Jordy
tramboy said:It's also cos French overhead takes a different pan tension to ours (i can't remember whether it is higher or lower).
I think its Higher - but i'm not sure why :?
Jordy
Simming said:Over head, safer, and you get better trains running of it (92s 8) )
Pendos do it at Harrow too, they spark a lotjoea1 said:Another thing - I was standing at Stratford. A 10 coach mk2 90 formation passed. When the 90 passed, it emitted a huge spark and it smelt really bad. That is one disadvantage of OHLE!
Seth said:It's when you touch the running & conductor rails at once that you want to be worried hock: .
Running rails have pretty much no electricity in them at all - only a few volts to operate the track circuits.
Only the LBSCR route was done which is only four platforms (don't think the WLL connection was around all those years ago) so that isn't really as challenging as it first sounds.AlexS said:Well, part of Clapham Junction was done, Birmingham New Street is all done and so on, so it's challenging, but certainly possible!
metrocammel said:I suppose the way forward is some sort of electricity transfer with no "bare" contacts that cant cause electrocution.
Tomnick said:What about transformers? There's no electrical connection between the two coils in a transformer!
Cockfosters said:Though would electricity transfer by magnetism be practical in such a situation?
Carrot cruncherFGWFan said:In any case, I still prefer my diesels.
The OHLE on the ONE WA lines seems to look nicer than the GEML. Do you know why it is. I asume that they were more interested in making it look better for your lines.one TN said:Hi Gang!!
There's no reason why OHLE needs to be ugly. The only reason is that it has been designed by engineers to be cheap to build and easy to maintain. However, there are no practical reasons why the lineside structures couldn't be more "sculptural".
Yes, it would definitely be better to use a linaer motor to propel the train and then use magnetic induction to power train doors, screens, heating, air con etc.If I remember my A-Level Physics, electric traction using magnetic induction would be expensive and even more risky than using OHLE. The strength of the magnetic fields and the size of the coils required to generate sufficient traction current would be enormous and would cause problems with electrical and electro-magnetic interference.
Probably the best way forward is to do away with on-train traction equipment altogether and have a system that drives a low-friction vehicle along a trackway.
With passenger levels rising and if the predictions for increaed frieght by 2020 are correct we might as well have some passenger only networks to creae room for more freight.A Maglev system similar to the one in China is currently the best option using existing technology. It would be an ideal basis for high speed passenger services. On the downside, it wouldn't work as an integrated passenger and freight transport system in the same way as the current railways do.
Thoughts...?
Nick W said:The OHLE on the ONE WA lines seems to look nicer than the GEML. Do you know why it is. I asume that they were more interested in making it look better for your lines.
