randyrippley
- Joined
- 21 Feb 2016
- Messages
- 5,132
it just proves that carriages without opening windows are a bad idea.
So some improvements to toilet and/or disposal design are necessary, then.
Or perhaps AXC could arrange to empty the toilet tanks at a correct interval such that they don't get full?
Really? If it's not the TOC who arranges the emptying who does? If the tanks are filling up regularly they're not being emptied often enough. It's not rocket science.
Contract an on-call provider of toilet emptying services to conduct this at a suitable location should it be required.
Install toilet emptying facilities at more locations.
Arrange a prompt repair of the faulty toilet, thus allowing the other one to be used with its spare capacity.
It is all about planning and proper incident management.
Tickets should be priced such that the basic service provided is adequate.
Time toilet provision was added to the franchise agreements, then.
I'm fairly sure that the equipment involved in "tanking" a CET tank is a fairly major bit of kit and I can't imagine it being done anywhere near a station being a pleasant experience for anyone, plus the issue of getting rid of a few hundred kg or so (how much do they actually hold?) from wherever you've pumped it to
Do you realise what is involved in emptying a poo-tank?
Again you show how you live in a black and white world. It sadly isn't that simple and I think you know that.
Correct and something Neil doesn't seem to grasp. While the technology shouldn't be to difficult to mount on a road wagon ( I am sure one of those drain whales would do) getting the road wagon to the train might prove difficult for reasons anyone who has ever been in a railway yard will easily recognise.
How, for instance, do you get the road wagon to Bletchley Carriage sidings?
It's not that they are filling up too quick or on a regular basis. The biggest fault that occurs is they simply run out of water so do not flush. Next I would say is blockage.
A "black and white world" would take the view "there must always be a working toilet".
My view is that there is far *too often* no working toilet, to an unacceptable level. Particularly on off-peak LM services formed of a single unit.
So provide another type of facility there.
It depresses me how some members of this forum feel the railway is incapable of improvement, or that such improvement is somehow an unreasonable concept. All businesses should always strive to improve.
In that case, an improvement would be provided by having more maintenance crews available such that some fixes can be rendered without a return to the depot.
Is a delay justified for this? Yes, as providing toilet stops will incur a delay.
What depresses me is that there is a refusal to accept that complications and the reality doesn't exist and everything should be solved overnight.
I would rather the train had a working loo, but I accept some times it won't.
If it doesn't then I would hope that:
1) This would be announced at stations, so passengers could go before boarding
2) If someone didn't want to travel on a train with no loo, their ticket would be endorsed to travel on the next service at no extra cost
You could say that about anything at all that costs money to fix, though.
The point is that it is not acceptable for this to be happening regularly (yes, you, LM), therefore a solution has to be found such that it is a rarity.
This isn't Greece you know... I thought soiled paper was supposed to go down them! Maybe you mean people using paper to dry their hands after the pathetic warm-air "driers" have failed to satisfy.And people blocking them up with paper.
Given how much embarrassment asking for that may cause, I would suggest an improvement would be that, in such an event, all ticket restrictions should be removed for those who are booked (with Advances) to travel on that train, at the very least, without anyone having to ask. Similarly for the main flows involved, Off-Peak restrictions should be eased to the next train, again without anyone having to ask.
Similarly, a longer stop should be provided for toilet purposes at a suitable location again without anyone having to request it.
I would rather that than having the train cancelled or have a huge delay while it goes off to the depot to be emptied.
On a related note, I struggle to see why tanking facilities are not provided at terminus stations. Why should a passenger have to rely on a train being timetabled to return to a depot to be able to use the loo? It's a basic human function, and on long distance journeys, it's simply unacceptable to not cater for it (as seems to be happening quite routinely.)
One compromise could be for the retention tanks retain the solids, and the excess water to drain onto the tracks. On these long CC routes,
a hose to top up the toilets with fresh water at one or two stations when necessary.
For new trains they could fit toilets with a vacuum type evacuation, and spray a fraction of the water into the pan compared with conventional toilets - Vastly increase capacity, cost of water and emptying.
Hear, hear. This would be particularly helpful for people with weak bladders, pregnant people or similar, who should not have to embarrass themselves to request a toilet stop or an endorsement for the next train.
I think it's really to do with the spacing between platform lines, the intensive use of adjacent lines and the fact that it's not acceptable to be down on closely-spaced tracks between trains any more (if one of them might move)...
A
one help may be to fit zero-water use urinals as used in McDonalds restaurants. Cuts water use, so cuts the retention tank fill rate. Theres room in many toilet compartments to fit them alongside the WC.
The other improvement would be to stop taps dripping, and WCs running continuously. Even a slow drip can rapidly empty a storage tank
One compromise could be for the retention tanks retain the solids, and the excess water to drain onto the tracks. On these long CC routes, a hose to top up the toilets with fresh water at one or two stations when necessary.
Not wanting to be antagonistic..............but what would happen if a 'comfort' break was not available to a member of a train crew? Would the service be cancelled?
