New Cross Gate to Thorpe Bay (RG query)
Ivo
8 Jan 2010
Bath (or Southend)
Hey guys,
Bit of routeing for you all to look at.
I've been alerted to an interesting split (by a certain someone on this forum; thank you for this!) for my route home from Bath to Southend which necessitates travelling via New Cross Gate. The problem is that the cheapest option from NXG to TPB is routed Upminster, which is fair enough, but lacks the Maltese Cross.
Having consulted the Routeing Guide, I find that NXG - TPB is valid on routes via London. This is all very well, but the route in question does not appear to permit the use of LUL. So would I thus be required to travel to between London Bridge and Fenchurch Street (I may chance Liverpool Street because I haven't been on the Emerson Park line for a while) by bus? The obvious alternative route ignores London (LOROL to Stratford via Dalston) and seems rather out-of-the-way.
I may yet not take up this option, if the currently available AP @ £17 w/YP stays as present and I can borrow some funds until Tuesday to pay for this (I will receive more than enough on Tuesday), but if it does become necessary any thoughts would be appreciated.
TIA :)
RJ
25 Jun 2005
Back office
Hey guys,
TIA :)
If London is shown as a permitted route, then the ticket includes the cost of Cross London transfer.
OwlMan
25 Jun 2008
There is also an a +any permitted flow
Ivo
8 Jan 2010
Bath (or Southend)
There is also an a +any permitted ticket
There is, but that costs roughly double the other one! I don't want to pay that if it only saves me a journey on the RV1 bus!
...oops, sorry, didn't realise that wasn't aimed at me. My bad :oops:
OwlMan
25 Jun 2008
I can not see where you are meant to go. It looks like a ticket introduced since the opening of the ELL and probably introduced in error (there is no similar ticket from other nearby station (including the main station of the cluster Forest Hill. There is also no equivqlent in the reverse direction
clagmonster
8 Jun 2005
The shortest route is:
New Cross Gate-London Bridge 2.75 miles http://www.networkrail.co.uk/browse documents/eNRT/Dec11/timetables/Table178.pdf
London Bridge-Upminster (LUL) 0 miles
Upminster-Laindon-Thorpe Bay 22.75 miles http://www.networkrail.co.uk/browse documents/eNRT/Dec11/timetables/Table1.pdf
Total 25.5 miles
New Cross Gate is a routeing point.
http://www.atoc.org/clientfiles/File/routeing_point_identifier.pdf page 43
Thorpe Bay is a related station to the Southend Group.
http://www.atoc.org/clientfiles/File/routeing_point_identifier.pdf page 60
The only routing permission for New Cross Gate to the Southen Group is London.
http://www.atoc.org/clientfiles/File/permitted_route_identifier.pdf page 673
Routeing Permissions for New Cross Gate - London Group are: LB and SC.
http://www.atoc.org/clientfiles/File/permitted_route_identifier.pdf page 672
Map LB allows New Cross Gate to London Bridge as you desire.
http://www.atoc.org/clientfiles/File/Maps.pdf page 57
Routeing permissions for London Group to Southern Group are: EA and TS.
http://www.atoc.org/clientfiles/File/permitted_route_identifier.pdf page 605
Your proposed route direct out of Fenchurch Street is permitted by map TS.
http://www.atoc.org/clientfiles/File/Maps.pdf page 108
The Routeing Guide states:
"If the routeing code is "LONDON", journeys include the cost of cross-London
transfer either by London Underground or Thameslink services. In all cases
the transfer points should be along the correct line of route given by the
‘permitted route’ map combinations."
http://www.atoc.org/clientfiles/File/RSPDocuments/instructions.pdf page 4
This paragraph covers you for an Underground transfer in the cost of your ticket. If you wish to transfer by bus, you will have to pay the bus fare.
Your proposed routes via Emmerson Park and Dalston are not valid. They are not mapped and are more than 3 miles longer than the shortest route.
Ivo
8 Jan 2010
Bath (or Southend)
I never seriously suggested Dalston! But not including LUL, it is the shortest route out there! I fail to see why Emerson Park shouldn't be valid though, assuming I go via Liverpool Street.
clagmonster
8 Jun 2005
It's not mapped, isn't the shortest route and isn't a direct train.
I believe LUL transfers are set to zero when calculating the shortest route, so for anything involving Southend the shortest route is always going to be Upminster to the District Line.
OwlMan
25 Jun 2008
No LU transfers are nil when it is not a joint route (where tickets are interavailable with NR.) West Ham - Upminster is a joint route and the mileage should count.
Otherwise you get really silly calculations for shortest route to London from places like Romford.
How about New Cross Gate - Shadwell
Shadwell - Limehouse (DLR) (Tower Gateway to Limehouse is interchangable between DLR & NR)
C2C limehouse onwards
Peter
clagmonster
8 Jun 2005
Peter
Is Upminster (or maybe Barking) on the list of BR-LUL interchange stations for the purpose of transfers though? If so, then it is valid for two reasons and for the purpose of calculating the shortest route, it would be zero when used as part of a transfer.
When it is a ticket for which London is not a routeing permission, so can't possibly be a transfer, then I agree that the mileage counts towards the shortest route calculation. So the shortest London Terminals-Romford route would be direct out of the Street.
OwlMan
25 Jun 2008
New Cross Gate - Canada Water the LU to West Ham & Upminster is actually the shortest route (whether you count LU between West Ham & Upminster or not (although via London Bridge is within 3 miles.)
