Northern Unit Refurbishments
CJ
18 May 2009
Stockport
Does anyone know if 150001 and/or 150002 have been on any Northern services yet? Or are they going to be refurbished first before entering service?
AMD
6 Dec 2017
No is the straightforward answer.
Traincrews need to be briefed on the differences before they can be used and in light of the current situation there's been other things taking priority, along with a reduction in units required. They will eventually receive works attention to make them Northern units (livery, seat coverings etc etc), but they will just be slotted into the programme at some point, so we expect them out in GWR green for a short while.
CJ
18 May 2009
Stockport
Interesting, makes sense. Many thanks!
sd0733
7 Nov 2012
Todays Crewe to NH is running.
Return is running afternoon.
Unit numbers anyone
Todays other works moves dontvseem to be running.
K
The Newton Heath to Crewe move was 2x150s. Couldnt see the front set but the back set was 150140. The front looked to be a 150/1 and was already in Northern white livery.
superkev
1 Mar 2015
west yorkshire
Sounds like more CET tank installations as 150 140 has already been to Crewe.
K
superkev
1 Mar 2015
west yorkshire
The 150 CET tank fitting is starting to pick up a little now. Northern and Angel Trains will want the tanks fitted first before the deadline before considering interior refreshes.
Thanks. I've asked this before but when is the date when trains can no longer discharge sewage on the track.
K
superkev
1 Mar 2015
west yorkshire
Looks like todays Heaton to Bristol Barton hill is not running now were yesterday's.
However todays Heaton to Holbeck and return look to be. Presumably more 156s for further interior upgrade.
Anyone have the numbers as well as the NH to and from Crewe moves yesterday.
Thanks
K
py_megapixel
5 Nov 2018
Northern England
The PRM TSI specification for the door opening tone is "a slow pulse multi tone (up to 2 pulses per second) of 2 tones emitted sequential; frequencies: 2 200 Hz +/– 100 Hz and 1 760 Hz +/– 100 Hz" [source]. Using Audacity to create a tone following this standard effectively results in the door tone found on Aventras, the Greater Anglia FLIRTs and the CAF stock for Northern, Transpennine Express and Caledonian Sleeper. If you haven't heard it there is an example in this video. The IET stock has a different tone (but with the same frequencies so still compliant) which can be heard in this video.
How are the 150s, 155s, 156s, 158s, 319s and 323s allowed to get away with a completely different tone which doesn't even remotely follow this standard? All of the dispensations I can see seem to be to do with units which were not compliant by the end of 2019, not ones where the refurbishment has not made them compliant!
Halish Railway
26 Apr 2017
West Yorkshire / Birmingham
Is there really a need for a multi tone hustle alarm? As long as there is some sort of tone it should be okay - obviously the door unlock tone should be less vigorous than the closing tone. Whilst we're at it, I can think of multiple trains that aren't multi tone that are new, e.g. Class 700.
But I agree that some hustle alarms e.g. Class 333 aren't loud enough.
py_megapixel
5 Nov 2018
Northern England
I don't think there's theoretically anything wrong with it; the problem is that the standard specifies it so my assumption would be that all the others are non compliant?
3973EXL
2 Feb 2017
NoMorePacers
18 Feb 2016
Humberside
4/6 Bristol - Heaton 5/6 Heaton - Bristol
Are those a pair of 158 moves by chance?
superkev
1 Mar 2015
west yorkshire
I always puzzled why someone at Northern puts paths on each week sometimes over 10 when often only a couple seem to get used. Seems both a waste of someone's time and reserving paths that may be needed by someone else. Perhaps network rail should start charging.
Kev
superkev
1 Mar 2015
west yorkshire
I hear some pebble brain has graffitied 150 001 at NH so it may be not long out of paint, overhaul. I thought NH was fairly secure.
Kev
3973EXL
2 Feb 2017
Kev
Not sure what Northern has to do with it? The paths you refer to are operated by FOC's.
3973EXL
2 Feb 2017
6/6 STP 5Q12 Eastleigh - Heaton
6/6 STP/VAR Neville Hill
6/6 STP Newton Heath
