Off Peak RTN with 16-25 but now DSB. Opinions?
Discussion in 'Fares Advice & Policy' started by tgsh2011, 19 Aug 2015.
Thread Status:
  1. tgsh2011
    tgsh2011 Member
    108
    5 Jun 2011
    On 4 August I purchased an Off-Peak RTN from Euston to Liverpool Lime Street using my 16-25 Railcard. My Railcard expired on 6 August 2015; however, I have since become eligible for the Disabled Railcard (and have duly purchased that card).
    I would like to use the return portion of my ticket (valid until 3 September 2015). Obviously I know the official line; i.e. this MUST be accompanied by 16-25 R/C; however, given that the price of this ticket with the DSB R/C is exactly the same price am I likely to encounter a 'pantomime' should I present this ticket with the DSB card (which is now valid)?
    On a separate issue would I be right in thinking that a Liverpool/Euston return portion used via Sheffield would be a permitted route?
    Thanks in advance!
    Rail Forums
  3. najaB
    najaB Veteran Member
    21,011
    You know the official answer - no, it isn't valid. In good conscience the only advice I can give you is to buy a new ticket and apply for a refund on the unused portion of the original ticket.
    I'd say that you're as likely to find a guard who will pass it as one who would stick to the rules - is the cost of an Anytime single something you're willing to gamble on?
  4. Merseysider
    Merseysider Established Member Fares Advisor
    4,413
    22 Jan 2014
    Nope. Liverpool to London isn't valid via Manchester, let alone Sheffield. You would need a combination of separate tickets to take this route.
  5. PermitToTravel
    PermitToTravel Established Member
    3,044
    21 Dec 2011
    Groningen
    If you explain the situation at a ticket office, particularly that you're not transferring the ticket to somebody else (showing both railcards might help), they might agree to change the discount for you
  6. najaB
    21,011
    That's a good shout, worst thing that can happen is that they say no.
  7. Bletchleyite
    Bletchleyite Veteran Member
    47,010
    Up and down the south WCML (mostly)
    Sounds like the sort of thing where the ticket office stamp and a note on the back might come into play. Best go at a quiet time and they'll be in a better mood and more likely to help :)
  8. tgsh2011
    tgsh2011 Member
    108
    5 Jun 2011
    Sounds a plan. And yes I do have both railcards :)
  9. Merseysider
    4,413
    22 Jan 2014
    Yup :)
    And to the OP, if that fails, a word with the TM (guard) before boarding might get you the OK. I've found Virgin's TMs to be a friendly bunch.
  10. button_boxer
    button_boxer Established Member
    1,270
    12 Nov 2009
    If all else fails, are you still eligible for a 16-25 railcard as well as the disabled one? If so, and the ticket office won't change the discount on your ticket, you could always renew the 16-25 card anyway if that's cheaper than the cost of replacing the ticket. There's no rule that says you can't hold two different railcards at the same time, as long as you meet all the criteria.
Thread Status:
Share This Page
