Back to the futureSounds like 150275, which was the initial refurb before the grabrails were changed to yellow. It recently gained the new seat covers
150102
They're supposed to go in between another 150 each, therefore they were probably envisioned to be refurbished along with the 150 they were going into. However, the idea to reform some 150/1's into 3 car trains using some /2's appears to have completely fallen by the wayside, with Wikipedia no longer mentioning it anywhere.how come 150209 wasn't refurbished straight after it arrived from GWR? you would have thought they would at least give it a toilet
However, platform extension plans on several routes are still based on the assumption of 60m formations... that's the joined-up thinking that the British railway industry is so famed for!They're supposed to go in between another 150 each, therefore they were probably envisioned to be refurbished along with the 150 they were going into. However, the idea to reform some 150/1's into 3 car trains using some /2's appears to have completely fallen by the wayside, with Wikipedia no longer mentioning it anywhere.
If there's a unit without the TrainFX system (auto announcements) in the consist, the method of work is manual announcements; using the TrainFX can prevent the cab to cab being used as the auto announcements cannot be overridden in the unit without the system.I'm on 158792 this morning, which is coupled to a 153 and the PIS is off. Is this as a result of the 153 being coupled to it, and surely this wouldn't now be allowed?
As far as I'm aware, that unit is just diagrammed as a standard 150 (I've certainly seen it around!)A 150 was running York - Leeds via Harrogate this evening, relating to dementia :-
https://www.northernrailway.co.uk/n...-train-to-recognise-dementia-friendly-railway
Northern has named one of its trains in honour of the Bentham Line and the work carried out by the Leeds – Morecambe Community Rail Partnership (LMCRP) to create a dementia-friendly railway.
Not quite sure what it was doing on the Harrogate line if it was designed in honour of the Bentham line, are Northern really that tight on units?!
It spends quite a lot of time in the northwest, I have seen it lots of timesA 150 was running York - Leeds via Harrogate this evening, relating to dementia :-
movements today between newton heath and wolverton;
first run already moving
https://www.realtimetrains.co.uk/train/O79203/2020-01-11/detailed
https://www.realtimetrains.co.uk/train/O79310/2020-01-11/detailed
and allerton and wolverton, if they run;
https://www.realtimetrains.co.uk/train/O79229/2020-01-11/detailed
https://www.realtimetrains.co.uk/train/O79281/2020-01-11/detailed
Only just managed to see 226 now we have another one! They are getting them refurbished quite quicklyWolverton to Allerton - 323229
Does anyone know when did 323229 go to Wolverton - a quick search doesn’t turn up the date it went?Wolverton to Newton Heath - 156459
Newton Heath to Wolverton - 156429
Allerton to Wolverton - 323236
Thanks!323229 went to Wolverton 23-11-19.
Thanks.Wolverton to Newton Heath - 156459
Newton heath to Crewe just on way.
https://www.realtimetrains.co.uk/train/K00213/2020-01-11/detailed
Is this 150 102 or was that earlier.
K
As I think both these have already been PRM'd its probably warranty work.150102 on 1039 Crewe CS to Newton Heath.
150115 on 1404 Newton Heath to Crewe CS.
Saw this at newton Heath just before it left150102 on 1039 Crewe CS to Newton Heath.
Anyone in the know as to which Northern units are in the various works - Ariva traincare Crewe, Wabtech Doncaster, Wabtech Kilmarnock, ? Wolverton etc.
K
Thanks, Of the 150s I think that just leaves 150/ 111, 122, 209, 210, 226 awaiting entry to works for PRM mods with 6 in works.150115 may receive the new seat covers and repaint whilst at Crewe
150228 and 150268 are at Kilmarnock, 150110, 150201, 150215 and 150218 are at Doncaster.
