61653 HTAFC
Will they have leather seats, I wonder? There's a lot of bull being spoken about the plans anyway...Well yes but from what we have herd so far it doesn't look like they will be using them on Connect services
I though the only Connect service not using new stock was Carlisle - Newcastle - Middlesbrough; is this now not the case?It does - some of the Connect services are very explicitly not using new stock - I think the Chester to Manchester service is one but might be wrong.
Well things may change but from what Northern have said so far they wont, they have said Harrogate route and Leeds-Southport neither of these are Northern Connect, and possible temp use on Chester-Leeds, pre 195 and pre Connect Service. 158's have been indicated as being used on Northern Connect services in the North East, although 170's might actually turn out to be more comfortable than the alleged more luxury version of the ironing board seat that the 195's and 158's are now go to get.It does - some of the Connect services are very explicitly not using new stock - I think the Chester to Manchester service is one but might be wrong.
Carlisle - Newcastle - Middlesbrough is supposedly using 158s. I think the other routes are all meant to be using 195s and 331s, though with Windermere now not being electrified that plan might have changedSorry, it might be that one - what I'm certain of is that there is one.
Plus the 170 would be far more suited to the limited stop, higher speed Sheff-Hull or Leeds-Notts routes than the Harrogate stop-start meander. The 170s are terribly slow off the mark but cruise effortlessly once up to speed. I also expect the 195s, whilst new, won't be as nice inside for pax as the Scotrail 170s.TBH I'd rather have a three coach 170 on the Nottingham - Sheffield - Leeds - Bradford service than a two coach 195 - the extra seats are more important to me (given that a 195 isn't going to be massively different to a Turbostar).
Correct re Carlisle - Middlesbrough, but what may also be confusing things is that some (most?) of the Northern Connect services will only have "Connect" units on certain journeys.
For example, I think the Sheffield - Hull service will only see "Connect" quality DMUs on around two thirds of the services - which would leave a gap for additional 170s to fill on the remaining services (whether ex-GA or ex-LM). The plan seems to be to order a headline number of new trains (albeit many of which are just two carriages) and then spread them thinly around the network (so that lots of stations are on the "Connect" map and get brand new trains, but not enough to fill all diagrams on those lines). So it looks like a huge improvement but there aren't sufficient carriages to do everything that is being suggested.
Aren't some 170's going to come of lease from the West Midlands Franchise?
Are the 22x 3 car 185s still on the cards?
I'd also expect Chiltern to nab a couple (for conversion into 168s), as they'll need to replace the slam door set by 2020.The Northern Franchise agreement has this to say about non specified additional stock; 18x 2 car units, of the equivalent performance and quality of Class 170 units.
There are the following coming off lease:
Greater Anglia 8x 3 car 170s
Greater Anglia 4x 2 car 170s
London Midland 17x 2 car 170s
London Midland 6x 3 car 170s
That said I would suspect the next Cross Country franchise holder is a good bet to take on at least some of these.
Must admit I did find the ones TPE had very cozy, shame they didn't have them for long.
They're awful! I get them sometimes on the Oxford to Bicester Line, the seats are hard and stiff, unlike the original 168s and ScotRail 170s. Fortunately the Northern 170s shouldn't have those seats.Must admit I did find the ones TPE had very cozy, shame they didn't have them for long.
Which way?It does - some of the Connect services are very explicitly not using new stock - I think the Chester to Manchester service is one but might be wrong.
Has it been confirmed that the 170s are keeping their current seats? Otherwise some of you will be very disappointed when a refurbished set appears with ironing board seats. Slightly off topic but I do remember reading that the 2-car 195s will generally work in pairs (stop sniggering at the back).
FWIW those seats are the Chapman frame - a good upgrade in Chapman seated units would be to change the cushions for that design instead of the originals.
So like on the 150/2s? Is there room??
Could there be confusion between 'lines' and 'services' here when you write about 'journeys'? For example, the Furness line will have Connect services from Barrow to Manchester using 395s and omitting certain stops while the Barrow to Lancaster/Preston services will be operated by existing units as stopping services.... what may also be confusing things is that some (most?) of the Northern Connect services will only have "Connect" units on certain journeys.
I think you mean 195, not 395. As nice as it would be to have 395s in the north, I can't see it happening anytime soonthe Furness line will have Connect services from Barrow to Manchester using 395s
