Northern Class 331: Construction/Introduction Updates
GrimShady
13 Dec 2016
They are certainly possible, as all other UK CAF DMU orders are gangwayed.
Must have been cheaper! If the Sprinters have them then these should too, features should be added with every new generation not removed.
They may regret this omission in the future, especially the two car units.
One plus is a better cab for drivers.
SP Man
26 Aug 2018
The meeting of CAF at Carnforth today. Northern 331 alongside TPE Mk5As
142Pilot
24 Sep 2018
Dare I suggest that a high quality cab may have been a sop for drivers to agree DOO?
Suggest all you want. It's not even remotely true but there you go.
The cab was designed in conjunction with Aslef, and has been fitted with all futureproof kit such as ertms and monitors for doo.
There is no way you could fit all this stuff in and have a gangway.
How are WMT and TfW managing it, then? No DOO kit?
Agent_Squash
22 Jul 2016
Class 387s have support for DOO and ERTMS, and a gangway too!
Jamesrob637
12 Aug 2016
Still on track (ha ha) to have the first couple in service by Dec 10, or maybe Monday Dec 11?
Met 331 001 at Preston today, just as it was about to set off for Lime St.
Plainly still under CAF control, with a CAF ZARAGOZA poster in one window.
It also seems to have UIC? vehicle numbers as well as GB ones painted on.
Eg - one vehicle number was 466 001, while underneath that was the number 947004660017.
There was also a window poster saying: CARS TESTING CENTER PROTOTYPE UT2 EMU.
The seats were still under plastic wraps, but it looked pretty smart.
Mollman
21 Sep 2016
Will these replace the 323s on the Stoke runs, or will that be given over to 319s?
I think 331s will be allocated to Stoke services as these need better acceleration than 319s currently provide.
TRAX
2 Dec 2015
France
That’s a weird and unreadable way of displaying the EVN... shouldn’t they be following the standard UIC format (I believe these have been put on in the UK) ? Which should be, for LNW-GW Joint’s picture, 94 70 0466001-7. Plus the GB country code is missing, and also the VKM (Vehicle Keeper Marking).
themiller
4 Dec 2011
Cumbria, UK
The number has had the spaces removed which makes the number hard to read. However, all required digits are present including the country code (70). The last digit is the computer check number which only ensures that the number is correct.
TRAX
2 Dec 2015
France
Yes I know thanks...
But it still lacks the letter country code and the VKM.
DJH1971
10 Jun 2012
St Helens, Merseyside
Saw this 331 at Liverpool Lime Street this morning which I can confirm was a 4 car set, but strangely was not numbered.
