bb21
Emeritus Moderator
- Joined
- 4 Feb 2010
- Messages
- 24,151
They are very much not all down to infrastructure failures.
There are some very telling underlying measures which have deteriorated very quickly in the last 12 months for which Network Rail can take no (or little) responsibility. There is no hiding from that. Some can be explained by a range of factors outside the control of the operator, such as a jump in ill passenger incidents, but they can only explain away so much. I'm not even talking about anything industrial-relation linked, as that is a complete red-herring imo.
Stagecoach are by no means perfect. They left behind an operation in a very poor shape in many respects, and there is no doubt that First Group picked up a franchise in a far worse state than they originally anticipated. There is however no getting away from the fact that First Group are doing quite poorly atm.
Are things going to improve? Who knows. You are right however to your normal passenger, all that counts is that the train runs on time and reliably.
Network Rail causes will always be in the majority, as infrastructure failures tend to cause much bigger delays and more extensive disruption. The problem with anecdotal evidence is that bigger incidents tend to leave a disproportionate impression, and they prop up more often in announcements by its very nature when there is a mish-mash of causes. Network Rail are certainly no angels, and are failing on many fronts, but they are actually hitting more of their performance targets than the TOC.Leaving aside the recent industrial relations issues, which have only been 6 days of strike action and 4 days of action short of a strike, I'd anecdotally argue that the overwhelming majority of delays and failure to reach ppm have been failure of infrastructure one way or the other.
No doubt someone on here has access to stats that breakdown root responsibility.
Having said all that, the average rail passenger doesn't give a hoot whether it's a track circuit failure or a shortage of staff,they just want their train to turn up on time consistently.
