southern442
This probably isn't that worthy of a completely new thread, but does anyone know what the next fleet of mainline trains to be withdrawn for good (and sent to scrap?) will be?
Probably the class 142's Since Angel Trains who own them have said they will not be modifying them to operate post 2020.
Poterbrook have looked at doing their class 143/144's however
It might be the 507s, 508s or 313s are withdrawn before the 142s are completely withdrawn. One new order for Merseyrail will see all 507s and 508s withdrawn, while it's unlikely that an order will be placed for 100 or so DMUs as class 142 replacement.
Porterbrook have looked at doing their class 143/144's however
Weren't they going to use the 507/508's for something else after they were withdrawn?
Thanks. I have also heard that the 153's that operate up north will be going soon. Is this true?
If that were true it would be a big mistake IMO. They are handy for the few genuinly lightly used services and for strengthening other trains.
saying taht 378s are now proven and they will i suspect become the standard for merseyrail etc
378s are 20cm taller than the 313s, 507s and 508s so any orders other than for LO would need to be to a modified design to allow for tunnel clearance, which would then be classed as a different type of train.
wouldn't have thought they would be withdrawn, probably end up with GA or EMT
with passenger numbers growing I wouldn't be surprised if EMT doubled up on the Lincoln line
failing that when the resignalling is complete down there it might be a case of more diagrams with trains running earlier and later
I reckon Derby to Crewe would get doubled up first, however if EMT get any more stock I expect it to be used to free up the last remaining 158s away from Liverpool to Norwich.
This piece of information comes up every time the PEP replacement discussion comes around. PEP stock (classes 313, 314, 315, 507 and 508) has a flat roof with the pantograph mounted directly on top whereas newer stock has a pantograph well. As a result the new trains aren't actually any taller overall so there won't be a problem replacing them with new EMUs. They would still need to be dual-voltage and run on 3rd rail in the tunnels but the pan can flatten just fine as it does today.
Undoubtedly. There are already several of the ealier class 141 Pacer railbuses in preservation, and there perhaps would have been more if the bulk of the small fleet had not been exported to Iran. There is also a Pacer Preservation Society already up and running for just such an eventuality.would we expect to see any being purchased by heritage lines
Pacers are not even good enough for Iran
Iran ordered some brand new Korean built DMUs to replace them.
it's likely we won't see single carriage trains beyond 2019.
153s will probs be reformed as 155s if it's approved. Can't make them economically DDA compliant with 1 coach.
Why is that?
