Glenn1969
The DfT views Northern as a basket case hence 20 years of no growth franchises. In this case nationalisation is the LAST thing that should happen
I've mixed feelings here. Whilst I can see the logic in speeding up Lincoln services by having a "local" train taking up the stations west of Worksop (not a massive priority but I can see accept that the current Lincoln service is tediously slow), having the Gainsborough services split between two stations (some distance apart) might cause a few problems as well as solving other.
Plus there's the issue that the forthcoming improvements to Doncaster - Lincoln (going hourly under EMR) will mean two trains per hour from Sheffield/ Retford to Gainsborough and two trains per hour from Gainsborough to Lincoln but (although the Sheffield - Central and Lee Road - Lincoln services share the same metals west of Gainsborough, they won't share any station.
(also, if any resources are found for regular services through Brigg to Grimsby etc at a time when plenty of other Northern services are regularly cancelled/ short-formed/ inadequately short then I reserve the right to scream about prioritising luxury services over essential bread'n'butter work!)
It was originally proposed to run extra Sheffield to Retford trains to address this situation but it has recently been decided to extend this to Gainsborough Central. How well used these trains will be used east of Retford is yet unknown. Perhaps that is not a priority in these times of DMU shortages.
They're between a rock and a hard place though. They've committed to addressing the poor frequencies of services in the north and are filling their pockets with billions of pounds of taxpayers money on the promise of these better services. Improvements are continually delayed, local politicians are clamouring for heads to roll. Time has run out - the excuses aren't good enough any more. It's no one's fault but their own if they don't have enough trains or drivers. The improvements must happen. If Northern fail to deliver they must be stripped of the franchise and it be given to a public sector body who will actually deliver.
A city the of the size and importance of Lincoln, especially with its increased student population, does need faster and better services in all directions
I'm surprised (unless there's a thread I've missed) to see no comments about the comments on the Calder Valley timings from May.
Most hours manage to have a half hour gap from Halifax to Bradford despite 4-5 trains an hour.
Sowerby Bridge has 2 trains an hour to Halifax and Bradford - in most hours these are 7 or 8 minutes apart.
I used to commute from Sowerby Bridge in the 90s when there were 2 trains an hour approximately half an hour apart. Spacings like that might have driven me to start driving.
So what you are really saying is that frequency is the problem? I absolutely agree with you - service needs to be simplified.I don't think that *frequencies* in northern England are that bad (outside of the kind of rural areas where you wouldn't get a frequent service in any part of the UK) - the bigger problem is the train lengths.
Sadly we have a franchise (and politicians) who are more interested in how many places they can link together with hourly services (which means lots of short DMUs rather than simple/ sensible frequencies over each bit of line).
Great news for the handful of people doing (e.g.) Hebden Bridge to Wigan on a regular basis but it can mean awkward timings on routes like (e.g.) Hebden Bridge - Halifax - Bradford - Leeds, because we are trying to accommodate several long distance trains (generally only two or three carriages long) which means bad co-ordination and makes disruption more likely.
Still, the councillors in some places can claim that their town has been "put on the map" and has some exotic destinations, and isn't that the most important things?
I hadn't seen just how bad the "co-ordination" was, but sadly I'm not surprised - I know that there are a few other examples (e.g. Manchester Airport - Piccadilly, where NINE services per hour still have gaps of up to SEVENTEEN minutes).
This leaves Bradford and Halifax to Huddersfield with a sub par journey time (34 mins from Halifax and up to 48mins from Bradford) which is slower from Bradford than the bus and may be slower than driving which does nothing to help Northern grow its numbers on this route (eastbound the journey is up to 14 minutes quicker)
I am still hoping the gap in the Halifax-Bradford and Bradford-Leeds pattern will be plugged by the 5th train (Nottingham-Bradford and Bradford-Airport) whenever that is able to start
1tph+1tph doesn't equal 2tph. As pointed out that 9*1tph on the Manchester Airport-Piccadilly route gives a gap larger than if there were 4tph (less than half the number of trains) running evenly.
I maybe wasn't explaining myself very well - I was referring to the idea that there are "poor frequencies" in the north - on most lines I'd suggest that trains are already frequent enough and that they are *too* frequent on some lines - especially given the additional services to come in the next couple of timetable changes (generally all short DMUs doing hourly services).
Using the Calder Valley as an example, instead of a simple fifteen minute service from Halifax - Bradford Interchange - Leeds, the obsession with long distance services (so that everywhere has a direct link to everywhere) we are going to have a messy combination of Blackpool/ Southport/ Liverpool/ Chester/ Manchester Airport to York/ Hull/ Nottingham which will mean a lot of (short) services per hour over the core section but also some big gaps.
You could run a much simpler set of services (e.g. one unit could shuttle the eighteen miles from Huddersfield to Bradford and back in an hour, so that can be taken off the messy combination of services through Pudsey) but nobody seems interested.
Regarding the western end of the Calder Valley, there are currently frequencies of 2tph from Manchester to Halifax/Bradford and 1tph to Brighouse. The Chester service is simply an extension of one of the two Bradford services that currently terminate at Victoria - it does not increase the frequency through the core. Likewise, the Airport service (in the unlikely event that Network Rail ever allows it a path through the Castlefield corridor) would likely be an extension of the other Vic - Bradford service (with the Bradford - Leeds section culled), which would give reasonable gaps from the two TPE services between Victoria and the Airport.I maybe wasn't explaining myself very well - I was referring to the idea that there are "poor frequencies" in the north - on most lines I'd suggest that trains are already frequent enough and that they are *too* frequent on some lines - especially given the additional services to come in the next couple of timetable changes (generally all short DMUs doing hourly services).
It can be inferred by comparing the Dec 2017 and Dec 2019 TSRs that the Liverpool - Bradford - Leeds Northern Connect will be an additional service through the Calder Valley core, likely filling in the big gap in the current timetable and providing 3tph between Manchester and Bradford. Is this really an excessive frequency between these two major Northern cities?
hourly from MayAny news on the Northern service York-Scarborough?
sorry my mistake thats the hull scarborough servivehourly from May
Thank you for the correction. So, unless the timetable is recast in December, it looks as though the eastbound Northern Liverpool to Leeds will run over the Chat Moss line only a few minutes behind the TPE Liverpool to Scarborough.The Liverpool service is the extension of the existing service. The Airport service will start from Bradford but interwork with the extended Bradford- Leeds- Nottingham service as far as I know
Sowerby Bridge does have 3tph. It is just that the third train goes to Leeds via Brighouse. Sowerby Bridge has annual pax of circa 400,000 so 3tph looks adequate. Halifax pax is nearly 2 million. I would say between Leeds-Bradford-Halifax there is a case for 5 or even 6tph but not all of them should stop at intermediate stations between Bradford, Halifax and Todmorden.
I also hope the Chester service gets good loadings in May
I would think a fastest category of service might work - say Manchester Victoria - Rochdale - Halifax - Leeds (avoiding Bradford) to give Halifax fast journeys to the two main cities on either end. Tod and Hebden are both about the same usage, but sub 1mn, so I think neither are essential for an additional tph.Sowerby Bridge does have 3tph. It is just that the third train goes to Leeds via Brighouse. Sowerby Bridge has annual pax of circa 400,000 so 3tph looks adequate. Halifax pax is nearly 2 million. I would say between Leeds-Bradford-Halifax there is a case for 5 or even 6tph but not all of them should stop at intermediate stations between Bradford, Halifax and Todmorden.
Ahh my bad, I thought there was an avoiding curve at Bradford. Was thinking of the service in terms of Halifax passengers' journeys, and the quickest possible Leeds-Chester timing.
The Victoria and Blackpool - York stay roughly the same. The problem with the Chester service isn't the path West of Manchester - it reaches Rochdale at practically the same time as the current equivalent service, but that the timings have just been switched from a 150 to 158 with allowances removed as well - there's nothing following it along the Calder Valley to stop them putting in a bunch more allowances or dwell time if they wanted.
Except, the real problem which is the Huddersfield train. It's current path out of Huddersfield is given to the new Castleford extension of the Huddersfield-Wakefield route. There appears to be a path to follow the Castleford train, but the short turnaround at Leeds won't allow it without an extra unit, which Northern won't pay for. You can't move one of the other trains to fill the gap because it'll clash with the Manchester - Leeds via Brighouse service which is basically set in stone to fit around TPE.
One quirk I have noticed in the timetable from May is the 07:50 from Manchester Airport to Liverpool Lime Street via Warrington Central has been moved to start from Wilmslow at 07:48.
Just to fill in the background, in most hours the xx50 Airport to Lime Street via Warrington shares an Airport platform with the xx53 TPE Airport to Cleethorpes (3-car 185). But the 0853 to Cleethorpes is a 6-car 2*185, which does not leave enough platform for the Northern train (the Airport platforms are 8-car length). So instead of an 0850 from the Airport, there is a short working, 0910 Oxford Road to Lime Street.The reason for this is, when the 195 start service it will be a 2x3 car 195
Thanks for providing all this background and reasoning to these changesJust to fill in the background, in most hours the xx50 Airport to Lime Street via Warrington shares an Airport platform with the xx53 TPE Airport to Cleethorpes (3-car 185). But the 0853 to Cleethorpes is a 6-car 2*185, which does not leave enough platform for the Northern train (the Airport platforms are 8-car length). So instead of an 0850 from the Airport, there is a short working, 0910 Oxford Road to Lime Street.
Likewise, the Airport platform is not long enough to be occupied by a 6-car 0750 (2*195/1) to Lime Street at the same time as the 0753 to Cleethorpes. Hence the change to start from Wilmslow and bypass the Airport.
Trying to fit 6-car trains into the Airport station is like trying to squeeze a quart into a pint pot!
This change will leave the Airport with a 3 hour gap between direct services to Lime Street via Warrington (0653 to 0953). And the first arrival from Lime Street via Warrington will become 0928. Clearly Northern is prioritising commuter capacity over early morning airline passengers.
