Northern 323s refurbishment and cascade
td97
26 Jul 2017
The Preston - Victoria stopper is currently 2 diagrams for 1tph, with tight turnarounds at each end. To clarify, I meant maintaining 1tph but including more stops and longer turnarounds. Especially since the turnaround siding east of Victoria is now electrified, it wouldn't be blocking P6 for 45 minutes.
DC2001
4 Aug 2019
"All stops" by its understood meaning would therefore have to include Clifton.
I had forgot about Clifton!
I don't think that passengers at Blackrod and Adlington would be very happy at having more stops added if they didn't get an extra service every hour though. If Northern had enough staff three extra diagrams could probably be added without significant alterations to current services; the 'extra' could be sent from Preston just behind the TPE to Manchester Airport and a return could be sent so it is somewhere between the Northern service from Hazel Grove and the service from Manchester Airport along the Chorley line.
Mollman
21 Sep 2016
What's the status of 6 car working east of the Pennines? Could we see doubled up 333/0s over there as opposed to single 331/1s with the influx of all these units?
Presume you mean 331/0s rather than 333/0s. I thing the issue is that 6 car working is not possible until platform lengthening work is completed.
agbrs_Jack
28 Apr 2017
Congleton / Milton Keynes
If needs be they could just be operated with ASDO with the rear carriage out of use (assuming all stations can have a minimum 120m length platform) if it was too expensive or not possible to extend certain platforms.
6 carriage 323 is approximately 141 metres.
Kidsgrove Up = 138m
Northern ran alcohol free dry trains as double 323s on the last Manchester - Stoke services on Saturdays in December 2017. These presumably would've called at Kidsgrove.
Bovverboy
1 Dec 2013
So which is it then - 17 or all 26?
I would hope it would be 26 to allow some doubling up!
Whichever figure is correct it still represents an increase in total capacity compared to the EMU stock in use now. Whether that capacity increase filters through to the travelling public remains to be seen.
And don't forget, the ex-WM 323s aren't going to be coming to Northern anytime soon.
DC2001
4 Aug 2019
Does anyone know if the Northern 323s have a dedicated bike section?
Llama
29 Apr 2014
There isn't a turnaround siding at the east end of Victoria, the line is electrified up to Bromley Street Jn but there is no useful move eastwards that wouldn't still cause conflict with other movements to/from Victoria.
323235
8 Dec 2007
North East Cheshire
Yes there's two areas with tipup seats in the middle carriage, which are used for bicycles and also intended for buggies - one side is a priority wheelchair area.
Usually on the Stoke line (and last time I travelled) in the morning peak you get upto 10 bicycles stacked up together at the same time.
DC2001
4 Aug 2019
That's good to hear, is it by any chance signed as the bike storage?
py_megapixel
5 Nov 2018
Northern England
Since the refurbishment will probably have to involve PRM mods, does anyone know what PIS is being fitted? I've heard that WMR are getting the LCD screens which are also being fitted to 158s. These convey no more information than a simple scrolling LED matrix and feel rather poorly thought out.
The best solution IMO would be retrofitting the same screens seen in the 195s (if possible)
Failing that, a decent high-res dot matrix as seen on most Bombardier stock built less than 10 years ago (S-stock/Manchester Metrolink/newer Electrostars)
Bovverboy
1 Dec 2013
I think someone may have got it a bit wrong - This is rail magazine after all :p
'Rail' contains lots of errors. I pointed one out to them a few months ago, but no correction appeared in print, and I didn't get an acknowledgement by return e-mail.
CHAPS2034
13 Mar 2018
Thanks for the replies.
Knowing the reputation of Rail magazine, I'm not surprised they have probably got it wrong..
It will be great to have all the 323s up here as I have grown quite fond of them on my local services - apart from when they disgraced themselves just after they were introduced when they took a dislike to frost on the wires. Nippy, reliable and comfortable.
driver_m
8 Nov 2011
I would take anything Rail have to say with a massive pinch of salt, their current thing seems to be a Arriva defence campaign after what seems to be constant digs against Andy Burnham online (Mayor of Greater Manchester) by the likes of Clinnick and Harris because he wants them gone. Sure, he doesn’t know the full goings on and has give TPE an easy ride in comparison, but Northern Rail have been absolutely awful, and no cheerleading by RAIL can change that. Plus, it is his job to change something he doesn’t agree with, i’d expect nothing less from a politician. They wanted him to go and say well done to Northern just because they’ve binned off a few pacers. Why on earth would he want to go along with that when he’d then get called by them for then being an opportunist?!
61653 HTAFC
18 Dec 2012
Another planet...
LIAR. the Grauniad of the railway press.
anamyd
17 Aug 2018
Not trying to moderate but there is a thread called "opinions on quality of journalism in RAIL magazine", just to let people know :)
driver_m
8 Nov 2011
Fair call. Suppose it should get back to 323s. With a 323 already been PRM’d will it just take the usual couple of weeks or a bit longer whilst it’s Northerns first one to be done?
northernchris
24 Jul 2011
Could running a Victoria - Bolton work interlinking with the Preston - Victoria? It would still give Kearsley, Farnworth and Moses Gate 2 trains per hour using the additional 323s once received
Xenophon PCDGS
17 Apr 2011
Thinking of the existing use made of the line from Salford Crescent to Bolton, would any of these extra proposed station stops referred to above have any detrimental affect on the timetabling of all services using that stretch of line. I must confess that every train that I have used in recent times on that line section has been non-stop.
northernchris
24 Jul 2011
Potentially, looking at the timetable there's a gap of around 12 minutes in each direction but would give an uneven frequency at the intermediate stops
Yes quite. Anyone else wishing to comment on RAIL please use the existing thread which can be found here. Otherwise lets get back to 323s please.
_toommm_
8 Jul 2017
As soon as it gets released to the public, I should end up seeing it in service within the week - most of my commute is on 323s so I'm well versed in them :D
I'll try and post photos as soon as it gets released to the general public.
AMD
6 Dec 2017
It should be a matter of weeks, with the caveat that it's the first Northern one, as you note. From September they'll be going into Wolverton two at a time and it's going to be pretty rapid as the programme wraps up in May next year.
prod_pep
8 Aug 2010
On Twitter, Richard Clinnick of Rail magazine has insisted that only 17 of the 26 West Midlands 323s are due for Northern, at least for now. He claims that Northern "would like" all 26.
I can't see any reason for all 26 to not go to Northern, other than a lack of available work for them. Surely Porterbrook would rather have the future of the entire class secured?
