Northern Class 195: Construction/Introduction Updates
Discussion in 'Traction & Rolling Stock' started by Haydn1971, 2 Apr 2016.
  1. 507021
    507021 Established Member
    3,214
    19 Feb 2015
    331106 apparently.
  2. 507021
    3,214
    19 Feb 2015
    In this instance, I was using bench seated 142s as an example. :)
  3. Jack Brown
    Jack Brown Member
    32
    1 Feb 2019
    Yes, 331106 went to Neville Hill for driver training. Confirmed via Web Gemini
  4. Clip
    Clip On Moderation
    10,034
    28 Jun 2010
  5. mikemcniven
    mikemcniven Member
    319
    13 Aug 2016
    Manchester
    195103 and 195109 switched places with each other oporating 5T03 Blackpool CMD to Newton Heath TMD 195103 and 5T09 Newton Heath TMD to Blackpool North CMD 195109
    I captured 195109 at Manchester Victoria around 11am this morning
    [​IMG]
    Northern 195109
    by Mike McNiven, on Flickr
    [​IMG]
    Northern 195109
  6. Elecman
    Elecman Established Member
    1,681
    31 Dec 2013
    Lancashire
    Several 195s running into/out of Blackpool North today
  7. Prestige15
    Prestige15 Member
    210
    6 Aug 2016
    Warrington
    Clag..
  8. paddyb6
    paddyb6 Member
    77
    21 May 2018
    Are any out tomorrow
    Thanks
  9. Nymanic
    Nymanic Member
    56
    6 Jan 2014
    Manchester
    I was passed by a 195/1 (or 331/0?) that was heading east between Edge Hill and Wavertree Tech Park, at about 1825 today. I can't find a corresponding service on RTT, though...
  10. Red Devil
    Red Devil Member
    110
    6 Jan 2016
    None out tomorrow
  11. Agent_Squash
    Agent_Squash Member
    613
    22 Jul 2016
    Sounds like a bus - perfect replacement for Pacers!
  12. Chris217
    Chris217 Member
    163
    7 Nov 2018
    Will any of these be introduced in time for the May timetable change?
  13. Harvey B
    Harvey B Member
    155
    11 Mar 2019
    Because of the problem, no they won't
  14. jonesy3001
    jonesy3001 Established Member
    1,885
    13 Jul 2009
    Malta
    They'll probably get phased in after the driver training and familiarization, seen a couple go up and down the WCML today, got to love railcam UK.
  15. Harvey B
    Harvey B Member
    155
    11 Mar 2019
    Even then, I doubt these and the 331s will be ready by the May timetable change. I can see them entering service in mid June the earliest
  16. jonesy3001
    1,885
    13 Jul 2009
    Malta
    :rolleyes::rolleyes::rolleyes:
  17. anamyd
    anamyd Established Member
    1,021
    17 Aug 2018
    Thought they had SCR!
  18. LOL The Irony
    LOL The Irony Established Member
    1,954
    29 Jul 2017
    Tracy Island
    Must need a service then.
  19. anamyd
    1,021
    17 Aug 2018
    ZF Ecolife Rail 6-speed gearboxes as fitted to 172s. I don't know of any buses with MTU engines though :)
  20. anamyd
    1,021
    17 Aug 2018
    I suppose so
  21. anamyd
    1,021
    17 Aug 2018
    Not much seems to be talked about on the internal bar coupler issue. Are there any plans for a fix yet...?
  22. anamyd
    1,021
    17 Aug 2018
    They're not safe until the restrictive internal bar coupler housings have been fixed.
  23. LOL The Irony
    1,954
    29 Jul 2017
    Tracy Island
    If they're running around again, they're probably fixed or are testing a fix.
  24. Harvey B
    Harvey B Member
    155
    11 Mar 2019
    I don't understand what your meaning
  25. anamyd
    1,021
    17 Aug 2018
    Curious to know what that is!
  26. M7R
    M7R Member
    130
    15 Sep 2010
    To stop clag you need a DPF, SCR is used to reduce NOx emissions only.
  27. krus_aragon
    krus_aragon Established Member
    3,810
    10 Jun 2009
    North Wales
    A DPF would be a diesel particulate filter; could someone help me with "SCR" ?
  28. M7R
    M7R Member
    130
    15 Sep 2010
    Sorry, Day job is emissions of slightly smaller things...
    DPF you was right, SCR is Selective Catalytic Reduction. The Nox is held onto by the surface of the brick in the cat, when it’s full urea (adblue( is added to the exhaust gasses up stream of the cat, it reacts with the nox via the coatings on the cat and turns it into less harmful compounds.
  29. anamyd
    1,021
    17 Aug 2018
    So they do have SCR but don't have DPFs...? Interesting :p
  30. M7R
    M7R Member
    130
    15 Sep 2010
    They meet EUIIIB emissions levels and the press release states they have SCR but no mention of a DPF.
    I have not looked into the limits for heavy duty engines as all the stuff I check is light duty so has different limits for different emissions. (in cars etc a DPF isn’t mandatory, but it is basically impossible to meet the particle limits without one, even direct injection petrols are now starting to GPFs - Gasoline Particle Filters)... but we are venturing way off topic now
Share This Page
