Nym, that's my favourite typo this year.
Why was it spelt Panoma?
Coz it's by the Panoma canal
I'm still of the view that the priority for the 2CC needs to be it's start and end points... ie beyond Cornbrook Junction everthing is funnelled into 2 lines to St Peters Sq .... and beyond the 2CC project, from Victoria, everything is funnelled into 2 lines up to Irk Valley Junction (Oldham Line).
The 2CC needs to use the disused 1.5km line over the Iron Bridge over Castlefield, and the disused Red Bank 1.25km line from Victoria to Irk Valley.
TBH, I don't think that 2CC is the answer, lets say that Metrolink tracks can take 20tph as the upper limit in City sections, marginally higher on segregated, lets base this on LU and say 27, possibly 30 for a short section.
We have coming from three directions:
Victoria: 10tph Bury, 10tph Oldham & Rochdale
Piccadilly: 10tph E Mancs Line
Deansgate: 5tph Eccles, 5tph Media City, 10tph Alty, 5/10tph Didsbury, 5tph Airport, 5/10tph Trafford Park/Salford Reds
One can see where the problem / pinch point will be here, we need to take services off the Deansgate approaches.
Now, if one assumes we re-open Central and send Alty services in by Heavy Rail then this becomes a tad easyer at:
5tph MC, 5tph Eccles, 5tph Didsbury, 5tph Airport and we have a balanced CC Network, with 10tph extra terminating at Piccadilly. But then opening the line to Trafford Park / Salford Reds and increasing frequencies can quickly cause problems. So for this I propose a 2nd terminus in Manchester serving the Deansgate approaches. Incorporated into an intergrated re-build of Oxford Road station, lengthening the through platforms 1 and 4 to 8x20 or 8x23m length by sacrificing platform 5 to extend 4, and the Piccadilly ends of 2 and 3, shortening these to 4 car length. (This IS possible within the footprint of the current viaduct)
This would provide conflict free terminating on 2&3 at Oxford road, or with clever timetabling, alternate platform services, although terminating on 2/3 may be a better option, either is possible.
5&6 would then be handed over to metrolink served by a new open viaduct (Steel Structure) linking to the end of the Deansgate Locks viaduct, there is plenty of road space to do this if we loose the on street parking.
These platforms at Oxford Road can then take the overspill of anything in excess of 20tph coming from the Deansgate approaches on the Metrolink, weather Central is re-opened or not.
If it is, then services could run as:
5tph Bury - East Didsbury
5tph Bury - Piccadilly
5tph Oldham - Airport
5tph Oldham - Piccadilly
5tph Ashton Under Lyne - Media City UK
5tph Ashton Under Lyne - Eccles
Providing the core 20tph balanced network.
Then add in
5tph Piccadilly - Trafford Park
5tph Piccadilly - East Didsbury
To terminate at Oxford Road, taking the overspill, and not needing four track between Cornbrook and Deansgate as 30tph is marginally do-able, one can alter the destinations as one desires, these can be changed if you like.
If Alty is not heavied back up again, then an expansion of the Metrolink network on this branch will be needed, as demand far outstrips supply and the Mid Cheshire is in need of help, then the whole route should be operated by Tram-Trains of four car length, some with diesel generators to run to Knutsford, Northwich or Chester. Passing loops installed on the line and 10tph slow and 5tph Semi Fast run. This would mean a minimum of 45tph between Cornbrook and Deansgate, requiring four track to be put in, and even more space to be found as two platforms at Oxford Road wouldn't be able to cope with 25tph.
15tph is more realistic for OR's two new platforms, as is 35tph through to Cornbrook, so it strikes me as a preferable option to take this busy arm off Metrolink, put it back on NR so that service levels can be increased (no bottleneck at Navigation Road) and free up other services in the City end of the Metrolink network.
