Northern Class 142 sightings
Tracked
30 May 2011
53.5440°N 1.1510°W
At Sheffield this afternoon:
144016 - 2L20 - 15:02 to Leeds (Went from Platform 1b)
142009 - 2R69 - 15:05 to Adwick (2nd unit, coupled with 144003, which was being coupled when I got into Sheffield, this had Leeds on the blinds at 1st but changed to Adwick, not sure if it was originally going to be the 15:02 as it was in 3A/3B where this usually goes from?)
142068 - 2N21 - 15:15 to Leeds via Bolton on Dearne (1st unit)
142079 - 2N21 - 15:15 to Leeds via Bolton on Dearne (2nd unit)
ash39
8 Feb 2012
I'm getting in early, as I'm really hoping to finish my Northern 142's on my day off on Friday. Would appreciate any sightings of 142023 & 142088 between now and then!
I'm hoping they are at least working in the same rover area as one another.
Tracked
30 May 2011
53.5440°N 1.1510°W
142025 on 2L20 15:02 to Leeds
144003 on 2R69 15:05 to Adwick, on its own
142094 on 2N21 15:15 to Leeds Via Bolton on Dearne, also on its own (another 142 was parked at the south end of Sheffield station, didn't get its number)
Dave91131
13 Jun 2018
The 142 parked at the south end was 142067 (assuming you are referring to the one that had its lights on). This worked the 1754 to Retford and return, then the 2015 to Leeds.
Also seen at Sheffield from lunchtime onwards were 142020 / 039 / 048 / 064 / 086. 142039 was on a Hope Valley stopper to Manchester, all others were at the east end from or towards Meadowhall etc.
144's seen were 007 / 015 / 022 / 023 amongst others - don't pay as much attention to them to be honest.
Tracked
30 May 2011
53.5440°N 1.1510°W
That's the one, thanks :) (it's not for personal use, I'm just in Sheffield/Doncaster a lot and figured I could spend the time I'd otherwise be stood waiting for a train home/to work noting 142 numbers for here)
Today:
Doncaster
142065 - 2R29 - 06:03 from Sheffield
E-pacer - 2R30 - 06:06 to Sheffield
Sheffield
Arrived too late to see what was on the 15:02, and a 144 was on the 15:05,
142084 - 2N21 - 15:15 to Leeds via B-o-D (1st unit)
142050 - 2N21 - 15:15 to Leeds via B-o-D (2nd unit)
Doncaster
142066 - 2R70 - 15:24 Adwick to Sheffield
sd0733
7 Nov 2012
142001 was paired with 150149 today on 14:16 Liverpool to Manchester Airport.
nicolaboo
19 Jun 2018
Thursday 17 Jan
142033 - 1018 Salford Crescent to Man Vic : 0Late (then paired with) 150118 - 1037 Man Vic to Leeds: 0Late
142004 142053 - 1026 Man Vic to Southport (and later) 2029 Salford Central to Southport : 4Late
142044 142036 - 1037 Man Vic to Kirkby: 0Late
150228 142005 - 1108 Salford Central to Buckshaw Parkway
142043 - 1118 Salford Crescent to Man Vic: 0Late (and later paired up) 142035 142043 - 2018 Salford Crescent to Man Vic : 0Late
150204 142029 - 1122 Salford Crescent to Alderley Edge : 0Late (and later) 1921 Man Ox to Wigan NW : 7Late (and later) 2045 Salford Crescent to Stalybridge : 1Late
142043 - 1139 Salford Central to Kirkby
142003 - 1144 Salford Central to Clitheroe: 3Late
142061 - 1157 Salford Crescent to Blackburn : 4Late
142055 (seen at Swinton in service heading to Salford, around 1205)
142070 156429 - 1215 Walkden to Leeds : 0Late
142012 156441 - 1236 Salford Crescent to Man Picc
142051 - 1317 Stockport to Man Picc : 2Late
142021 - 1349 Man Picc to Sheffield
150204 142029 - 1729 Deansgate to Alderley Edge : 3Late
150149 142001 - 1813 Man Picc to Man Air : 0Late (and later) 1909 Man Picc to Liverpool L St : 0Late
156428 142007 - 1831 Man Picc to Blackpool N : 0Late
142041 - 1842 Man Ox to Man Picc : 20Late (and later) 1941 Salford Central to Blackburn : 2Late
142045 142034 - 1952 Man Picc to Wigan NW : 0Late
142027 - 2045 Salford Crescent to Wigan NW : 0Late
Andy Pacer
11 Jul 2017
Leicestershire
Anyone seen 142092 around recently? I was over in the Manchester area recently but just trying to keep nan eye on it as it's my last one for haulage!
Tracked
30 May 2011
53.5440°N 1.1510°W
142051 - 2S70 - 15:04 into Sheffield from Manchester (bit late)
142091 - 2N21 - 15:15 to Leeds via Bolton on Dearne (1st Unit)
142071 - 2N21 - 15:15 to Leeds via Bolton on Dearne (2nd Unit)
Coolzac
8 Nov 2014
Does anyone know the typical unit workings on the Esk Valley to Whitby?
I remember that the Mon-Sat 10.57 Hexham-Danby service was normally a 142.
I also remember that the 15.30 Newcastle - Whitby service was normally a 142.
Any others? Are they generally booked as such or is it fairly random?
John Taylor
15 Jun 2018
On Strike Days the 10:20 usually throws up a Pacer.
Tracked
30 May 2011
53.5440°N 1.1510°W
Today's sightings:
142047 - 2R30 - 06:06 Doncaster-Sheffield
142055 - 2R69 - 15:05 Sheffield-Adwick
142078 - 2N21 - 15:15 Sheffield-Leeds via Bolton on Dearne (1st unit, 144005 the 2nd)
142090 - 2C77 - 15:30 Sheffield-Hull
simon7929
27 Sep 2011
Stockton South
I suspect that the unit that does the first two trips does the last one also. That been the case then that would suggest that the Whitby line has been all 142s today?
