Network Railcard - Midnight
soup6
I know that a Network Railcard is not valid before 10am but given that the "railway day" starts at (I think) 04:30, I had assumed it was valid for post-midnight departures. However, on checking on the Southeastern website, there seems to be no railcard-discounted fare on the 00:12 HS1 departure to Ashford. A railcard-discounted fare is available in the 23:37 departure but this also involves travel "before 10am" as the service does not arrive into Ashford until 00:14. Is there an anomaly here?
causton
4 Aug 2010
What if you chose the day before and chose 23:30, then scrolled down/pressed Next to move to the 00:12?
Your thinking is correct, but you would need a ticket dated the day before, as the railway day actually runs (as far as websites and ticket machines are concerned) Day 1 00:00 - Day 2 04:30. So with this ticket you would be using the last 00:00-04:30 period which would be allowed, but if you turned up at St Pancras at 00:01 you would end up buying a full price single for the next day!
furlong
28 Mar 2013
Reading
It's a grey area and relies on 'custom and practice' rather than stated terms and conditions, unfortunately. It's been like this for years and years and the railway just won't do anything about it.
Paul Kelly
Verified Rep - BR Fares
16 Apr 2010
Reading
I think we had the discussion before as to whether you could turn up at a station (which had an open ticket office at that time of the morning) and ask for a ticket dated the day before to get around this sort of problem. As I remember the consensus was that the booking clerk would not be able to issue a ticket dated the previous day once midnight has passed. So the solution is, you need to buy the ticket, dated for the previous day, in advance of your journey.
bb21
Emeritus Moderator
4 Feb 2010
No TIS would be able to backdate a ticket AFAIK.
The restriction should have just been defined as between 0430 and 1000, but I suspect that the number of passengers involved is small, and the cost of amending the restrictions is fairly hefty.
soup6
In order to try to verify what logic was being used, I tried to book a Kentish Town - Ashford ticket on the SouthEastern website. The 23:01 from Kentish Town allows a Network Railcard discount to be applied but the 23:50 does not. Both journeys begin before midnight and end after. It is difficult to see what logic is being applied here. If I try booking for a friday night/saturday morning, a Network Railcard discount is allowed on both so it is definitely the "before 10am" rule that is being (mis)applied.
Paul Kelly
16 Apr 2010
Reading
No need to guess; you can see the full time restrictions being applied by booking engines on BRfares.com: http://www.brfares.com/#faredetail?orig=KTN&dest=AFK&rlc=NEW&ldn=1&tkt=CDS (scroll down to "Unpublished Restrictions"). The time restrictions are applied by booking engines to everywhere you board and alight a train, not just where the overall journey starts. You are probably falling foul of this one:
Not valid to depart any location 0001–0959 on any TOC
furlong
28 Mar 2013
Reading
I have purchased tickets from booking offices after midnight with the discount without comment, and the tickets I was handed were, as expected, dated the previous day.
talldave
24 Jan 2013
Don't use the crap Southeastern site that forces you to select trains??
As there are no reservations on those trains, just buy a ticket for the day before. It will be accepted.
So technically not valid on any after-midnight train? Bizarre. I can't see any member of staff arguing with a train that clearly belongs to the day before.
bb21
Emeritus Moderator
4 Feb 2010
Where was that from?
furlong
28 Mar 2013
Reading
Most recently, Paddington - yes, let's give them some praise for a change on this forum!
The problem here is that those restrictions do not distinguish between 0001 on the date of the ticket and 0001 on a ticket dated the previous day - if they treated that as 2401, it could be made to work in the way people expect.
bb21
Emeritus Moderator
4 Feb 2010
Interesting. That is the first time I have heard of a backdated ticket. By "recently", do you mean after they changed to STAR?
Paddington ticket office have always been pretty helpful and competent ime.
soup6
The pragmatic question is whether a Network Railcard discounted ticket, dated from the day before, will operate the barriers on the SouthEastern platforms at St Pancras after midnight? No-one would want to get into a validity argument for the 00:12 to Ashford as it is the last train of the day so missing it due to a ticket validity dispute would be more than unfortunate.
Broadly on this topic, what happens if you buy a ticket from Transport for London after midnight? Presumably that is dated for the day before because their day runs 0430-'2829' so to speak.
I was once told by barrier staff that an NR travelcard which I had purchased at 0001 was not valid on the underground until start of service (ie after 0430). I was however allowed to travel.
bb21
Emeritus Moderator
4 Feb 2010
IIRC London Underground machines print the previous day's date if purchased shortly after midnight, whereas NR machines print the following day's date.
Deerfold
26 Nov 2009
This only applies for capping. A day travelcard is valid from 0001 to 0429 the following day, a season on Oyster from 0001 on the first day to 0429 on the day after the expiry date.
They were wrong.
Mojo
7 Aug 2005
If you buy a ticket from a London Underground Passenger Operated Machine between Midnight and close of traffic it will be printed with the de facto date and a time since Midnight of that date. For example, at the time of making this post it's 20.27 Hrs on April 10th. If I buy a ticket in 5 hours time it will be printed with a date of April 10th and a time of 25.27.
TfL Rail and Overground are National Rail Tocs so will operate under the National Rail standard. Not sure about DLR (but I would expect it works the same way as LU given the same printing style) or TfL (which don't open late).
Are the barriers actually closed at that time of night? They certainly aren't at Euston for the late-night services - the station is near enough unstaffed by then apart from non-revenue-trained security guards.
maniacmartin
Fares Advisor
15 May 2012
Croydon
See this thread I made on the subject back in 2013
furlong
28 Mar 2013
Reading
Staff should let you through the manual gate in these circumstances: TfL has said it is not worth spending money fixing the barriers because because of the tiny number of people affected.
BestWestern
6 Feb 2011
Hopefully the current day; the following day's date would be highly confusing! :D
