New signals on Merseyrail Northern Line
Grumpy Git
13 Oct 2019
Whilst walking over one of the Cressington bridges last night, I noticed what appears to be new signals.
The Liverpool bound line was showing green, but also had another indicator underneath which was displaying the letters "TT" (in white), but as a train from Hunts Cross approached the platform, the "TT" message turned off. The green aspect remained until the train had departed (as expected) and eventually turned red, but the extra indicator stayed off (no image showing at all).
I was in the process of taking a photograph, but the "TT" message went off before I could get one and as it was dark there wasn't much point thereafter!
Can someone please explain what this additional screen is indicating please?
3 Dec 2008
Huyton
TT means Tripcock Test. There’s a device there that ensures the trains tripcock arm is in the right place, should the ‘TT’ indication not go out the driver needs to stop and contact the signaller.
Liverpool 507
17 Jan 2018
Merseyside
There’s more new signals being rolled out across the Merseyrail network
jamesst
4 May 2011
Merseyside
Thank you.
Theres also trip tester signs located at Liverpool Central Northern line (Moorfields end), Birkenhead North (Liverpool direction all platforms), Birkenhead Central up platform and outside Sandhills (can be viewed from the road bridge)
QueensCurve
22 Dec 2014
I didn't realise Merseyrail used Tripcock. Is it the same as that used on London Underground?
jamesst
4 May 2011
Merseyside
Pretty much. Tripcocks are only used on the underground section of Merseyrail using the Axle counter system. Open areas are fully track circuited.
Liverpool 507
17 Jan 2018
Merseyside
New LED signal lamp heads are starting to appear more across the network now. ML92 at Hightown has now been replaced with a new LED lamp head.
