Operating Incident @ Brighton
Seanmac86
7 Aug 2012
Hi guys and Girls am new here so be gentle and am sorry if this is not the right place, but what is an Operating incident apparently that has happened on platform 5 & 6 which are now closed.
Thanks for letting me join also
hluraven
4 Apr 2012
An example of an operating incident occured last week when a 10-car train was wrongly signalled into an 8-car platform at London Bridge, which caused delays as it had to go back out of the platform and back into a suitable platform.
It could cover a number of similar things but that might be it.
Seanmac86
7 Aug 2012
cool so should be sorted by home time with any luck
now saying an obstruction on the line so who knows :roll:
Evvy73
13 Feb 2009
Mid-Sussex
Latest Tweet states:-
@networkrail: #Brighton - Staff are on site helping to clear the obstruction. Platforms 6/7 currently out of use
......so what ever it was it sounds as though it should be cleared soon.
tcm1106
4 Jan 2010
Rugby
Motorised tug and water bowser fell onto the tracks causing the 3rd rail to short and trip. Reason for the delay is to get a winch/crane to remove the bowser.
ushawk
5 Nov 2010
Eastbourne
Bowser might have been nicked judging by this
From what i have heard, the driver was trying to reverse around to get back to the top of the platform, but misjudged it so it fell onto the tracks. There was a FCC train in platform 5 (the next platform) when it happened so it had probably just emptied its tank.
The staff kneeling to the floor were around the injured driver who has been stretchered to Hospital (injuries arent too bad). Hoping to re-open Platform 7 soon, Platform 6 will remain closed until its removed and safety checks have been made.
Hopefully the driver makes a full recovery !!
ATW Alex 101
28 Dec 2010
Ellesmere port
ouch, wouldn't the driver have received an electric shock looking at the postion of the drivers cab and how close it is to the 3rd rail? And what is that machine thingy?
Hope the driver recovers soon
neilm
3 Jan 2012
I think at Brighton the 3rd rail is protected which might of helped. That machine empties the toilets and I assume also tops the water up.
OxtedL
Quizmaster
23 Mar 2011
I'm not convinced they empty the toilets, I think they just fill up the water? It possibly wouldn't be a good idea to have a tank of raw sewage trundling round a station.
Then again I could be completely wrong.
tcm1106
4 Jan 2010
Rugby
Toilets are done via the CET facilities on depot. Bowsers on platforms only ever contain water.
neilm
3 Jan 2012
Cool thanks for the info, strange because I have been on trains from Brighton that still have no water.
BestWestern
6 Feb 2011
Just water in the bowsers, they don't empty the bogs whilst the train is in the station. Might raise a few eyebrows! As far as I'm aware, the FCC 319's wouldn't have chemical retention toilets?
According to internal info, it was indeed a member of staff driving the bowser. I would agree he/she was incredibly fortunate not to have fallen onto the juice rail, could have been far worse.
tcm1106
4 Jan 2010
Rugby
Apologies. I'm not familiar with 319s! Even so, if they were fitted with tanks, emptying whilst at a station is not going to be happening...
daikilo
2 Feb 2010
As far as I am aware, most airliner toilet waste tanks are emptied at the end of one or a few flights, between flights.
I see no reason why this should be an issue in a station if similar equipment were used That said, whereas an aircraft probably has one and no more than three collection points, trains still have one per vehicle, and vehichle lengths and access point locations vary. I believe it is not an issue of whether but rather, how.
Harbon 1
30 Apr 2011
Burton on Trent
If this happened though, there is room for error, as most trains don't have a 90 minte turn around time. Also it could cause chaos as happened years ago where the person who was emptying the tank turned it from suck, to blow, the rest writes itself, with a large thud, and suddenly browning windows :lol:
pendolino
22 Nov 2010
That's not quite what happened as far as I'm aware. The train was routed into platform 14 but the driver stopped at the signal and queried the route because he had 10 cars (14 is 8 cars in length). But the signal he had stopped at only leads to 14/15/16 (all 8 cars) so he had to change ends and go wrong road back one section and be routed back in to a different signal that gives access to 9-13 (these are 12 car platforms).
Sorry, a bit pedantic I know.
MCR247
7 Nov 2008
I wouldn't like to be walking along the tracks on the approach to London Bridge! (if it was mon-gangway stock)
KA4C
7 Mar 2012
Well, you get the block on the adjacent road and only get out on the P Way between units
jopsuk
13 May 2008
"Operating incident" is a bit of a catch-all term that can be used when:
A: the explanation is a bit long winded
B: the explanation is a tad embaressing
C: Control don't yet know what has actually happened
asylumxl
12 Feb 2009
Hiding in your shadow
I believe the 319s do have retention tanks. Chemical? I don't know. Unless there are different kinds of retention tanks.
If so, forgive my ignorance :).
westcoaster
4 Dec 2006
DTOS A or B
Just an update, the member of staff involved did come into contact with the 3rd rail, and luckily and I mean it only received burns to his arm. He managed to get him self up of the track just a driver got there to help him, one lucky chap. Hoping for a speedy recovery.
Class377/5
19 Jun 2010
Note not the latter for most TOC's actually. That's why they use the term problem under investigation. Operating incident is something different and viewed very seriously.
Actually that's not the full story but a part missed out if we're being pedantic.
