Overcharged by Oyster (somewhat my fault)
I've managed to get myself charged £6.90 due to having an incomplete journey. This came about because I arrived at Waterloo platform 13 and wanted to take the Bakerloo line to Leicester Square and then onto Kings Cross so seeing an entrance to the Bakerloo on the platform I took it. However, from here things went wrong. I came across a set of barriers which I touched in on, then the entrance to the Bakerloo line which was behind these barriers was blocked off so I had to go around and then touch in again on another set of barriers before continuing on as normal. It's this first touch in that has caused the me the problem as it seems that Oyster has interpreted it as me touching out not in and it doesn't know where I've come from so has charged me accordingly.
I did ask someone on the second barrier if this would be okay but I guess he didn't understand my question as he just told me to touch in and carry on as normal. So is there anyway to get my money back (as I've not actually done anything wrong) or am I just going to have to chalk this up to experience?
I've attached a copy of my journey history for yesterday if it's of any help.
MikeWh
15 Jun 2010
Crayford
Assuming you were on a paper ticket into Waterloo I'd call the helpdesk and explain. The first set of barriers are the exit from Waterloo NR followed closely by the entry to Waterloo LU. I'd imagine this is a common issue so you should have no trouble getting a refund.
I was on a paper ticket, I'll call them up. Thanks :)
Urban Gateline
8 Mar 2011
Ah ok, so in actual fact you touched OUT on the Waterloo barriers in the subway with your Oyster card instead of using the ticket to get out? Then you touched in on the LUL barriers.
I'd keep your ticket if you can to explain to a LUL ticket office when you try to get a refund, but wouldn't hold much hope in getting a refund as it was your mistake, not a fault of the system.
If you'd used the barriers at the end of the platform to get onto the concourse I bet you'd have used your paper ticket as usual?
Must be something psychological about being underground made you use Oyster to get out when you shouldn't have... :D
Yeah that'll have been it along with thinking about what route I was going to take to get across London, I was in full on underground mode not thinking about the fact I was still platform side on National Rail.
Pretty stupid all in all, anyway I'll give 'em a call tomorrow and see what I can do.
34D
9 Feb 2011
I think this is a little harsh - iirc waterloo NR wasn't barriered at all until fairly recently.
Furthermore, it isn't obvious at all what a barrier line actually pertains to - if it was labelled as NR exit gateline or LU entry gateline it would be clearer.
W-on-Sea
18 Dec 2009
I've been able to get refunds without any difficulty when I've made a mistake (e.g. touching in/out with my Oyster PAYG card when I meant to put my National Rail season ticket through the gate). So long as you don't make a regular habit of it, you shouldn't have a problem either.
bb21
Emeritus Moderator
4 Feb 2010
I fully agree. If it is an easy mistake for the passengers to make then there should be notices next to the readers advising of this fact.
I do realise that not everyone will read them though ...
goldsounds
8 Feb 2012
You can request a refund however you have 28 days to do this as it states in the Conditions of Carriage :)
