Northern Class 331: Construction/Introduction Updates
sd0733
7 Nov 2012
Thanks
My presumably out of date lists 331010, 013, 020 012, 022, 023, 024 025. 026, 027 stored edge hill. Awaiting delivery 028 to 031.
K
013 is definitely out too, was paired with 014 the other day.
ic31420
23 Aug 2017
Pretty sure I was on 020 014 021 I think 21 was paired with 14 and had that new car smell.
I have to say I noticed some knocking from the bogies but not as much as I expected. Has it ever been determined what the noise is?
Goldie
29 Sep 2014
Making Doncaster to Leeds journeys suddenly took like time travel into the distant future:
superkev
1 Mar 2015
west yorkshire
On the 195 thread member "Philip" posted on the 22nd Feb that Class 331s; 012 and 022-031 where not yet in service.
Of these I haven't heard that 027-31 have being delivered.
K
Llama
29 Apr 2014
The regen brake has generally been in operation again for a couple of weeks now after software modifications were tested and proved to have fixed a potential issue.
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
That’s good to hear that they’ve finally found a fix. When I rode it on Saturday, 331 106 was still using friction brakes.
Also, does anyone know which two 331/0s are at Skipton (I’ll assume that it will be two that haven’t seen service).
Llama
29 Apr 2014
There are still a few drivers isolating the dynamic brakes on 331s if they were trained on 331s while instructions mandated the dynamic brake was isolated at all times and they don't sign any other traction with a dynamic brake. They need a brief and a ride out with an instructor before they can use it.
bengley
18 May 2008
Northern do crack me up sometimes
superkev
1 Mar 2015
west yorkshire
I believe 3 car 331 004 and 012 are the Skipton trainers.
K
24 Jun 2014
Derby
Two of the 321s are off lease 901,902 and 3 333s are not in service. 333 007 is at Holbeck for interior refresh, 009 is at the railways technical centre with serious structural problems and I believe another is stored at Skipton.
There are rumours that the structural problem will take 9 months to repair and may be uneconomic putting in doubt the future of the whole class.
K
Some time ago, there was a 333 at the Railway Technical Centre which appeared to have very recently been repainted into the current northern livery; however, the last time I saw it (I guess about two weeks ago) it's body was totally wrapped in white - looked like some sort of material. My thoughts were that it had been wrapped to prevent the paint work whilst being transferred by road back to Yorkshire. Is this the set you're referring to, or are there more than one at Derby?
24 Jun 2014
Derby
Received my March 'Modern Railways' today, and there's an article about battery powered 331s being used on the Windermere branch.
It claims that, subject to DfT approval, 5x3-car units are going to be converted to 4-car sets, with both the new vehicles and the existing centre cars being battery carriers; it suggests that these will provide sufficient power to operate one return trip between Oxenholme and Windermere, but as most of the current diagrams require two return trips, a fast recharge facility will be required at either Windermere or Oxenholme.
Couldn't see anything about this by doing a quick look back on this thread; anything further known, please?
Bovverboy
1 Dec 2013
No Windermere diagrams do fewer than three return trips in a row, Oxenholme - Windermere, and a minority do four. Perhaps someone has in mind recharging facilities at one of the termini?
Or perhaps the plan is to run an hourly service, Windermere to somewhere or other (i.e. on the WCML)?
bengley
18 May 2008
Are you saying drivers should be allowed to use brakes they haven't been trained on?
This seems a simple sensible solution until all are trained.
It's the same brake. The brake force is not changed. I've never heard of any TOC having such weird restrictions like this.
Llama
29 Apr 2014
It is, I'm fairly sure, part of the safety case that all traction with a dynamic brake needs drivers to be specifically trained (including practical handling) on the operation of the brake, and an extra assessment in the two yearly cycle specifically on traction with a dynamic brake. If they haven't had the practical handling with the dynamic brake in use and don't sign any other traction with it then they need a bit more practical handling on it before they can use it.
Seems fairly belt and braces to me. If there was an incident whereby a driver wasn't familiar with all the quirks of that brake, how the friction brake blends with it (or doesn't) and what it feels like in different scenarios, and the dynamic brake did something it shouldn't (which is what led to it being isolated on the fleet in the first place) I'm sure there'd be finger-pointing at an inquiry.
Philip
27 May 2007
Manchester
In the case of the 175s and 185s, I didn't think the driver had the option whether or not to use the dynamic brake? I thought the driver just pulls the throttle stick to the brake position if active and higher than 20-30mph, then the dynamic brake would apply, if isolated then it wouldn't?
Greybeard33
18 Feb 2012
Greater Manchester
The Windermere services currently interwork with the Barrow services at Manchester Airport. In order to disentangle the diagrams, I think the Windermere - Airport service frequency would have to change from the current 1tp3h to 1tp2h (the round trip time is 5 hours, less an hour's overlap between Oxenholme and Windermere). This would mean that the frequency of direct Airport - Barrow services would also have to change to an even 1tp2h, so further reducing DMUs under the wires between Lancaster and the Airport.
The 331 diagrams would then make two successive return trips Oxenholme - Windermere before returning to the Airport, as suggested in post #1516.
Bovverboy
1 Dec 2013
Post #1516 inferred that that is what prevails now, and it doesn't. The said post doesn't 'suggest' anything, that I can see.
themiller
4 Dec 2011
Cumbria, UK
The platform at Oxenholme is already wired so they could recharge the batteries from this during the station call.
Greybeard33
18 Feb 2012
Greater Manchester
Under the current timetable, turnaround times at Oxenholme vary from hour to hour. The longest is 32 minutes, but the shortest is only 4 minutes!
The battery charging rate from OLE would be limited by the power rating of the 25kV transformer, i.e. roughly the same as the traction power demand during maximum acceleration. I would guess that a charging time of at least 20 minutes would be needed to transfer enough energy for a round trip to Windermere with aircon on.
If a charging facility were also provided at Windermere, the charging time could be much less. But then a 25kV "extension lead" from Oxenholme would be needed, or a dedicated rapid charge installation fed from the local DNO network. Perhaps better to spend the money on a few miles of OLE, as originally intended, rather than on battery trains?
td97
26 Jul 2017
I recently made a post detailing that in principle electrification is the most cost effective solution for the branch (the original question was regarding further procurement of diesel trains, but the same principle applies for battery trains; if anything likely to be even more expensive than a diesel counterpart).
For perspective:
£1.7m per carriage for the Civity order. Suppose Windermere would require 3 4-car units. Thats £20.7m.
10 miles = 16km of electrification Oxenholme to Windermere: £2m/stk=£32m, at the upper end of estimates. If the price could be made to be £1.25m/stk then you get £20m to electrify the lot; quite possible given there's no need for any big electrification kit/feeder stations etc.
The units could now be had for effectively free; the DfT-owed 365s, with a bit of a unit reshuffle/cascade on other routes to ensure the 331s end up on the Windermeres.
The only difference is the tight-arsed DfT have to pay out a big cheque to do electrification, but new train orders are financed so cost the DfT next to nothing.
Chester1
25 Aug 2014
How much is electrification currently costing per mile? Five additional coaches for Nothern would be very welcome, especially they lead to follow on orders. The CLC would be the obvious next route, potentially Airport - Blackpool to allow interworking (and recharging).
Greybeard33
18 Feb 2012
Greater Manchester
Northern ordered the 331s before Windermere electrification was cancelled, so some of them (presumably 3-car units) were originally intended to work the Windermere services. When, in 2018, additional 195s were ordered for Windermere, the 331 order was not reduced.
I presume that the main reason for ordering additional carriages is that a 3-car does not have sufficient underfloor space for enough batteries.
superkev
1 Mar 2015
west yorkshire
Getting bit off topic but I would think that electrification costs are as inflated as ever due to most of the hard won skilled crews are disbanded and expensive plant scrapped or rusting away. I hate politicians!
Incidentally battery costs goes an electric car are about £300 a KWhr plus controllers and installation say 500kwhr total and last around 7 years.
Depending on the size needed and how many trains need fitting I suspect batteries will be more expensive than the life costs of a simple tram style catenary.
Re battery capacity for interest BR in the 1950s had an experimental BEMU based on a 2 car Derby Lightweight dmu for the Balletar branch which had a 500kw/hr battery. I suspect at least that per car would be required for the Windemere branch so at £500 a kwhr that's £500000 per car - hmmm.
See
https://en.m.wikipedia.org/wiki/British_Rail_BEMU
K
