I have booked a Goldcard off peak return booked for Southampton Parkway to London ... . What extra would I need to cover the break of journey on the way home to Guildford.
You don't need any extra ticket to break the journey on the return leg when using a
£29.45 Standard Gold Card Off-Peak Return SOUTHAMPTON AIR - LONDON TERMINALS Route ANY PERMITTED at any station on any permitted route between an appropriate London Terminal and Southampton Airport Parkway.
The
National Routeing Guide tells us that Guildford lies on a permitted route between Southampton Group and London Group using
map PD. This would allow you to break the return leg of your journey overnight at Guildford and to travel at no extra cost the next day from Guildford to Southampton Airport Parkway. But there are two problems with doing this.
Firstly, map PD does not allow travel from Paddington. You would still be able to make the outward leg of your journey to Paddington via Reading using a different combination of maps, but on the return leg you would need to travel via Barnes, Wimbledon or Elephant & Castle. In effect, this means using one of the former Southern Region terminals in London.
Secondly, if using
map PD to continue the return leg of your journey on the second day from Guidford to Southampton Airport Parkway, you must travel via Havant. You can't travel via Basingstoke.
If returning from a former Southern Region terminal and/or travelling via Havant is inconvenient, you would need to buy additional tickets.
What extra would I need to cover the break of journey on the way home to Guildford. Would a ticket from Woking to Guildford cover me?
You would need tickets valid from Woking to Guildford on day 1 and from Guildford to Woking on day 2. There are no return tickets available with validity for more than one day for this short journey. A Gold Card Standard Single Woking - Guildford costs £2.50. The next day Guildford - Woking would also cost £2.50, unless travel is before the Gold Card discount becomes available, in which case it would cost £3.80.
