NR test train @ bletchely depot
Discussion in 'Allocations, Diagrams & Timetables' started by DarloRich, 23 Nov 2011.
Thread Status:
  1. DarloRich
    DarloRich Veteran Member
    20,493
    Work - Fenny Stratford(MK) Home - Darlington
    There is a drs 37 hauled NR test tain on thefueling road at Bletchley depot - also think it was hiding in a tucked away siding outside euston yesterday evening any info on what it is up to?
    Rail Forums
  3. Hydro
    Hydro Established Member
    2,202
    5 Mar 2007
    MENTOR or Radio Survey, the loose change in my pocket would be on Radio Survey, can't check the roster at the moment.
  4. 33056
    33056 Established Member
    2,340
    12 Nov 2007
    On a train somewhere in Europe
    I saw 37409 lurking at Tring on Monday night with some yellow coaches so probably that. Don't know what the train was for exactly but I don't think it was MENTOR.
  5. DarloRich
    20,493
    i dont think it was mentor but it was pitch black - looks like the yard lights werent working!
    I thought mentor was oos?
  6. Hydro
    2,202
    5 Mar 2007
    MENTOR is alive and kicking, RSC 1 and 3 are doing the rounds at the moment too.
  7. pendolino
    pendolino Member
    737
    22 Nov 2010
    Here Hydro, what's the one I've seen in Selhurst yard a few times recently? The bit in the middle, painted black, in a train that's mostly yellow, looks like two halves of a wagon welded together like a cut'n'shut.
  8. 33056
    2,340
    12 Nov 2007
  9. Dreadnought
    Dreadnought Member
    586
    1 Oct 2007
    It was a standard test train, though not sure which coach it had in it this time. Its the one that runs approx every 4-6 weeks (Mon - Wed) on the Southern WCML though usually with a 31, headcodes are normally 3Q68-3Q70 dependng on which day it is on in the diagram . This is the 1st time I've seen it with a 37 though.
  10. Hydro
    2,202
    5 Mar 2007
    It's an ultrasonic working then. They are fairly unusual with DRS 37's, yes.
Thread Status:
Share This Page
