Northern Class 195: Construction/Introduction Updates
palmersears
20 Sep 2011
And presumably, since it's Northern, the guards aren't permitted to work the doors from too near the front, meaning that on the 2 car sets they're effectively tied to a bungee cord to the only door panel they can use?
I've been on 195s where the guard has opened the doors from the front upon arrival at Lime Street. I've not seen it at intermediate stations, however.
They can't get in the external cab doors no. Drivers aren't able to either until they get 'issued' a butchered T-key which looks like a crackpipe and has the end from a sawn-off drivers key welded on to one of its ends, the welding in question done by a traincrew manager and his mate on weekends.
Very Northern! :D
Why can't they just carry the driver's key separately?
Llama
29 Apr 2014
Are there any disused coal workings from the former Moston colliery under the site of Newton Heath depot that could cause problems?
There's been concrete down within the shed visible for many weeks now so I'd assume it isn't that but it would explain a lot if it was that.
Llama
29 Apr 2014
Very Northern! :D
It's not physically possible to get in the doors with just a drivers key as was the intended design, there's far too much force required and you can't get enough leverage. Even using an adjustable spanner on the lug of a drivers key for extra torque bends the drivers key.
Deerfold
26 Nov 2009
That would explain why I've seen so many unlocked cab doors on 195s.
Llama
29 Apr 2014
It's the exterior cab crew doors we're talking about here rather than the cab to saloon doors, the exterior doors don't actually lock but are virtually impossible to get into without the right 'key'. If you find an interior cab door unlocked it would be worthwhile to mention it to the guard or driver, someone's being slack.
Deerfold
26 Nov 2009
My mistake.
As the guards kept walking through (at stations), I assumed they were aware.
Wow, you'd think the cab door would be a standard thing for CAF and that such flaws would long since be designed out.
Llama
29 Apr 2014
CAF didn't make the cab doors. The firm that made them is understood to have never made any cheaper doors. We've had problems with those doors coming open in service and the mechanism to get in the doors is just comical.
craigybagel
25 Oct 2012
Interesting solution! If you don't have the bodged key how do you access the train on depot or in other places where the doors might be locked?
Opening is fine, but Northern are against their guards closing the doors from the front for some reason
Llama
29 Apr 2014
If you don't have the key, you don't take the unit. It's possible to get in with a T-key at a cleaners door switch but that's not good enough to take the unit out in case you end up having to get down on the ballast while out and about.
fulmar
12 Feb 2016
Sorry, sharing a picture of a key designed to access a secure space would not be appropriate.
craigybagel
25 Oct 2012
Interesting. Judging by the photos WMR have gone for electric cab doors on their 196s, but the drawings I've seen suggest the TfW 197s have the same manual doors as the Northern units. Hopefully they'll find a better way of opening the doors by then then a bodged t key.....
27 Jun 2016
I've noticed the external cab doors don't have t key locks - are the guards even able to access the cab?
They are actually designed to be opened with a drivers master key, the problem being that the lock mechanism is so stiff that there isn't enough leverage on the 'handle' of a drivers key to be able to open them (unless you're very strong).
The makeshift T-Keys are no longer issued, there is a version now made by CAF, issued with a brief of "just use the cab door key end, the square end is liable to break off if you use it".
craigybagel
25 Oct 2012
I'd be lying if I said that filled me with confidence....
Llama
29 Apr 2014
Interesting to hear that there are official keys now, however flimsy, I won't hold my breath though.
And as I said upthread, it can need enough force to get in these doors that it actually bends a drivers key.
27 Jun 2016
Standard railway afterthought of a solution to a problem.
Yes the official ones aren't holding up too well. Ones that have been used only a handful of times are showing wear already. Unlike T-Keys/Drivers keys that we all tend to have a few spares of, we've been issued one each so if it gets dropped, lost or actually breaks in service then they're going to have problems.
Edders23
22 Sep 2018
Are there not second keys at depots for use in such a situation there must be more than one per train surely ?
27 Jun 2016
One per driver is issued on a personal basis. There may be spares but they are not as freely available at depot level as other keys are. I guess that may change in future but certainly as an initial roll out supplies are limited.
LowLevel
26 Oct 2013
Sounds like a right load or rubbish. I'd be quite annoyed if I had to wait for a driver to turn up to gain access to my own train!
I can see why using t keys is undesirable from a security perspective but the driver's master key was never really designed for exerting torque in that manner, it seems a bit daft.
Something along the lines of a HST/170 Kaba security key with a normal lock would have been far more sensible.
27 Jun 2016
It's only really from sidings first thing that the guard needs the driver for access. From platform level there is a separate egress via the passenger doors for the guard/cleaners and anyone else.
But I do agree with you. There must've been a better alternative.
Or the lock just unlocks it, then you use a handle to exert the force to open it. Like, er, just about every uPVC door in the country, then.
If they find this difficult, it's entirely understandable why e.g. decent-riding bogies are beyond them.
ed1971
14 Jan 2009
Wigan
Considering that BREL could make 'decent-riding bogies' in the late 1970s, I don't know why we can't have them four decades later.
TH172341
22 Aug 2010
Does not surprise me really with the key or software situation based on my experience with CAF!
It's disappointing that, other than the Class 221, every single train built since the Class 158 has had a significantly worse ride.
172s and 710s I find ride very well and 170s whilst not as good as 158s, are fine. Hitachis are okay aside from when faced with poor track quality or pointwork at high speed. CAF by far the worse, very jiggly and unsettled. Is laughable how the quality can go backwards when a 150 rides better than a 195.
superkev
1 Mar 2015
west yorkshire
The poor 195s (and 331) ride and banging, presumably from the bogie bump stops, does not bear well for long life.
Ian Warmsley in this months Modern railways says that inside frame bogies ride worse than older outside frame designs for some reason. He also was of the view that using inside frame on the CAF Scottish sleepers, where there have been rumours of spilled whisky and disturbed sleep, was criminal.
I hope CAF can eventually alter some parameters to improve things.
K
