NR Signal Application
Aivilo
15 Jan 2014
Been contacted by a friend who is applying for a signal persons position.
He is a bit confused about the 20 or so question asking about experience?
My interpretation is they're like competencies so explain a time you have do x,y or z
However he is reading them as simply outline what experience you have?
I don't want to point him in the wrong direction so wondered if anyone has applied recently and can shed light
flappy8
20 Feb 2016
I applied a while ago. There are the scenario questions which are coaxing out whether you have experience in some of the non-technical skills, and then there is the the section which asks about directly related rail/signal experience . I had none so said that!
Aivilo
15 Jan 2014
From what I gather the mix of 20 or so questions are exactly that.
I've not seen the application so going on the assumption that like toc applications they want experience explained like competencies. But he says that it's just experience so simply something like, as a police officer I've dealt with many high pressure situations
carbers255
6 Sep 2016
Hi all. There are around 50 questions to answer and they surround any previous signalling knowledge to situations where you can evidence communication, team work, dealing with difficult situations and leading a team. I guess they will be looking for some indication you hold the basic skills necessary to be considered. Not having previous signalling experience doesn't matter and won't necessarily mean you're rejected.
