Northern Class 195: Construction/Introduction Updates
Discussion in 'Traction & Rolling Stock' started by Haydn1971, 2 Apr 2016.
  1. Llama
    Llama Member
    763
    29 Apr 2014
    Doors between vehicles cost money, as do cab-end gangways. These units really are CAF - cheap as ...
  2. Mogster
    Mogster Member
    208
    25 Sep 2018
    I have no problem with the functional look, easy walk through makes sense on busy frequent stopping services.
    For longer distances, journeys of greater than an hour maybe, something offering a bit more comfort would seem appropriate.
  3. Agent_Squash
    Agent_Squash Member
    623
    22 Jul 2016
    For the Connect routes that have seen refurbed 185s, they’ll be a downgrade. They’ll still be an upgrade for the rest, though.
  4. Spartacus
    Spartacus Established Member
    1,148
    25 Aug 2009
    Not long enough, cheapskates! Ruddy heck, I thought it was a shock they were ordering new units at all and not going for the 144e/cast offs option!
  5. Bertie the bus
    Bertie the bus Established Member
    1,123
    15 Aug 2014
    You weren't paying much attention then. Ordering new stock has nothing to do with Arriva and nor does Pacer withdrawal. Both were specified by the DfT. The bidders had no choice.
    The choice of new stock was down to Arriva and from various comments it isn't anything to boast about.
  6. darloscott
    darloscott Member
    388
    12 Dec 2013
    Stockton
    No doors between cars? Presumably that means a 700-style open walkthrough area? Gets you more standing space too if so!
  7. beano900
    beano900 Member
    46
    30 Jul 2013
    This used to be served by 6 carriage 185's at peak times under TPE. The morning rush hour service was always very busy even with 6.
  8. sprinterguy
    sprinterguy Established Member
    9,874
    4 Mar 2010
    Macclesfield
    No; typical narrow corridor connection.
  9. Bletchleyite
    Bletchleyite Veteran Member
    38,435
    Up and down the south WCML (mostly)
    Standard seating:
    6-car 185: 338 seats (30 of which 1st)
    4-car 156: 304 seats (no 1st)
    That's surprisingly little difference. The Class 185 layout is second only to the Voyager for its gross inefficiency of space usage.
  10. Bletchleyite
    38,435
    When I first saw that I thought it had "Pacer" written all over it. Cheap and nasty.
    These things, given their comfort level and superior acceleration, should really be going on Manchester and Leeds area locals directly replacing 142s and 150s. Northern Connect needs better, more InterCity like trains such as 170s and 158s, ideally with an ATW or EMT style interior with decent seats rather than ironing boards (or just the originals with new cushions - the GWR 158s are like that and are decent) and a less stark colour scheme.
  11. sprinterguy
    9,874
    4 Mar 2010
    Macclesfield
    I agree on all counts. From what has been seen the 195s don't seem appropriate for Northern's premier services.
  12. samuelmorris
    samuelmorris Established Member
    3,216
    18 Jul 2013
    Brentwood, Essex
    Agreed. Just because they're modern air-conditioned 2+2 units they're far higher-spec than a lot of the other Sprinters, but they are really commuter-spec, not long-distance. What was the expected average journey time on Connect services?
  13. Wtloild
    Wtloild Member
    76
    8 Aug 2018
    But the end-only doors on 156s make for horrendous delays on packed commuter services with people mid-coach slowly trying to squeeze through the crush to get off (e.g. Manc-bound morning trains at Salford Cresc).
    185s much more efficient in that respect.
  14. modernrail
    modernrail Member
    327
    26 Jul 2015
    I hadn't noticed the lack of end doors before. That is a bit naff on long distance services. I also hadn't noticed the mis-matching seats and carpet before. Can somebody please lend Northern a bloody colour wheel.
    Is it looking increasingly sensible for Northern to deploy the 170's on the Connect routes and the 195's on routes like Leeds to Harrogate and Manchester to Southport? The 170's are better geared for longer routes and the interiors better suited. The 195's are better geared for routes with lower line speeds and more regular stops (I understand).
    Putting my passeger hat on I would be more than happy with:
    - 195's on Leeds to Harrogate, Manchester to Southport, Liverpool to Manchester via Warrington and the like;
    - 185's, if they can be negotiated into the franchise, on all Transpennine via Calder Valley services;
    - 170's on the remainder of Connect services such as Leeds to Nottingham (with the exception of 158s which are fine for Carlisle to Newcastle)
    The final piece of the non-electrified puzzle for me would be to replace all sprinters with converted 321's. Hydrogen where this works and bi-mode where it doesn't.
    That would, in my view, take Northern from basket case to logical and actually pretty comfortable. As they need to move all the deck chairs anyway they might as well apply some logic.
  15. samuelmorris
    3,216
    18 Jul 2013
    Brentwood, Essex
    Not enough 170s coming over to do that are there?
    I agree in principle with all that, though I'm not sure how many 321s are likely to be converted. Presumably there are several areas on Northern where 4x20m units aren't practical.
  16. modernrail
    modernrail Member
    327
    26 Jul 2015
    I am not sure on the number of 170's. I know a line from London Bridge with some suitable stock though if a bi-mode replacement can be found that fits through Oxted tunnel!
  17. js1000
    js1000 Member
    432
    14 Jun 2014
    I do believe that in time the 321 hydrogens & 769 bi-modes could be a panacea for the Norrhern franchise.
    The 150s/156s are life expired and do nothing to encourage more people to use the train.
    However no TOC or ROSCO is going to make another large diesel order given the possibility such trains could be banned / require modifications to hybrid in the next 10 to 20 years. The fact the 195 was only increased by 3 says it all.
    A cheap and cheerful solution is the only way and the 321s and 769s could offer that. (assuming they'll work as reverse engineered bi-modes)
  18. krus_aragon
    krus_aragon Established Member
    4,031
    10 Jun 2009
    North Wales
    Sat over the border, where TfW have ordered similar Civity stock from CAF, we're expecting stock with inter-unit gangways (which naturally must have doors!) so I'd expected some doors between carriages as well for us.
    I hope CAF offer some flexibility on the internal fitting, as our stock is going to be routinely working services that are four to six hours end-to-end (Holyhead-Cardiff, Manchester-Milford, Birmingham-Pwllheli).
  19. Bantamzen
    Bantamzen Established Member
    2,807
    4 Dec 2013
    Baildon, West Yorkshire
    A couple of questions. When did Northern Connect become an 'Inter-City' brand as opposed to a Regional one? I was always under the impression that Connect was just a slight upgrade to commuter services, covering longer distances with fewer stops. A bit like the York / Leeds - Preston / Blackpool, or Leeds - Nottingham?
    As for the gangway doors, is it actually the case that there are none? The photo up-thread shows an unfinished interior, with no tables, plastic covering on the floors and a divider where the doors might be suggesting that there is still more work to be done, perhaps such as fitting sliding doors?
  20. Mogster
    Mogster Member
    208
    25 Sep 2018
    The 319/769s are already 30 years old, how can they be anything but a short term stop gap? I’ll believe they are a success when they actually appear in service.
  21. modernrail
    modernrail Member
    327
    26 Jul 2015
    I agree there is a question to be answered here. If I was sitting in the DfT or a TOC I would be asking the following very simple questions of the ROSCOS:
    - Will you guarantee me 15 years good quality service here, and by that I mean the ROSCO provides the units plus maintenance at a fixed price as is now common for new trains. I don't think the TOCs should be taking on maintenance responsibility. My hunch is that the ROSCOS will be willing to do this.
    - Can you offer me the units to Renatus standards at a cost that is low enough for me to say okay fine this is a much better solution than a new order as there is sufficient delta between the two prices.
    It is this bit where I I think there will be most questions. There will clearly be some units that have already been converted to Renatus standards and so those costs have already been incurred and so the ROSCO just needs to try and max revenue from them. It is the cost of conversion to bi-mode and conversion of any non Renatus units that I suspect could put pressure on the equation.
  22. LNW-GW Joint
    LNW-GW Joint Veteran Member
    12,801
    I believe Arriva ordered more new stock than was required in the ITT.
  23. Mogster
    Mogster Member
    208
    25 Sep 2018
    The 195s should be being used to directly replace the Pacers, the seem most suited to that role.
    The regular pax aren’t stupid, mostly..., and will quickly work out that Northern’s “new trains to replace pacers” is actually a smokescreen and start complaining.
    The pax seeing 170s and 185s daily aren’t going to be impressed with the 195s particularly. Punters traveling on 4x 142s however will be impressed with 4x 195s... Seems so simple :D
  24. samuelmorris
    3,216
    18 Jul 2013
    Brentwood, Essex
    Doing that would have required considerably more units - in excess of 100. As things stand, using 195s to cascade Sprinters to replace Pacers manages expectations to some degree. Not great for the people that have endured Pacers for the last 30 years to step up to only having 150s for another decade, but better than nothing. Given the considerable subsidy that goes up there, I don't think the DfT would be too keen to see expensive new assets used on routes that weren't bringing in a good return. The 150s, 155s and 156s are long overdue for replacement too, once they are replaced with something better then some growth might be stimulated. Personally though, I don't see that coming unless service frequencies / journey times are improved.
  25. Mogster
    Mogster Member
    208
    25 Sep 2018
    You can’t increase peak time passenger numbers if the current services are full. It seems the major problem is most of the infrastructure can’t support longer trains than a 4 car 156 and there’s no spare rail capacity for increased frequencies.
    Surely in the short term longer trains are the answer, but without the platform space that can’t happen.
  26. samuelmorris
    3,216
    18 Jul 2013
    Brentwood, Essex
    I don't think that's universally true in the North, but longer platforms would certainly help.
  27. Clip
    Clip On Moderation
    10,152
    28 Jun 2010
    There’s a pair of these sat at Blackpool north sidings and they do look nice in the flesh even though it’s a bit dark
  28. Wtloild
    Wtloild Member
    76
    8 Aug 2018
    There's quite a few stations that can't even cope with 4-car 156s.
  29. Mollman
    Mollman Member
    362
    21 Sep 2016
    It was design to avoid Manchester - Barrow & Windermere being downgraded in quality with the transfer from TPE (designated as an Intercity franchise) and Northern. The loss of first class and a trolley has already downgraded them to an extent.
  30. Bletchleyite
    38,435
    Which is ironic, as I personally always used to avoid the TPE services and choose the Northern ones, because the seats can be as fancy as you like and the trolley as well-stocked and good value as you like, but neither are any use if you don't get a seat and the trolley can't get through, and I strongly resent paying for First Class purely to get a seat on a non-commuter service.
Share This Page
