Yes tough choices as they say- theirs more examples all over, the case to wire to Shrewsbury will not be made on ATW running DMU's under wires from Salop to INLT either. No news on whether Manchester- Cardiff- West Wales will be cut back to Manchester-Cardiff come 2018.
Agreed. ATW's longer distance services don't really fit comfortably inside "borders", nor do they fit around electrification post 2019. Continue running short DMUs on the Swansea - Cardiff part of Milford Haven - Manchester services and you waste part of the justification for electrifying the line. But cutting the service at both Swansea and Cardiff would be politically unpopular.
Same goes for the Cambrian running through to Birmingham so often if the line from Shrewsbury to Wolverhampton is electrified, as you say.
Politics and efficient railways are two different things
Working westwards from the current wires, I would put the business case in the following order:
Wolverhampton-Shrewsbury - 30 miles
Crewe-Chester - 20 miles
Warrington-Chester - 18 miles
Chester-Llandudno/Holyhead (84 miles, all or nothing)
This looks like a pretty sensible scheme (after Chat Moss etc is done in CP5), if the service west of Chester is a half hourly one from Manchester/ Crewe/ London (with the current services from Shrewsbury to Chester via Wrexham mainly cut back to terminate at Chester, as used to happen in Central Trains days)
Chester-Shrewsbury - 42 miles
Harder to justify, unless you are doing the Marches line from Newport to Crewe too
Wrexham-Bidston (27 miles) is mired in uncertainty given the current traffic levels and technical issues.
Merseyrail will want it 3rd rail for compatibility with their current services
It looks pretty suited to dual voltage EMUs (which the 507/508 replacements are guaranteed to be, as
Chris125 says). It's a self contained service, which is always the best type to justify electrification.
what to do with islands with no business case? (Helsby-Ellesmere Port, Llandudno Jn-Blaenau Ff)
Blaenau Ffestiniog is going to be diesel run forever, as far as I can see - it may be tied up with the same light weight stock suitable for the HOWL etc.
The Helsby line is a tricky one, if electrification would cause problems with the oil refineries (urban myth?)
