john.aston.96
- Joined
- 26 Nov 2014
- Messages
- 16
Be good if/when this document comes into the public domain
Sent from my iPhone using Tapatalk
Agree with it or not the major routes between cities will have priority for more services. On routes where fast trains mix with stoppers there will be stations that don't get the services they should. Congleton, Mossley, Greenfield, Blackrod, Adlington Lancs, Eccles in my opinion should all get 2tph all day as minimum but faster links between major stations will always be seen as a priority.
Isn't the Levenshulme/Heaton Chapel issue caused by the track layout having been changed to pairing by speed, meaning stopping trains on the fasts in one direction? Or did they not do that? It was sheer madness.
Really, Levvy and Heaton Chapel should be served by a high acceleration EMU service.
Don't you have a source for this?Furthermore I'm pretty sure Eccles is recieving a significant increase in service.
Nor is Altrincham to Chester. There is no technical barrier to running 2tph Altrincham - Chester from tomorrow, if you just had the unit and a crew, and this has been the case for years.
Disley is to receive a worse service
The lines through Levenshulme and Heaton Chapel are paired by direction, with the platforms on the Slows. But routings have to take account of the need to avoid conflicts at Slade Lane Jn (where they switch to pairing by usage) and at Edgeley Jn.
Ah, so the change was not made as proposed. Good
Currently, off peak, the Alderley Edge and Crewe EMUs stop in both directions, as does the Hazel Grove DMU. The remaining call is provided by the Buxton DMU southbound and the Chester DMU northbound.
The Stoke EMU runs through non-stop on the Fasts. Until a couple of years ago it used to provide one of the northbound calls. I believe the change was to improve timetable resilience to WCML delays (it is often held at Stoke or looped at Macclesfield). Southbound it is only a few minutes behind the Alderley Edge service, so it would be pointless for them both to stop.
How many Disley passengers travel to Buxton at off-peak times? If the figure is very low and punctuality improves after the recast could it in fact be argued Disley has seen improved service?
An improved service - but only to Stockport & Manchester. Traffic to Buxton will fall to near zero, because it will be quicker to travel to/from Buxton by bus - and a preferable option to long waits at New Mills Newtown, which is a bit basic to say the least.
But I wonder how much share rail has anyway between Disley and Buxton? The journey time is fairly comparable between both modes, and the bus has the advantage of being every half hour. And many people may just drive anyway. No point going for a market thay isn't really there in the first place.
Arguably it's better to speed up journeys from Buxton to Manchester by omutting Disley etc. as that is where rail has a better competitive advantage.
This is a totally bizarre argument. I have never heard anyone use a potential (without any evidence even) handful of percentage points increase in PPM as a justification for cutting direct trains?
This is a totally bizarre argument. I have never heard anyone use a potential (without any evidence even) handful of percentage points increase in PPM as a justification for cutting direct trains? And it's not only direct to Buxton, it's direct to every station south of New Mills Newtown.
This also does not address the fact that Disley is one of the most likely locations for a big increase in usage but it isn't getting any more trains.
You didn't read the franchise consultation document then. The 'bizarre argument' wasn't just included in it, passengers were specifically asked their opinions on it.
Central Trains had a period of running inter-regional through trains across Birmingham New Street - for example, Cambridge to Liverpool - but stopped this because delays on one 'leg' were adversely affecting the other.
Passengers were asked for their priorities I agree. But nobody was asking about this in the way you put it.
Yes, what sense is there is trying to create faster links between a major UK tech hub and one of the top 5 major cities... who on earth would use such a thing?...
Emmerdale Farm to House on the Prairie though... that's of vital importance...
Get the point, but I can't imagine too many folk do that journey fully. Top 5 for what???
But if so, you'd definitely be better off going via London - mainly because the Liverpool-Brum trains are semi-fast at best. Which yes, is a bit rubbish.
Which makes good sense. I can't imagine many people are desperate to travel from Cambridge to Liverpool who cant get a decent connection and are unhappy at the lack of direct trains. Disley to Whaley Bridge or Buxton is a completely different point.
Liverpool's the 5th largest city in the UK (unless you use an illogical method of working out population e.g. trying to claim the population of Wigan counts towards Manchester's population.)
