Orcats
Discussion in 'Fares Advice & Policy' started by Intermodal, 31 Aug 2011.
Thread Status:
  1. Intermodal
    Intermodal Member
    948
    3 Nov 2010
    The North East
    Any good guide on how this works or is it generally private?
    Rail Forums
  3. First class
    First class Established Member
    2,733
    9 Aug 2008
    Private unfourtunately.
    TOCs can't even see what each other gets, although it is probably easy to guess on some flows.
  4. martinsh
    martinsh Established Member
    1,519
    27 Jan 2011
    Considering a move to Memphis
    They make it up as they go along, don't they ?
  5. First class
    2,733
    9 Aug 2008
    What does the OP want to know about ORCATS?
    I can help, but won't provide numbers.
    LENNON is also key to ORCATS. Depending on what you want to know, LENNON may be relevant.
  6. Intermodal
    Intermodal Member
    948
    3 Nov 2010
    The North East
    Well, I was just wondering how it is calculated. For example if there is an Off Peak return at £30, and three TOCs can be used each way, would each TOC get £10, or is it done based on who's "turf" it is, or based on service frequency, or what? How do open access operators come into it?
  7. First class
    2,733
    9 Aug 2008
    Lets say Liverpool to Chester SDS Any Permitted, £8.50.
    Step 1
    9% of that ticket goes to whatever TOC sold it (at a station)
    Step 2
    Merseyrail, ATW, Virgin, London Midland, TPE, EMT and Northern are all entitled to a part of that ticket due to various permitted routes being available, (via Runcorn, Warrington & Birkenhead).
    Step 3
    Allocation Factors
    -Who runs the most trains
    -Journey times of those trains
    -The route of the trains
    -The frequency of service
    -The capacity of the rolling stock
    My Chester Any Permitted example would meanthe fare split as follows:
    Merseyrail - 60%
    Arriva - 15%
    Commission 9%
    All other TOCs share remainder.
    If it was route BIRKENHEAD
    Merseyrail - 91%
    Commission 9%
    All other TOCs 0%
    The operator who sets the fare is *usually* the one who stands to make the most money from the flow, although this isn't always the case. Sometimes it is better for one operator to set the fare, despite say never operating any services.
    Consider this,
    Merseyrail can increase fares by Inflation only.
    ATW can increase fares by more then inflation.
    Example:
    If Liverpool-Chester Any Permitted was priced by Merseyrail initially, then "given" to ATW, then Merseyrail will still get most of the ORCATS share (as per above criteria). Merseyrail therefore have a "fares rise" that is "out of their control" but increases their revenue nonetheless.
  8. bb21
    bb21 Moderator Staff Member Moderator
    23,166
    4 Feb 2010
    There is also an example of ORCATS working here.
  9. yorkie
    yorkie Administrator Staff Member Administrator
    41,173
    There is no way to know what the formula is, so no way to know how much each TOC would get. All we can go on is little snippets of information that have been revealed. But if TOCs don't like what the formula produces, they can appeal.
  10. RJ
    RJ Established Member
    7,147
    25 Jun 2005
    Rail replacement bus cab
    Manual ORCATS surveys are periodically undertaken in some cases. I spent a day in revenue management learning a thing or two about it.
  11. 142094
    142094 Established Member
    8,782
    7 Nov 2009
    Newcastle
    Probably a good thing about ORCATS is that it has allowed fringe operators such as GC to get into the market. Also would be good if some of the other Open Access scheme that have been mooted got off the ground, but half the time it seems to be the DfT saying it would extract revenue from other TOCs (then again wasn't privatisation meant to encourage competition? :roll:).
  12. swt_passenger
    swt_passenger Veteran Member
    19,375
    There is usually a section on ORCATS at the back of the annual stations usage report, because they need to use it to determine one of the usage stats, which is interchanges. Appendix 1 here: http://www.rail-reg.gov.uk/upload/pdf/stn_usage_report_0910.pdf
Thread Status:
Share This Page
