OHLE 25kV or 750V DC third-rail
Have your say.
  • Total voters
    54
TheSlash
7 Jun 2005
Marwell Zoo
Well i have just seen sufficent evidence in a demonstration today that you need to make a good 'earth' when you touch the 3rd rail or it won't do anything. Somebody repeatedly belted the con rail with a spanner, deliberately.
Sprog
6 Sep 2005
SPM
:lol: FUN! :scratch: :lol:
Dennis
8 Aug 2005
Trowbridge
Should get a few chavs to try this, only make sure the juice is on!
:violent2:
NumptyDriver
27 Jan 2006
Between chester and clitheroe, lime st and leeds.
in reply to theslash,
i too hold full AC and DC PTS, and regularly drive over / under both systems.
3rd rail is distinctly 'lo-tech'. the main day to day operational difference between the systems is that one slip can more easily be fatal in 3rd rail areas, ohle is out of the way. and ohle is more energy efficient, it's proven that high voltage/low(ish) current transmission is less 'lossy' than high current/low(ish) voltage. I too read papers and watch news, up here in the merseyrail third-rail area there are regular incidents. and dead badgers. maybe such incidents don't make the news down there.
roll on fuel cells.
voyagerdude220
13 Oct 2005
roll on fuel cells.
It doesn't make the news around Lancashire, so I don't think Southerner's will get it
uktrain225
11 Mar 2006
OHLE are no limits.If it use third rail, it only supply DC.If the trainis AC motor,It have to use VVVF!If OHLE,it can supply DC or 25kV AC.so use OHLE is better.
Julian G
9 Jun 2005
OHLE is better than 3rd rail
Look at the examples of 1980 EMU
The pantograph produces a wonderful buzzing noise
Jordy
9 Jun 2005
WCML South
Hmmmm, wonderful :confused: ;)
Jordy
T
Tom
Guest
Third rail CAN use AC.
O L Leigh
20 Jan 2006
In the cab with the paper
Indeed it can but, because there is effectively no current flowing at two points in the AC cycle, the peak voltage would need to be higher than 750V to give sufficiently high mean voltage to run a train. This in turn would lead to greater chance of short circuits with the CR so close to the ground and the running rails.
I would be interested to know whether there are any AC 3rd rail mainline systems anywhere in the world.
one TN
Julian G
9 Jun 2005
one TN
West London Line
North London Line
