YorkshireBear
- Joined
- 23 Jul 2010
- Messages
- 8,692
How will stations on the Styal line be served?
It is no longer a self contained stopper. Doesn't mean it is being removed. And the Man Pic - Crewe via airport stopper remains.
I hope this doesn't mean that some stations will have long gaps as per Levenshulme and Heaton Chapel on Sundays which have two trains within quarter of an hour of each other, then nothing for 45 minutes (this applies only country-bound, Manchester-bound it's more roughly every half hour)According to the May 18 Northern timetable thread, the Chat Moss stopper will continue as an all stations to Crewe from Piccadilly (as notlob.divad says) and the other Northern Airport services will be skip-stop, stopping at either one or two stations between Piccadilly and the Airport.
So what about passengers on this line who want to go to Manchester Victoria?
When's this likely to be happening?The TPE services will stop at St Helens Jn and/or Newton le Willows.
There are going to be Northern services from Liverpool (and Chester) to the Calder Valley via Victoria as well, don't know what the stopping patterns will be.
Where did you get this information from?The first Northern passenger train on December 10th over the Chord is now showing an 08:40 service from Victoria to Oxford Rd, returning at 08:57 to Leeds.
May 2018. It was supposed to be december but everything has been put back due to delays in electrification meaning Northern do not have the quantity of self powered Rolling stock to cover the full change.When's this likely to be happening?
NRE suggests a Cheshire Day Rover at £23 is required for the Victoria to Oxford Rd journey! I hope fares between Manchester stations are sorted out before then.
Yes, but it's possible to buy a ticket from one central zone station to another (e.g. Pic-Deansgate) for substantially less than the price of a Cheshire Rover.IIRC it still counts as the central zone so if you've got a ticket to one station it's valid to all (listed as Manchester Stns on tickets)
If the supposed fast Newcastle is going to go from non-stop Liverpool to Manchester to calling at one of the stations mentioned, isn't that going back on the idea of the genuine fast Liverpool-Newcastle calling at principal stations only? If DfT only ever envisages slow trains on the trans-Pennine route, then what's the point of talking about (a) major route improvements along the present line, and (b) ideas of an HS3?On a side note, I believe there are still 2 open questions about the TPE stopping pattern.
1. Is there going to be a none-stop Liverpool-Manchester train with the 2nd making 2 stops, or will each train stop once?
I thought that was evident from my post, this earlier journey is being shown on National Rail Enquiries (as well as realtraintimes).Where did you get this information from?
Hazel Grove will be one...the other???Out of sheer interest only, what are the chosen "one or two stations" between Manchester Piccadilly and Manchester Airport that you make reference to above?
Oops, I meant Heald GreenMight be a bit hard given that Hazel Grove isn't on the Manchester Airport/Styal line...
The problem of sending more trains that way isn't the chord but Piccadilly & Oxford Road stations, the platforms 15/16 at Piccadilly and the lengthened platforms at Oxford Road are needed.This has probably been asked about a million times but when is the date when TPE start using the chord too? Certainly doesnt look to be too stretched taking the the 8 trains a day from Northern.
Hopefully that's not true, because the TPE services should start May 18, while there's no chance of those works completing before then. Signalling upgrades are needed along with Northern receiving enough rolling stock to take over the CLC - Airport service, according to earlier discussions on this thread. The Northern service is also due to run through to the Airport by May 18.The problem of sending more trains that way isn't the chord but Piccadilly & Oxford Road stations, the platforms 15/16 at Piccadilly and the lengthened platforms at Oxford Road are needed.
On the Airport Line one train each hour will stop at:
Mauldeth Rd and Burnage
East Didsbury and Heald Green
Gatley and Heald Green
East Didsbury
Heald Green
One All stops
Isn't what we have now nearer 2tph all stops, then others are just Airport or Heald Green and Airport?
Yes, all the extended ATWs stop there.Does the mid-day period Llandudno to Manchester Airport have an intermediate stop at East Didsbury. How long will this ATW service be running as such?
