Anonymous10
what lines were the lines that the original pacers ie class 140 and class 141 operate i seem to remember a photograph of the 140s at landore did they operate in west wales??
The 140 did a tour of much of the country as it was a demonstrator of the Pacer concept. (If you search for 140001 and random stations around the country you might find pictures - I found Plymouth, Blackburn, Birmingham, Swansea in just a few moments)what lines were the lines that the original pacers ie class 140 and class 141 operate i seem to remember a photograph of the 140s at landore did they operate in west wales??
It's mentioned in one of the other threads that they used to run York to Darlington.I am sure I saw one of the west yorks green & white units at Darlington in the distant past!
what units could they work with in multiple using those gangways then?I remember travelling on 140001 several times between Burscough Junction and Ormskirk in 1981
By John Atkinson - Prototype Pacer 140001 - Ormskirk 22/ 08/ 81
Disclaimer “Fair Use” Act ,- Non Profit - For Educational & Entertainment Purposes Onlywww.flickr.com
None - it isn't a gangway, just an end door, similar to those on a 313/315/315/507/508.what units could they work with in multiple using those gangways then?
It's just an emergency exit door for the cab because it doesn't have seperate cab doors.what units could they work with in multiple using those gangways then?
ohhh ok thanksIt's just an emergency exit door for the cab because it doesn't have seperate cab doors.
