TheGrandWazoo
Fair enough but the examples quoted are in the minority. Most businesses bought lower capacity vehicles. Also fair to point out that for much of the 1970s and 1980s, the most common decker had 74 seats!
Operators like Nottingham and Brighton & Hove took long Scanias with East Lancs bodies to ensure high capacity vehicles.
Typical capacity on todays vehicles - H47/28F or even H45/28F, giving at best 75 seats, probably less.
Agree with this, but where it does cause problems is for the larger vehicle sizes (ironically)...49 seats has long been a contract standard for single decks, but you just can't get that capacity in similar sized DDA compliant vehicles - they languish around 41/42 seats.
Same thing goes for Olympians - H51/36F gives a huge 87 seats but the only way you get near that these days is by ordering stretched Scania based E400s, or even moving up to E500s!
A considerable number of our 'older' passengers consider the distance they have to walk to the first seat to be an issue, judging by the complaints we get. It's also a problem for us as an operator as it impacts on boarding and setting down times as the less mobile passengers take far longer to board/alight when they have to walk further down the bus. Pulling off before they are seated isn't an option, so running times have to be increased, resulting in a less frequent service or an increased vehicle requirement.
as an aside to this thread... in response to the criticism that the seating now starts far back on single deckers a number of designs have come out with seats over the front wheelarches accessed by a very steep step... guess which section of the population these seats are popular with? yes you've guessed it... pensioners who couldn't POSSIBLY manage to get into a step entrance vehicle!
Pensioners with other levels of fitness are available.
I can think of a few problems that may be caused by the DDA regs, but not very many. What are your 'whole host of other problems' ?
We shouldn't forget that a largely unintended benefit of the need for things like lower floors, ramps, wheelchair space etc is that the 'buggy brigade' also now use buses more than they might otherwise.
Is the luggage space getting smaller on all newer buses, no matter what manufacturer? I'm sure the luggage space used to be larger on the older buses
It has very little to do with the low-floor, either. The ALX300 Volvos had a huge luggage space behind the driver, but on more modern E300s it has been replaced with seats.
In all honesty the problems on my local route are caused by drivers!
The buses are usually middle sized solos with no luggage space. Whenever it gets busy the drivers lean back out of the cab and shout for people to move down the bus, if it doesn't work as a collective instruction non-compliant passengers are singled out and told to move. The big problem with this is that they seem to move people closer to the back first, regardless of whether they have luggage or a pushchair or are clearly infirm and struggling with the step up at the back. I've seen it before with 3 visibly able people sat on flapdowns in the wheelchair space, passengers towards the rear with full suitcases on their laps and a buggy totally blocking the isle. It ended up running very late due to the time taken to offload and re-load the whole bus for one or two people at the back to get off.
I must be missing something here because as far as I can it is the fault of ignorant, selfish passengers.
In what way are the passengers ignorant or selfish?
If these had identified that it was easier for themselves to forego that seat for someone of greater need, or acted upon the "collective instruction" then individuals would not have needed to be singled out and the bus perhaps a more punctual service could have operated.3 visibly able people sat on flapdowns in the wheelchair space,
