Northern timetable changes May 2019
Discussion in 'Allocations, Diagrams & Timetables' started by absolutelymilk, 19 Jan 2019.
Thread Status:
  1. Mogster
    Mogster Member
    421
    25 Sep 2018
    The problem is it’s not 5 minutes, then you’ve got to trogg through the Piccadilly concourse and summit Castlefield viaduct. The buses don’t go that way from Longsight either. Everything drives past Oxford Road.
  2. HotelNovember
    HotelNovember Member
    53
    6 Apr 2019
    05:42 Wilmslow-Liverpool, 07:57 Liverpool-Man Vic etc, are booked DMU’s in the short term. Makes perfect sense to use them on that diagram and allows a 319 to do the Preston-Airport shuttle.
    There are 14 323 diagrams at the moment.
    A 323 will do a round trip to Wigan on a Saturday night.
  3. geoffk
    geoffk Established Member
    1,283
    4 Aug 2010
    Are 323s likely to get to Blackpool? A 6 car-train from Bolton in the peaks seems to be needed.
  4. prod_pep
    prod_pep Member
    555
    8 Aug 2010
    Do you have the times for this working, please? I might try to catch it tomorrow night. Thanks.
  5. Mathew S
    Mathew S Established Member
    2,006
    7 Aug 2017
    Haha, I was just thinking the same.
  6. Bovverboy
    Bovverboy Established Member
    1,741
    1 Dec 2013
    According to RTT, it's 2300 Lime Street to Wigan, back ECS to Allerton. Previous journey 2043 Wilmslow to Lime Street.
  7. Mathew S
    2,006
    7 Aug 2017
    I don't know where in Longsight you work, obviously, but have you tried the 192? That would take you right to Piccadilly.
  8. Bovverboy
    1,741
    1 Dec 2013
    'Thomas6187' did say there were going to be fifteen daily (M/F, presumably) diagrams for 323s on the current schedules, and fifteen is indeed the number I can account for. A possibility is that one of the diagrams he said was going to be 323-operated is actually being covered by a 319, but that wouldn't make particularly good sense when 319s seem to be in slightly shorter supply than 323s at the moment.
  9. Thomas6187
    Thomas6187 Member
    372
    27 May 2011
    Rochdale
    I worked it out as 15, and a rough guide to what the diagrams roughly follow
    LT 101 Hadfields + last Hazel Grove
    LT 102 Peak Hadfields
    LT 103 Morning Peak Alderley
    LT 104 Crewe/Liverpools
    LT 105 Crewe/Liverpools
    LT 106 Peak Macc
    LT 107 Stokes
    LT 108 Peak Hadfield + Evening Stokes
    LT 109 Crewe/Liverpools
    LT 110 Crewe/Liverpools
    LT 111 Crewe/Liverpools
    LT 112 Stokes
    LT 113 Day time Stokes
    LT 114 Hadfields
    LT 115 Hadfields
    Edit: After the 01 July, the morning Alderley is worked by a Train from Newton Heath
  10. Bovverboy
    1,741
    1 Dec 2013
    How come all the diagrams are coded 'LT' when only four units actually commence their day at Longsight? Does the code indicate where the units are nominally based, rather than where they're stabled?
  11. Andy1673
    Andy1673 Member
    165
    10 May 2019
    Yes, this code shows units' allocation depot, most of diagrams are consecutive so that a unit off a diagram ending at <A> commence next day's diagram at <A>. An <A> can be the start and finish point for several diagrams.
  12. Bovverboy
    1,741
    1 Dec 2013
    Looks like there could be a bit of a reshuffle in the offing, given that other changes are planned for 1 July. It certainly seems odd that a 323 should be replaced by a DMU when the 323s are pretty well the only type of train which Northern runs in the North West that is not currently in short supply.
  13. prod_pep
    prod_pep Member
    555
    8 Aug 2010
    It may tie-in with the start of 323 repainting and PRM mods.
  14. Mogster
    Mogster Member
    421
    25 Sep 2018
    Plymouth Grove. I have tried going to Piccadilly, it just adds time to my journey. My daily timings are pretty tight as it is but I prefer standing sometimes than getting home later.
    Thanks though :)
  15. geoffk
    1,283
    4 Aug 2010
    I've been to Castleford today and watched this manoeuvre. The platform has been extended and would certainly have accommodated both the 153 on the Huddersfield service and the 150 on the Leeds - Sheffield (or even two 150s), but, as this would be a permissive working, would Network Rail sanction it?
  16. Glenn1969
    Glenn1969 Member
    865
    22 Jan 2019
    How is the Castleford service doing loadings wise? I had heard that usage of that train had dropped since it was terminated at Kirkgate presumably because Huddersfield pax were using it to get to LNER and XC at Westgate
  17. geoffk
    1,283
    4 Aug 2010
    I was on the 1003 from Huddersfield. Three or four travelled across Wakefield and they didn't look like track-bashers.
    There's no publicity for this service at Castleford station. The timetable sheets displayed there show only the two well-established services, Leeds - Sheffield and Leeds - Knottingley. Other than the customer information screen (which gives just a list of departures) there is no mention of the Huddersfield service and perhaps not many people in the town are aware of it. I don't know what Metro or Northern have done locally.
  18. Glenn1969
    Glenn1969 Member
    865
    22 Jan 2019
    I know they are supposed to be improving Castleford station if they can decide how to fund it. Hopefully usage will grow with time
  19. Philip
    Philip Established Member
    1,338
    27 May 2007
    Manchester
    Have Northern completely finished with 185s now? Also is there much chance of seeing even an occasional 185 in service on the Bolton route (working to Scotland)?
  20. 61653 HTAFC
    61653 HTAFC Established Member
    10,873
    18 Dec 2012
    Another planet...
    Metro barely do any publicity these days, and they seem far too submissive to the whims of First/Arriva/Transdev (though Stagecoach not so much!). I gaze jealously at my neighbours in TfGM and Travel South Yorkshire country!
  21. Mathew S
    2,006
    7 Aug 2017
    Unless things have changed, there are still occasional 185 operated diagrams to Scotland (effectively covering for the 350 which had to be taken out of service when it lost an argument with some horses on the line). But you are correct, Northern are no longer hiring in the 185s from TPE, so there should be no more 185 operated Northern services, sadly.
  22. Bovverboy
    1,741
    1 Dec 2013
    185s have always been employed on the Scottish services, even since the arrival of the 350s, simply because the 350s alone can't provide sufficient total capacity on Fridays/Saturdays/Sundays when some diagrams are covered by double units. This was the situation even before 350403's incident, so there certainly aren't going to be any fewer 185s on the Scottish services, there may be more.
    P.S. In the 350403 v horses incident, it was the horses which lost the argument, but 350403 didn't come off completely unscathed.
  23. geoffk
    1,283
    4 Aug 2010
    A feature of recent changes is the greatly improved service to Church Fenton and Sherburn-in-Elmet. The former has a better than hourly service to York (30 trains a day, in fact) and hourly non-stop to Leeds. Sherburn gets most of the hourly York - Hull trains, which take this route rather than the faster and more direct route via the Hambleton curve. I assume this route is taken mainly because of pathing issues on the ECML.
  24. adrock1976
    adrock1976 Established Member
    2,786
    10 Dec 2013
    I have noticed that the short Sundays Only Preston - Hellifield working at 15:35 and the 10:30 Hellifield - Preston working do not appear on the GWR booking website when I checked for today and next Sunday.
    Do both of the above trains exist, as I have found those on the PSUL website? It is noted that the Sundays Only Blackpool - Carlisle via Clitheroe and return are still shown, and appear in journey planners on booking engines.
  25. Kite159
    Kite159 Veteran Member
    13,781
    27 Jan 2014
    West of Andover
    Although a bit rubbish if you want Micklefield or stations towards Leeds (as the Leeds - York stoppers don't call at Church Fenton).
  26. Deerfold
    Deerfold Established Member
    10,289
    26 Nov 2009
    These trains do not run in Summer. The Winter Blackpool North to Hellifield train continues to Carlisle in Summer rather than running back to Preston. Similarly, it starts from Carlisle instead of coming from Preston in the evening.
  27. Tractor37
    Tractor37 Member
    122
    23 May 2017
    An East Coast service through Castleford. I've never heard of such a working in my 19 years at Leeds.
  28. clagmonster
    clagmonster Established Member
    2,123
    8 Jun 2005
    Whilst there are no Northern 185 hire ins in the North West, the 05:59 and 21:04 Cleethorpes - Barton services and associated returns are still booked to be a hired in 185 and indeed have gained New Clee request stops on three out of four workings. These should become Abellio East Midlands Railway services on 19th August.
  29. 30907
    30907 Established Member
    7,986
    Diversions only AFAIK. Are you commenting on an earlier post?
  30. 61653 HTAFC
    10,873
    18 Dec 2012
    Another planet...
    I thought Castleford to York was a regular diversion for LNER and XC as well as TPE.
Thread Status:
Share This Page
