Hey I was just wondering if I could get some information on what an item I got off a grandparent was. I think it’s a light but not 100%.
is there any writing cast into the case? Might give a clue?Hey I was just wondering if I could get some information on what an item I got off a grandparent was. I think it’s a light but not 100%.
Hey sorry I thought I’d uploaded the photo with it on. Here it is.is there any writing cast into the case? Might give a clue?
I’ll check tomorrow if there is and report back. Thanks for the info so far.The fact that the hot strip is pointing downwards suggests that it probably wasn't installed in a tunnel, since tunnel signals tend to be mounted at or near ground level.
A single-lens head could have come from a fixed red signal, but it could also have come from a fixed distant (yellow) signal. It may even have been something unusual like a white light for setting back, although those were usually ground mounted. If the inner lens is still in place, it would be interesting to find out its colour.
Thank you for the info guys! Do you think it’s world preserving and maybe getting it to someone who would appreciate it for how it is or should I restore it and turn it in to a garden light?It's is a signal of some sort. It uses a two-aspect signal casing with one aspect blanked off, leaving the single aspect at the lower position. When mounted at the usual height this single aspect will be closest to the driver's eye-level.
I'd agree with Railsigns that if opened up it will be found that the inner coloured lens will either be a yellow colour to form a "Fixed Distant" or a red colour as a "Fixed Stop" signal. If the latter, it may have been used to limit travel for some form of 'wrong line' working on a running line. For example, at St Albans City station a fixed stop signal (a semaphore in this case) at the north end of the up slow platform allowed passenger trains to be switched from the Down slow to the Up slow via a facing crossover for terminating the train. (It is not permissible for passenger trains in service to approach a 'Limit of Shunt' sign as this is considered an inadequate means of stopping a wrong-line movement in those circumstances.)
Ultimately, it is your property. If you think it would make a nice garden light, go ahead and make a nice garden light. If monetary resale value is most important to you, sell it. etc.Thank you for the info guys! Do you think it’s world preserving and maybe getting it to someone who would appreciate it for how it is or should I restore it and turn it in to a garden light?
I’m not too interested in getting money for it I just wouldn’t want to ruin it if it’s valuable in its current state and would maybe donate it or something. Obviously if it’s a common object that wouldn’t be the case.Ultimately, it is your property. If you think it would make a nice garden light, go ahead and make a nice garden light. If monetary resale value is most important to you, sell it. etc.
It's a little unusual. But it has limited interest as only being a single aspect.Thank you for the info guys! Do you think it’s world preserving and maybe getting it to someone who would appreciate it for how it is or should I restore it and turn it in to a garden light?
See Our Home Page for the next few Open Sunday Afternoons or wait until September for our extended Heritage Open Days......@John Webb - I passed St Albans box the other day on the train and was admiring it, which reminded me of your posts on this forum. I must aim to visit some time!
Thanks JohnSee Our Home Page for the next few Open Sunday Afternoons or wait until September for our extended Heritage Open Days.
Thank you very much for the information! I’ll post some photos if I end up restoring it. Thanks again.It's a little unusual. But it has limited interest as only being a single aspect.
These signals usually work off 100volts with a transformer inside the signal head. I recommend, from restoring such signals:
1. Don't use the inbuilt transformer unless you can get someone to test the insulation resistance.
2. The lamp it is fitted with is bright, but visible over a narrow area only due to the optical design of the signal. Spare bulbs are expensive and not easy to obtain.
3. So at St Albans South box our demo colour-light signals are fitted with 3.5Watt 12v LED bulbs (Type "MR 16" is the usual catalogue description) and fed from a separate 12v power supply.
I would suggest that you might consider something similar to make a garden light out of it. An LED 12v bulb between 3 and 5Watt will give you adequate light - keep the power supply indoors and run a cable out to wherever you have the signal placed to avoid mains voltages outdoors.
My pleasure. If you look at http://www.sigbox.co.uk/sigbox/news/news 2020.eb you can see, about halfway down the page, a description with photos of the way we did a complete rewire and relamping of our 1970s colour light signals - click on the small photos and they are opened up in a new window for easier viewing.Thank you very much for the information! I’ll post some photos if I end up restoring it. Thanks again.
