New yorkshire power stations
Discussion in 'Infrastructure & Stations' started by YorkshireBear, 31 Oct 2011.
Thread Status:
  1. YorkshireBear
    YorkshireBear Established Member
    7,703
    23 Jul 2010
    Rail Forums
  3. 142094
    142094 Established Member
    8,789
    7 Nov 2009
    Newcastle
    Depends on the location - the Ferrybridge one might be on the land at the same site as the one now - not sure for the Donny one.
    I do know that Drax were wanting to build one next to the existing power station, but haven't heard much about this in a while.
    Think the article mentions that one is gas-powered, so that wuldn't be transported by rail.
  4. balne-wonderer
    balne-wonderer Member
    753
    27 Jul 2011
    The Thorpe Marsh station is re-opening then??? Or is this a completley new project?
    The exisiting station was shut down around 94, all that remain are the cooling towers but they looked in poor condition the last time I drove past them.
    The old station had rail access with the line joining the ECML at the Joan Croft Junction, a popular place for spotters.
  5. WatcherZero
    WatcherZero Established Member
    9,292
    25 Feb 2010
    Doncaster one is a gas power station, thats unlikely to be rail.
    Wakefield one is biomass/wood burning so may see some rail supply, depends on the scale and source (i.e. if its local waste it will probably be road).
  6. route:oxford
    route:oxford Established Member
    4,855
    1 Nov 2008
    Could this mean that it is also capable of burning coal should the country every be require to make use of the centuries worth of black stuff underground?
  7. trainfanatic
    trainfanatic Member
    210
    4 Jan 2010
    Big Sky Country - Sleaford
    Cooling towers are still there to maintain the original planning permissions in terms of height.
    Willington near Derby was the same, but I believe there is a new station on that site now?
  8. 142094
    8,789
    7 Nov 2009
    Newcastle
    The process is just about the same - the biomass is pelletised on site and then can be crushed further if needed and blown into the furnace. Same happens with coal. The only problem being that there may be a need to add extra parts such as FGD which may not be needed if it was solely biomass-fuelled.
  9. Nym
    Nym Established Member
    8,138
    2 Mar 2007
    Somewhere, not in London
    And if it's a lot of FGD then being served by rail for limestone in and gypsum out would be quite helpful...
  10. DaveNewcastle
    DaveNewcastle Established Member Fares Advisor
    7,397
    21 Dec 2007
    Newcastle (unless I'm out)
    This junction and its adjoining Shaftholme Jn. is due to be remodelled soon by the addition of a two-track flyover so that freight to & from Thorpe Marsh (and the Humber ports beyond) can cross the ECML towards Ferrybridge without conflicts.
  11. sprinterguy
    sprinterguy Established Member
    10,389
    4 Mar 2010
    Macclesfield
    The situation at Willington is still the same: The cooling towers still remain as the only thing standing, the rest of the site is just waste ground.
  12. brad465
    brad465 Member
    638
    Maidstone
    Whenever I've been on the ECML around the area full of power stations, I already think there are loads there already. Based on where they're being built there's a good chance the range for seeing power stations in the ECML area will increase. :|
  13. balne-wonderer
    753
    27 Jul 2011
    Drax and Eggborough power stations would be visible from the ECML in Yorkshire, I’m not sure Ferrybridge would be though.
    On the subject of the cooling towers at Thorpe Marsh, I believe that one of the reasons they haven’t been demolished was due to fears that a huge explosion would create damage to a nearby weak river bank. The area around Thorpe Marsh has excellent rail and water links, like I said though, it depends on the actual location of the new station.
  14. DaveNewcastle
    7,397
    21 Dec 2007
    You can, between Hambleton and the bridge under the A19, its cooling towers stand above the horizon near the crossing of the Selby Canal.
  15. balne-wonderer
    753
    27 Jul 2011
    Ah there we go! Living in Yorkshire when I use the ECML it's usually from Doncaster going south or out of Leeds going north joining the ECML at York. The ECML stretch between Donny and York I don't think i've ever been on despite living near it for 26 years! madness.
  16. brianthegiant
    brianthegiant Member
    588
    12 May 2010
    My understanding is that Coal is basically out of the running for new generating capacity. The ighj carbon emissions per kWh mean that we wont build coal unless it has CCS, (which is an unproven and v.expensive technology).
    So at the moment its another dash for (Russian) gas, with a bit of wind & biomass, whilst we inch along the ~10 year Nuclear project cycle.
    You can co-fire 10 maybe 20% biomass in a coal fired plant, but not vice versa, for example since a biomass plant isn't built with the complex emission controls (SO2 removal etc) you get in a coal plant. Also the gasification/pyrolysis reactions in burning coal and wood, are significantly different, so that a burner optimised for coal is not efficient for wood & vice versa, different secondary combustion levels.
  17. 142094
    8,789
    7 Nov 2009
    Newcastle
    You can co-fire a coal power station with biomass much higher than 20% - Drax are currently on about 30% and were aiming for near enough 50:50 when I visited earlier in the year.
  18. brianthegiant
    588
    12 May 2010
    ah, ok, the 20% figure is what you can do in existing coal stations without major changes to the burner. If Drax are aiming for 50% they must have made some changes.
  19. 142094
    8,789
    7 Nov 2009
    Newcastle
    They were in the middle of a continuous process in trying to move further towards biomass when I was there, they were even considering growing some plants on site for a trial period. Plus they've just invested in a new warehouse near Goole for incoming foreign biomass.
  20. Penske666
    Penske666 Member
    5
    5 Nov 2011
    Eastern Region
    Just to clarigy the Thorpe Marsh situation, its going to be a gas fired power station, the sidings are going to be used to transport materials to the new North Doncaster Chord freight avoiding line and the cooling towers are going to be demolished soon.
    The new line will also mean the end of Joan Croft level crossing as the road will have a new flyover built north of the present road. :)
  21. balne-wonderer
    753
    27 Jul 2011
    Is it confirmed now that they are closing JC level crossing?
    I know it was in consultation but wasn't sure it had been decided.
  22. YorkshireBear
    7,703
    23 Jul 2010
    well the plans they are to/have submitted to planning department have it as a road bridge not level crossings. They chose this as local residents wanted it plus it allowed them to lower the wires through this section (not having to make allowances for HGVs) so the chord is now lower and less expensive.
  23. balne-wonderer
    753
    27 Jul 2011
    I often spot at JC level crossing. This is a bit of a disaster personally speaking but I guess we can't stand in the way of progress!
    Back to Balne Lowgate and Hensall Quarry for spotting I think!
  24. Penske666
    Penske666 Member
    5
    5 Nov 2011
    Eastern Region
    Don't let that stop you from going up to the Joan Croft area, theres a footpath just south of the old freight overpass that crosses the ECML called Marselles (or something like that). Theres also Dormer Green if you don't mind the walk :)
Thread Status:
Share This Page
