FrodshamJnct
Hi All
Can anyone help with the current locations of 66418 & 90047 please?
Cheers
Rob
66418 currently on 4E91 to Leeds Freightliner Terminal.
90047 currently on 4S50 to Coatbridge Freightliner Terminal.
Hi All
Cheers
Rob
Worked 4O29 Trafford Park to Southampton yesterday, not sure if it worked back on 4M95 0322 this morning however..maybe someone with Tops access can check. I suspect it did..Does anyone know if 70011 is scheduled on anything today?
Thank you!Worked 4O29 Trafford Park to Southampton yesterday, not sure if it worked back on 4M95 0322 this morning however..maybe someone with Tops access can check. I suspect it did..
That is 66721 and 66726Hi All
Can anyone tell me what is on this
Cheers
Realtime Trains - 0Y68 0939 Tonbridge West Yard Gbrf to Eastleigh East Yard
Realtime Trains provides live realtime running information for the Great British railway network using open data.www.realtimetrains.co.uk
Still there as of 8.30 last nightCan anyone help to locate loco 66518, was at Crewe yesterday ?
Thanks in advance.
OZ28 was a 56 again so assume 103 againAny possibility of an ID for yesterdays 1530 084W Willesden to Acton TC please, also todays 0934 0Z28 Willesden to Reading
Thanks for any help
Thanks @55002 for your help.Still there as of 8.30 last night
Cheers Tom, do you happen to know the timing for the return working back to Crewe by any chance? Thanks66418 currently on 4E91 to Leeds Freightliner Terminal.
90047 that is for of courseCheers Tom, do you happen to know the timing for the return working back to Crewe by any chance? Thanks
Think the 2 90s come back tonight on the 4L81 1936 London Gateway (to Crewe) or 4L89 2133 Felixstowe (to Ipswich)Cheers Tom, do you happen to know the timing for the return working back to Crewe by any chance? Thanks
Yes it is.Is it 458 504 which is off the road at Clapham Junction please?
Many thanks 55002, I might check again a little later if that's OK then as I may be able to rendezvous with the 19:36 working on my way home from workThink the 2 90s come back tonight on the 4L81 1936 London Gateway (to Crewe) or 4L89 2133 Felixstowe (to Ipswich)
Thank you.Yes it is.
1v33 was replaced by 153353+153369 then 175002 returned to.manchester as 1z54 swapping for 175112.Thank you as always
I believe 1V33 has had a swap and 1W54 was replaced by 1Z54, anyone able to identify the units on those please then that’s it for me much appreciated
It did work 4M95 so I assume it will work back to Southampton again on 4O29 1515 from Trafford ParkThank you!
Great, thanks!It did work 4M95 so I assume it will work back to Southampton again on 4O29 1515 from Trafford Park
1L24 377411 377469Hi
could anyone help with allocation for today`s
1L24 Victoria 10:50 to East Grinstead
1I24 Victoria 11:25 to Horsham
1C24 Victoria 11:05 to Portsmouth Harbour/Bognor Regis
1J26 Victoria 11:35 to Southampton/Bognor Regis
2K24 Victoria 11:36 to West Croydon.
Thanks in advance
Not sure if it has alas..showing as still at Trafford Park an hour agoGreat, thanks!
Thank you so much!1L24 377411 377469
1I24 377624 377702
1C24 377444 377117 377452
1J26 377441 377146 377420
2K24 377109 377211
There’s 2 unidentified 90s on 4M11 1814 Coatbridge to CreweMany thanks 55002, I might check again a little later if that's OK then as I may be able to rendezvous with the 19:36 working on my way home from work
Tamper for the engineering works at Ash Vale tonight, real TRN 6J61Anyone know what this is? Doesn't seem to have a headcode yet but it's down as running https://www.realtimetrains.co.uk/train/U39283/2020-12-02/detailed
Ah thanks!Tamper for the engineering works at Ash Vale tonight, real TRN 6J61
