019
    Like I said, most. Anyway, the 37s are fairly reliable, doesn't mean they won't fail from time to time.
  11. HSP 2
    HSP 2 On Moderation
    158
    4 Dec 2019
    12B
    What is the point of having a test train that will do 125 mph when the line it's working on is only "fit" for 60 mph.
    You may as well keep the old school second train.
    Unless you just want to see some more 43s still working?
  12. 43096
    6,295
    23 Nov 2015
    For the reasons given above.
  13. InOban
    InOban Established Member
    2,417
    12 Mar 2017
    The obvious advantage of an HST set is that they don't need to run the engine round at . a terminus. Indeed if it's a one engine in steam branch, I suppose they must send in a second 37 to retrieve the train.
  14. jopsuk
    jopsuk Veteran Member
    12,152
    13 May 2008
    They've got a few DBSOs set up that work with the 37s, or they just top and tail.
  15. hooverboy
    hooverboy Member
    1,068
    12 Oct 2017
    realistically for testing purposes you need both.
    low speed for scanning the track/bedding accoustically etc, and high speed for checking out it all fits properly, catenary can handle it etc.
  16. dosxuk
    dosxuk Member
    690
    2 Jan 2011
    Fast trains can slow down for low speed use like scanning, but slow trains can't speed up for high speed use like traveling to the location they're being used at.
  17. HSP 2
    HSP 2 On Moderation
    158
    4 Dec 2019
    12B
    if the slow speed test train is fitted for use with 31s or 37s maybe 20s as well the DVT is set up for that, so what would you do? Re wire all of the possible coaches that could be use on the slow train with a class 43. Or refit all of the gear into Mk3 HST coaches then you have to fit at least buck eye couplings to the stock and 43s (the test trains don't all run in fixed formations). Or you could use ex loco hauled Mk3 coaches just a full refit and the need of the wiring for the use of the 43s (I can't remember how the two loco talk to one another). Another down side is that Mk3 coaches are C3 restriction Mk1 & M2s are C1.
    So a lot of money could be spent for NO gain apart from two more class 43s getting kept.
  18. Meerkat
    Meerkat Established Member
    2,507
    14 Jul 2018
    Can a 43 tow a 442?
    just kidding.would you have to rewire the coaches or can you sling some electrical gubbins in the guards bit of the 43 to give the correct supply?
    How heavy is a test train relative to an 88 on diesel? That would be NR setting a good example if possible....(probable RA issues??)
  19. HSP 2
    HSP 2 On Moderation
    158
    4 Dec 2019
    12B
    If you "sling some electrical gubbins in the guards bit" how does it get to the other end?
    IIRC the 88 has a RA of about 7, the 37 a RA of about 5 and the 43 a RA of about 5. So the two older locos can go to more places. But I do like how your thinking about the 88s. Down side is that I can't remember the RCD getting and keeping a "new" loco.
    On your first question, my question is why would it have to? But if all of the correct gear has been made yes it could. But why????
  20. Roger B
    Roger B Member
    90
    16 Jun 2018
    Gatley
    I believe 977969 is part of UTU2 - have I got that right? I'd love to know where UTU2 is usually stabled, it never seems to be on Derby RTC when I go past. Can anyone point me in the right direction please? Many thanks
  21. fgwrich
    fgwrich Established Member
    5,316
    15 Apr 2009
    Between Edinburgh and Exeter
    I think the 20 and the 73 has to be the most go-anywhere loco on the network. I'd certainly be happy to see more of the GB ones covered and utilised on the test train jobs.
  22. Spartacus
    Spartacus Established Member
    1,502
    25 Aug 2009
    It might be nice to see 20s, but there'd be no point with the NR 950/150. NR's 73s do see a fair bit of use though.
  23. hooverboy
    hooverboy Member
    1,068
    12 Oct 2017
    the 20's have had a good innings, realistically they are only good for shunting duties now.
    the modified 73/9's on the other hand are proving to be quite versatile little beasties.
    I think NR should invest in a few more of those, either with the MTU power plant or 2*QSK19.
    The latter might be the better option as it could be used in eco mode with just one engine on(better for fuel economy) if lightly loaded, or use as an auxiliary engine if one fails, which would mean improved reliability.
Share This Page
