Times that service trains are booked to stop please. Thanks in advance.
I've started the search period a shade early, the reason being that the unit working the 1344 to Barrow isn't scheduled to get back to Preston until 2018. If you see this one you should catch all the 195s in use on the Barrow/Windermere services (should be seven), in fact four should be through twice. I'll give scheduled platform numbers, but, believe me, these are subject to alteration.
1344 Barrow (P3)
1408 Manchester Airport (ex-Windermere) (P4)
1445 Barrow (P4)
1509 Manchester Airport (ex-Barrow) (P4)
1545 Windermere (P4)
1608 Manchester Airport (ex-Barrow) (P4)
1645 Barrow (P4)
1708 Manchester Airport (ex-Windermere) (P6)
1745 Barrow (P4)
1808 Manchester Airport (ex-Barrow) (P4)
1908 Windermere (P5 - arrives 1843)
The unit working the 1408 to Manchester Airport should be back at 1645, 1445 Barrow at 1808, 1509 Airport at 1745, 1608 Airport at 1843.
Cancellations are always a risk, but these are less likely on a Thursday than some other days. All the same, there have been some bad Thursdays. When trains do get cancelled it's usually either north of Preston only (there's often a crew change at Preston), or south of Preston only. It's less common for a train to be cancelled throughout.
I see that there are indeed some training runs scheduled for tomorrow, but these will not necessarily run, if they do run it won't necessarily be at the booked time, and I wouldn't be able to tell if they're intended to be 195s or not. If you want to keep track of those the best way to do it would be via the 'Realtime Trains' website.
Units used on training runs are usually ones which haven't yet seen passenger service.
I don't know if you're interested in 'electric' 195s (i.e. 331s), but there should be at least two of those in use on the Liverpool - Blackpool service, and any units coming through on training runs are more likely to be 331s than 195s.
