Hb06_
I have not seen one train going past today through the West Coast Main Line, near the Rugby to Milton Keynes Central area at Weedon Bec. Is it just me going crazy or is it a network problem? Thanks.
Was this planned before the Covid era?
A good use of the reduced traffic impact if not.
I can't remember an extended closure before, not even with WCRM.
I wonder if they'll enable 125mph EPS instead of the current 110mph blanket speed limit (presumably because of pressure waves in the tunnel)?
Some tunnels on the line manage it (Northchurch and Linslade), but not Watford, Stow Hill or Kilsby.
It is probably only maintenance, not major works to improve journey times or speeds.
Did anyone suggest otherwise?ONLY maintenance? sigh. It is crucial work to keep the trains running.
No, it won't be 125mph after. The work is to replace track, sleepers and drainage in the last third at the Weedon end. It has been planned for ages but never been able to get to an agreed slot due to the length of time it needs.Was this planned before the Covid era?
The quoted poster by suggesting it was ONLY maintenance. It seems my views are unwelcome so I shall say no more.
There still is overnight in the week.Wasn't there a time (ie in the 1990s) when all WCML services at weekends were given an extra ten minutes in their schedule at the weekend so they could all go via Northampton if necessary?
Yes, 'maintenance' such as this is absolutely essential - I am sorry if I caused offence - I was trying to make the point that it wasn't some sort of major upgrade that would enable higher speeds - instead it is allowing the existing speeds to be maintained and lower speeds to be avoided.
That sounds slightly concerning given similar thinking allegedly contributed to the Hatfield derailmentIt has been planned for ages but never been able to get to an agreed slot due to the length of time it needs.
It’s closed for the next 2 weeksI have not seen one train going past today through the West Coast Main Line, near the Rugby to Milton Keynes Central area at Weedon Bec. Is it just me going crazy or is it a network problem? Thanks.
When attempting to check times, that is what I saw, yes.On my short cycle ride today, via Berkhamsted, trains were running From Hemel Hempstead to Euston, with a bus replacement between Hemel and Milton Keynes.
I don't know what work is being carried out though.
You've just fallen into the clichéd "hard working" mode so beloved of politicians.No problem. No offence taken at all. I get annoyed with posters here sometimes dismissing important work done by hard working people without a thought. I suspect that is because it isn't sexy or fun. It is boring, dull, hard work done at horrible times and often in horrible weather.
On a similar point the use of "essential maintenance" as a phrase - you'd hope they are not doing "non-essential maintenance".
Not really, poor drainage didnt cause Hatfield. This is allowing a substantial amount of work to take place in one go where normaly this sort of access is nigh on impossible to get.That sounds slightly concerning given similar thinking allegedly contributed to the Hatfield derailment
I agree. I find the hyping up of routine scheduled work into "ESSENTIAL maintenance" to be inappropriate.On a similar point the use of "essential maintenance" as a phrase - you'd hope they are not doing "non-essential maintenance".
Perhaps Network Rail need to roll out the big guns, and get someone like Neil Oliver to big it up.I agree. I find the hyping up of routine scheduled work into "ESSENTIAL maintenance" to be inappropriate.
Stowe Hill tunnel is EPS125 already due to new ventilation (pressure relief) shafts being dug during the last WC upgrade, unfortunately due to its proximity to the 100 EPS110/120 curves at Weedon its effectiveness is somewhat limited on the up road. Kilsby tunnel could be upped to 125 we were told but only by capping the very large (60ft diameter?) ventilation shafts situated at 1/3 and 2/3 distance, as their presence upsets the pressure waves. Watford tunnel is EPS115 on the down but only 110 on the up.I wonder if they'll enable 125mph EPS instead of the current 110mph blanket speed limit (presumably because of pressure waves in the tunnel)?
Although it is going rather off-thread, at least for somewhere remote from a station and on a high speed line (such as via Kilsby and Weedon) I do remember this turn of phrase even back into BR days.I agree. I find the hyping up of routine scheduled work into "ESSENTIAL maintenance" to be inappropriate.
One of the worksites was at Tring where the old station footbridge was being removed on Sunday.On my short cycle ride today, via Berkhamsted, trains were running From Hemel Hempstead to Euston, with a bus replacement between Hemel and Milton Keynes.
